Author Topic: [Shipping Starting] LZ-GH Keyboard (taking LED options...)  (Read 357123 times)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [CLOSED] LZ-GH Keyboard (taking LED options...)
« Reply #1400 on: Fri, 07 June 2013, 17:41:49 »
Can be done a kb case out of Marble?
Probably if they have the right tools. I imagine a water cutter may be required.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1401 on: Fri, 07 June 2013, 18:34:42 »
I just thought that the shelled aluminum was a bit meh, nothing wrong with it at all, just not my preference if I was to give $500 to someone for a keyboard.
Technically, the keyboard wasn't $500.  It was $315.  Even with shipping, it won't hit $400.
Yes it will, 125$ + 315$ makes it 440$ shipped to me with a pit stop in boost's garage
that hurts but still, I love the board and I can't wait for the postman to ring at my door with it under his arm
Regarding shipping cost,
Elrick if you read this and you feel like paying a bit more for shipping I can send you my paypal address anytime. And please don't be shy, just ask for it!
* tjcaustin high fives batmann from france
Offline jcrouse
« Reply #1402 on: Fri, 07 June 2013, 18:36:25 »
I only use a phone, tablet, or laptop in the bathroom. Definitely no Korean keyboard. No shelf for it across from the toilet!
Nothing that can collect small curly hairs, very smart indeed.
Offline SmallFry
« Reply #1403 on: Fri, 07 June 2013, 19:50:53 »
So, where is the programming utility/drivers/whatever I need.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1404 on: Fri, 07 June 2013, 19:59:49 »
Linked in the first post
How to program the LZ-GH
http://red-line.kr/pds.html
You read Korean, right?  ;)
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #1405 on: Fri, 07 June 2013, 20:02:13 »
Ah, thanks. The manual will be a bit tougher. I'll see what Google Translate can do.
« Reply #1406 on: Fri, 07 June 2013, 20:32:37 »
lol :))
Offline SmallFry
« Reply #1407 on: Sat, 08 June 2013, 17:19:35 »
Boost, I need info on how to program this thing. I'm Google Translate does nothing really. I can't seem to figure out how to get the firmware to take.
Also, FWIW. Pics.
« Last Edit: Sat, 08 June 2013, 19:33:11 by SmallFry »
Offline codyeatworld
« Reply #1408 on: Sat, 08 June 2013, 21:16:29 »
That looks great smallfry!
So when I receive my lz-gh will I need to flash firmware onto it?
Offline SmallFry
« Reply #1409 on: Sat, 08 June 2013, 21:21:04 »
Perhaps, for the LED modes. I'm not sure at the moment.
Offline alaricljs
« Reply #1410 on: Sat, 08 June 2013, 22:06:47 »
I am in the same position, cannot figure out the software without english.  Doubly irritating is that I have boards with differing firmware or settings.  First board I tested had the LED brightness set to wtf dark, really worried me that the resistors were wrong or something.
Offline SmallFry
« Reply #1411 on: Sat, 08 June 2013, 22:14:47 »
I believe that I have figured out the raw programming part (just for mapping keys).
1) Plug in the LZ-GH
2) Press a key on the virtual TOP keyboard in the utility
3) Press the place you would like it in in the BOTTOM keyboard in the utility.
4) Press save up in the top left.
NOTE: For winkeyless layouts, make sure you download the right layout file from the LZ site. (or linked below)
What I have NOT figured out yet is the LED programming modes, though I presume that the modes from left to right are...
1) Full LED On
2) Gaming Mode
3) Text mode
4) Mood Mode
5) Pad mode, which doesn't apply to this keyboard since it doesn't have a supplementary keypad.
I will report back if I can figure out this LED situation. Also, sent you a PM Alaric.
« Last Edit: Sun, 09 June 2013, 19:58:28 by SmallFry »
Offline SmallFry
« Reply #1412 on: Sun, 09 June 2013, 19:58:47 »
Also, I have figured out how to control the LED modes without using the GUI. Hold the "M" (Macro, not the actual M key) and press 1-5. 5 is irrelevant since it controls a pad that isn't attached to this keyboards. By default, the "M" key is the Pause key.
By the way, DO NOT HOLD THE ESC WHILE PLUGGING IN. This makes the keyboard go back to the default keymap.
Offline alaricljs
« Reply #1413 on: Sun, 09 June 2013, 20:09:50 »
Except those boards that have a different firmware loaded for some reason... Then it's the ~/` key.
Offline SmallFry
« Reply #1414 on: Sun, 09 June 2013, 20:13:52 »
Hm, I suppose that you need to wait for Boost to drop the firmware file. That is really odd. Can you change it in the macro tab?
Offline Batmann
Re: [Shipping Starting] LZ-GH Keyboard (taking LED options...)
« Reply #1415 on: Mon, 10 June 2013, 01:00:53 »
Usefull stuff here, good job SmallFry.
Do you know if Lz Mini use the same controller?
Offline alaricljs
« Reply #1416 on: Mon, 10 June 2013, 01:12:05 »
It doesn't.  The PCB in an LZ-mini is OTD produced, whereas the LZGH is the first of LZ's in-house PCB designs.
Offline Batmann
« Reply #1417 on: Mon, 10 June 2013, 01:23:15 »
Thanks, gonna check this out
Offline pasph
« Reply #1418 on: Mon, 10 June 2013, 03:02:05 »
Seems that LZ support isn't the best, or you are just waiting for it?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1419 on: Tue, 11 June 2013, 18:20:35 »
So no word on the game board boxes i ordered via usps, does anyone have another source for theses boxes?
On the other note. Int orders that did not order soldering will go out tomorrow.
-Enzo Ferrari
Offline AKIMbO
  • HHKBro
« Reply #1420 on: Tue, 11 June 2013, 18:22:09 »
They usually take a little while to show up.  Mine took around 1.5 weeks after I ordered them online.
| KBD75 (box reds)
Offline Caaaarrrt
« Reply #1421 on: Tue, 11 June 2013, 18:52:29 »
Yay! :D Thanks Boost!
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1422 on: Thu, 13 June 2013, 22:08:39 »
Boxes in. Will be out on sat
-Enzo Ferrari
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1423 on: Thu, 13 June 2013, 22:55:13 »
Oh boy, getting excited now. I will probably be missing something stupid like a  7x spacebar wire or SMDs and be unable to build it for awhile.
Edit: I forgot this comes with stabilizers, should be fine.
« Last Edit: Fri, 14 June 2013, 07:37:23 by danielucf »
Offline SmallFry
« Reply #1424 on: Thu, 13 June 2013, 23:03:31 »
Do we have any info on the firmware, Boost?
Offline YoungMichael88
  • HHKB Wannabe
« Reply #1425 on: Fri, 14 June 2013, 14:21:01 »
Excited!! Although I will need to get some soldering practice in before I can build mine. And for this I will need solder. And for this I will need money.... And I don't have money...... Who wants to give me money??!?!
« Reply #1426 on: Fri, 14 June 2013, 14:37:42 »
Do you just need solder, or do you need a full soldering station setup?
« Reply #1427 on: Fri, 14 June 2013, 15:12:03 »
He just needs some solder. And to grow a pair!
Offline metafour
« Reply #1428 on: Fri, 14 June 2013, 20:20:28 »
Sounds like he needs to get a job. ;)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1429 on: Fri, 14 June 2013, 22:05:58 »
So glad I'm getting this finally.  Hopefully, I can get it before the people that paid for assembly get th--oh wait.
Offline Moomoo
« Reply #1430 on: Sat, 15 June 2013, 10:11:33 »
If anyone wants to sell one AUS hit me up
Offline Glissant
« Reply #1431 on: Sat, 15 June 2013, 10:21:42 »
alaricljs, I would love it if you got back to me via PM. I did ask you about the LEDs and paying for them over a week ago now.
Offline alaricljs
« Reply #1432 on: Sat, 15 June 2013, 10:39:41 »
Sorry, mostly just noticed the thanks and then the ~200 PMs since then made it easy to forget anything else.
Invoiced!
Offline Glissant
« Reply #1433 on: Sat, 15 June 2013, 10:56:39 »
Cheers, brother =). Paying now!
Offline Batmann
« Reply #1434 on: Sat, 15 June 2013, 13:16:08 »
I missed the carrier because my phone was on silence mode, FML 😭
  • HHKB Wannabe
« Reply #1435 on: Sat, 15 June 2013, 13:37:17 »
My carrier is Halverson. He holds the power!!!!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1436 on: Sat, 15 June 2013, 13:52:33 »
All shipped on my end!!!!
-Enzo Ferrari
Offline alaricljs
« Reply #1437 on: Sat, 15 June 2013, 18:40:38 »
So I just ran out of resistors for the bright LEDs... I'll admit being a twit and not counting them before cutting them up.  Soooo, here's the deal:
732Ohm are for blue/green/pink/white  (label: 7320)
1.2kOhm are for red/orange/yellow (label: 1201)
If those of you with un-built boards could check when you receive them I have a feeling you got more resistors than necessary and should be fine.  If you aren't let me know and I will ship out what you need.
Ok, back to work.
Offline elton5354
« Reply #1438 on: Sun, 16 June 2013, 01:06:00 »
So in order to get full LED support, one would need to solder resistors on the PCB? Or is it already done and can just install the LEDs and it will work?
  • HHKB Wannabe
« Reply #1439 on: Sun, 16 June 2013, 01:31:26 »
You will need to install resistors And the resistors used depend on LED color.
EDIT: however I'm told the areas on the LZ-GH pcb where the resistors go come with a small amount of solder already in place.
« Last Edit: Sun, 16 June 2013, 01:33:48 by YoungMichael88 »
Offline elton5354
« Reply #1440 on: Sun, 16 June 2013, 01:41:13 »
Thanks.  I saw a picture you posted a while back with a large roll of resistors. Was that for your LZ GH?  Want to spare some? :D
« Reply #1441 on: Sun, 16 June 2013, 04:43:45 »
We only have 5000! Hehe. We can send you some sure. What LEDs are you using? I think the big roll was for red LEDs.
« Reply #1442 on: Sun, 16 June 2013, 04:47:58 »
Ok, back to work.
Wait, this is a quote I have from you from youngmichael:
"The resistors need to be a ridiculously small SMD size: 0805 (2012 metric)  Here's a 732 Ohm part #: 71-CRCW0805732RFKEA  This is what I am using on the lower voltage LEDs (red/orange/yellow)"
Now I'm confused. Did you message the wrong ones, or did you mix up the ones in the thread. Or does it even matter!
Offline elton5354
« Reply #1443 on: Sun, 16 June 2013, 09:28:29 »
Uh oh I think red uses more power?
But I would like to have a 100. :D
« Reply #1444 on: Sun, 16 June 2013, 09:30:46 »
In another message, he said 560 for blue LEDs.
Hope he responds soon!
Oh and you can have as much as you need :)
Offline alaricljs
« Reply #1445 on: Sun, 16 June 2013, 11:15:09 »
It's not dependent on color, it's dependent on voltage.  For the LEDs that I sent out the easiest way to differentiate is by color.  For anyone supplying their own LEDs they need to do the calcs based on voltage.
And yes, that was a mistake re: 732Ohm for the lower voltage LEDs.  My brain is stuck on brighter==bigger ## when that's not how it works.
« Reply #1446 on: Sun, 16 June 2013, 11:19:54 »
Ok so whatever you showed Youngmichael should still be correct? Pretty sure you linked him to LEDs and resistors.  He messaged me all flustered while I slept. I hope we don't have to order more resistors, I wanna start building next week!
Offline alaricljs
« Reply #1447 on: Sun, 16 June 2013, 11:23:59 »
Pretty sure we're good via PM.
« Reply #1448 on: Sun, 16 June 2013, 11:25:41 »
K awesome. Thanks again for all the help! :)
  • HHKB Wannabe
« Reply #1449 on: Sun, 16 June 2013, 16:16:22 »
Yea we will be good to go. I messed up by thinking all "like-colored" LEDs shared the same voltage (i.e. one red is the same foreword voltage as any other red) I now know I was wrong and need 1kOhm resistors for our particular red LEDs and our 5000 732Ohm resistors are no good for us....For now...
