Author Topic: Ducky Shine replacement spacebar  (Read 5770 times)
Offline Rick98761
« on: Sat, 26 January 2013, 23:09:41 »
I just got my first mechanical keyboard.  A ducky Shine 2 Blue LED.  I love it so far.  The duck logo on the space bar kind of bugs me, and I would like to replace it with a normal space bar.  Where should I start to find one that matches the finish of the stock keys?
Offline laffindude
Re: Ducky Shine replacement spacebar
« Reply #1 on: Sat, 26 January 2013, 23:24:10 »
You need a UV coated space bar. I am not sure if it possible to buy one by itself nor I think the black ABS will quite match the color of the black paint.
« Reply #2 on: Sun, 27 January 2013, 05:06:10 »
Also they are OEM profile i.e. a bit taller than other keycaps, whereas most replacement spacebars would be Cherry profile, which is lower.
What about colouring over the Ducky logo with a black texta?
Offline MattBuzzy
« Reply #3 on: Sun, 27 January 2013, 05:12:02 »
Nooooooo! The ducky logo is awesome lol
« Reply #4 on: Sun, 27 January 2013, 05:33:01 »
I don't mind it either - not as in-your-face as the CM logos all over my QFR.
So saying, I swapped Win modifiers with someone so I got the ones with Ducky logos and he got the ones with Windows flags on them.
I don't mind the Ducky logo :)
Offline MattBuzzy
« Reply #5 on: Sun, 27 January 2013, 05:43:12 »
Yeah I really like it, but I guess it is not for everyone. If I end up buying a Ducky keyboard, the spacebar won't be going anywhere lol  :cool:
Offline laffindude
« Reply #6 on: Sun, 27 January 2013, 22:17:48 »
See if you can tell which one is the black paint over translucent ABS vs UV coat over black ABS.
