Author Topic: KMAC 2  (Read 172826 times)
Offline okooko
  • afk.
Re: KMAC 2
« Reply #300 on: Tue, 26 February 2013, 23:25:49 »
Sheesh, all these questions!
want it.  see it.  buy it.
easy as that.
the buy it part requires funds. Most of which have gone to other KB related purchases.
I aint no CEO, dont wanna be a day late or a buck short
Offline Leewei
Re: KMAC 2
« Reply #301 on: Tue, 26 February 2013, 23:33:22 »
Probably better if you don't mention a time =D What kind of payment are you accepting? credit card okay?
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline FabsSpeed
Re: KMAC 2
« Reply #302 on: Wed, 27 February 2013, 00:01:25 »
27th :) Waiting in line ,... HaHa
| Wanted: KMAC  & KMAC 1.2, 356 Mini, 456 GT |
Offline singaporean123
  • I like keycaps and I cannot lie
Re: KMAC 2
« Reply #303 on: Wed, 27 February 2013, 00:10:09 »
Do you accept kidneys? I was born with two, I think I only need 1
Offline webs0r
Re: KMAC 2
« Reply #304 on: Wed, 27 February 2013, 01:14:02 »
On originative website or on temp forum store thread??
Filco Ninja TKL Browns | Leopold FC700R Graphite Reds | Matias Quiet Pro | Topre Realforce 10th Anniversary Constant-55g | Vortex RACE Reds | CM Storm Quickfire Pro Blues | CODE keyboard Clears
Offline laden3
Re: KMAC 2
« Reply #305 on: Wed, 27 February 2013, 10:17:18 »
Looks like website is up ... anyone grabbing the KMAC?
I rrrove brrracks.
Offline Leewei
Re: KMAC 2
« Reply #306 on: Wed, 27 February 2013, 10:21:44 »
how is the 4s going to happen?
Qsenn dt-35
Re: KMAC 2
« Reply #307 on: Wed, 27 February 2013, 10:25:36 »
Site's looking great.  Look at it just sitting there... so tempted to just get another one :eek:
Re: KMAC 2
« Reply #308 on: Wed, 27 February 2013, 10:27:56 »
i heard that paypal isn't accepted amirite..
Offline Leewei
Re: KMAC 2
« Reply #309 on: Wed, 27 February 2013, 10:30:59 »
no paypal from what I see
Qsenn dt-35
Offline Soulpyre
Re: KMAC 2
« Reply #310 on: Wed, 27 February 2013, 10:37:28 »
When I view the Cart or check out it doesn't differentiate how much of each type of springs/stickers I chose. Also my account is still pending from when the store first came up weeks ago =(
TX 1800 - 62g Clears
KMAC LE - GON's Nerd PCB 62g Clears
KPAD - 62g Clears
KBT Race - Browns, Ducky Shine 4 - Browns
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
Re: KMAC 2
« Reply #311 on: Wed, 27 February 2013, 10:49:37 »
You don't have a quantity listed on the spring bags.
Just sayin'
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline laden3
Re: KMAC 2
« Reply #312 on: Wed, 27 February 2013, 11:02:49 »
Do you need diodes for this?
I rrrove brrracks.
Re: KMAC 2
« Reply #313 on: Wed, 27 February 2013, 11:24:15 »
My KMAC2 came with SMD diodes already installed.
Offline Leewei
Re: KMAC 2
« Reply #314 on: Wed, 27 February 2013, 11:29:45 »
Anything specific that needs to be done when assembling?
Qsenn dt-35
Re: KMAC 2
« Reply #315 on: Wed, 27 February 2013, 11:44:46 »
Carefully break the edges off the PCB
Prepare your switches and install them in the plate
Install the PCB mount stabilizers before you start soldering the switches
Mate the switches with the PCB and make sure everything is laying flat
Solder a few switches to hold it together and check again that everything is correct
Install the LEDs and make sure they are in the correct direction before you solder and snip the leads.
If you aren't using the plate, you have to install the standoffs in the bottom case, seems easy to figure out.
If you are using the plate you have to choose if you want to mount it to the top case or bottom case.  I chose the bottom case.
Hope I didn't forget anything....
Also if you want to program it you need a kbdmania account.
« Last Edit: Wed, 27 February 2013, 11:47:32 by metalliqaz »
Offline Leewei
Re: KMAC 2
« Reply #316 on: Wed, 27 February 2013, 11:45:51 »
Aight sounds good. Haha. I just ordered mine =D
Qsenn dt-35
Offline alaricljs
  • I be WOT'ing all day...
Re: KMAC 2
« Reply #317 on: Wed, 27 February 2013, 12:06:28 »
If you are using the plate and PCB mount switches I recommend seating the switches into the plate and PCB at the same time (1 at a time).
Filco w/ Imsto thick PBT
Offline Patchwrks
Re: KMAC 2
« Reply #318 on: Wed, 27 February 2013, 13:54:24 »
kmac 1.2 please :(
(´・ω・`)denko-chan~~~내 스레드
Offline webs0r
Re: KMAC 2
« Reply #319 on: Wed, 27 February 2013, 14:37:27 »
This. And how to co-ordinate assembly services?   :)
Offline cancelx
Re: KMAC 2
« Reply #320 on: Wed, 27 February 2013, 15:01:21 »
What isn't included in this price?
Model M SSK - WASD V1 - CM Storm QFR - Ducky Year of the Rabbit - Realforce 87U - WASD V2 - K-Type
Offline nebo
Re: KMAC 2
« Reply #321 on: Wed, 27 February 2013, 15:18:53 »
Easier to say what is:
Case, plate, PCB.
Offline cancelx
Re: KMAC 2
« Reply #322 on: Wed, 27 February 2013, 15:21:03 »
Case, plate, PCB.
Dayum, thanks
Re: KMAC 2
« Reply #323 on: Wed, 27 February 2013, 15:23:48 »
You need to add the following to the kit to get a fully functional keyboard:
* Switches (~$60)
* Stabilizers (~$5)
* LEDs ($5-$10)
* Key caps ($40-$120)
* USB cable ($10-$30)
If you don't built it yourself, you will probably spend at least $50 to have it constructed for you.  Plus shipping and paypal fees.
Offline cancelx
Re: KMAC 2
« Reply #324 on: Wed, 27 February 2013, 15:50:46 »
Where can I get switches for a price lower than 1$/each? I'm mostly thinking about reds or clears
Offline AKIMbO
  • HHKBro
Re: KMAC 2
« Reply #325 on: Wed, 27 February 2013, 16:08:53 »
Clears no idea unless you buy a used board.  Reds and blacks have the same stems.  You can search the classifieds...I know there is one guy who is selling a ton of blacks and vintage black switches ($0.20 and $0.35 each).
| KBD75 (box reds)
Offline Leewei
Re: KMAC 2
« Reply #326 on: Wed, 27 February 2013, 16:14:53 »
I saw that thead of vintage blacks but it is already sold out. I would just wait and see sherryton about that 4s package. That is a pretty good deal.
Qsenn dt-35
Offline sherryton
  • Kībōdo
    • Originative
Re: KMAC 2
« Reply #327 on: Thu, 28 February 2013, 21:09:42 »
KMAC 2 available on live store:
www.originativeco.com
Offline alixinhzai
Re: KMAC 2
« Reply #328 on: Thu, 28 February 2013, 21:55:32 »
when 4s come with sherry?
Offline sherryton
  • Kībōdo
    • Originative
Re: KMAC 2
« Reply #329 on: Thu, 28 February 2013, 22:00:48 »
Arranging that with alaric tonight :)
Offline calavera
Re: KMAC 2
« Reply #330 on: Thu, 28 February 2013, 22:02:01 »
Whats a 4s package?
Offline Leewei
Re: KMAC 2
« Reply #331 on: Thu, 28 February 2013, 22:02:09 »
I already ordered a kmac, would I be able to add the 4s in that order? =D
Qsenn dt-35
Offline alaricljs
Re: KMAC 2
« Reply #332 on: Thu, 28 February 2013, 22:07:47 »
Would help if you looked at Skype... :P
Offline alixinhzai
Re: KMAC 2
« Reply #333 on: Thu, 28 February 2013, 23:19:22 »
u wanna sell single 4s without KMAC2 order?
Offline sherryton
  • Kībōdo
    • Originative
Re: KMAC 2
« Reply #334 on: Thu, 28 February 2013, 23:39:33 »
No, it's only for people who purchased the KMAC 2.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
KMAC 2
« Reply #335 on: Fri, 01 March 2013, 00:24:00 »
Please excuse my ignorance...4s?
Offline alixinhzai
Re: KMAC 2
« Reply #336 on: Fri, 01 March 2013, 00:32:50 »
sticker, stabilizer, spring and switch =))
Offline Leewei
Re: KMAC 2
« Reply #337 on: Sun, 03 March 2013, 20:10:21 »
Errr. Any news or updates about that 4s and kmac 2?
Qsenn dt-35
Offline Patchwrks
Re: KMAC 2
« Reply #338 on: Sun, 03 March 2013, 20:14:24 »
that's pretty much all im waiting on to order one
Offline FabsSpeed
Re: KMAC 2
« Reply #339 on: Sat, 09 March 2013, 00:05:56 »
When will the Orders be sent out on the kmac ?
Offline FabsSpeed
Re: KMAC 2
« Reply #340 on: Sun, 10 March 2013, 11:27:30 »
Anyone got the kmac yet?
Offline Leewei
Re: KMAC 2
« Reply #341 on: Sun, 10 March 2013, 20:15:51 »
nope, don't think it has been shipped out. sherryton previously said around 3 weeks eta.
Qsenn dt-35
Offline Patchwrks
Re: KMAC 2
« Reply #342 on: Mon, 11 March 2013, 08:15:33 »
I'd like to know about the 4s so I can actually purchase this thing
Offline rurushu
Re: KMAC 2
« Reply #343 on: Tue, 12 March 2013, 10:58:32 »
no news on KMAC1.2?
Offline KuhnTang
  • Game of Thrones
Re: KMAC 2
« Reply #344 on: Tue, 12 March 2013, 11:42:58 »
Has anyone been able to order anything from Sherry's website?  I get stuff in my box, then go to check out and it won't let me passed the credit card info page.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: KMAC 2
« Reply #345 on: Thu, 14 March 2013, 13:57:55 »
it does this for me too and I've been trying for 2 weeks to be able to order just some springs.
Re: KMAC 2
« Reply #346 on: Thu, 14 March 2013, 14:02:37 »
He's probably wondering why sales are so sluggish :))
Offline Glod
    • YouTube Channel
Re: KMAC 2
« Reply #347 on: Thu, 14 March 2013, 14:10:37 »
this isn't the only time we've brought this up either. Along with the site grouping different weighted springs into 1 row called "Springs" in the shopping cart.
you would think the vendor would read all the posts in their vendor sub-forum but nope.
Offline Michael
  • Formerly Bro Caps
Re: KMAC 2
« Reply #348 on: Thu, 14 March 2013, 14:12:44 »
It's a shame, really. Because I planned on spending some dough on his stuff.
Offline Dianoda
Re: KMAC 2
« Reply #349 on: Thu, 14 March 2013, 15:08:43 »
Is sherry still accepting orders via pm?  That's what I did and everything went pretty smoothly.  Paid via Amazon Payments, order shipped quickly, got my stuff in less than a week.
