Author Topic: 60% Keyboard - TEX mini Keyboard  (Read 47462 times)
Offline twilek
Re: 60% Keyboard - TEX mini Keyboard
« Reply #50 on: Sun, 17 March 2013, 15:07:15 »
HOLY MUTHER****ING ****!!!! SHUT AND TAKE MY MONEY
Offline cobraj
« Reply #51 on: Sun, 17 March 2013, 15:15:32 »
Wow.
Not saying this keyboard is bad, but did not think it would warrant such excitement :P
Offline histevenhere
  • Student
« Reply #52 on: Mon, 18 March 2013, 22:22:31 »
Very interesting review. The Tex sure does look great ... Especially on top of a macbook air or something ... Would love to see that one day!
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
Offline cannedlemons
« Reply #53 on: Tue, 19 March 2013, 15:41:37 »
Looks really nice, reminds me of a macbook pro a lot. Though the only thing that bothers me is the small shift key = O .
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #54 on: Tue, 19 March 2013, 16:05:59 »
Using Cherry keycaps not a big problem. You can get 2.0 shift from G80-11*00, and 1.0 shift from minicoms. There are lots of random key or blanks that could be used for the Fn and ~. Only the spacebar would be problematic.
For other source like SP you would need to have shift made on same as numpad zero, also not a challenge.
Offline uzoc
« Reply #55 on: Tue, 19 March 2013, 16:36:33 »
I need the delete key up there (not fn).
Tab can be made 1X size and backslash the same, to fit in delete next to the backslash.
Offline jksteger
« Reply #56 on: Wed, 20 March 2013, 10:13:29 »
can someone go ahead and take my money? LOL
J:
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #57 on: Wed, 20 March 2013, 10:20:13 »
J:
According to a post from ShakeR, who runs MechanicalKeyboards.com, it looks like  availability will be in May.
It also appears that the keyboard that I tested is a pre-production model.
Offline jksteger
« Reply #58 on: Wed, 20 March 2013, 15:41:08 »
J:
I emailed them and that's pretty much what they said.
Thanks,
J
Offline Lunartuna
  • Good bye money!
« Reply #59 on: Wed, 20 March 2013, 22:50:42 »
Any idea what kind of stab's this board has?
Shine 2 TKL - Choc Mini
Offline laffindude
« Reply #60 on: Wed, 20 March 2013, 23:27:45 »
Cherry platemount stabilizers.
Offline rknize
    • metaruss
« Reply #61 on: Thu, 21 March 2013, 00:08:41 »
Woah, sam is right.  The staggering in row 3 is not "normal"!  I wonder how that would affect fast touch-typists?
Russ
Offline deazncy
« Reply #62 on: Thu, 21 March 2013, 02:40:14 »
Keyboard looks nice, although the layout is a bit funky. Any idea on what the cost would be like?
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Offline mashby
    • Mashby
« Reply #63 on: Thu, 21 March 2013, 09:17:27 »
Looks like they are averaging around $130 US, depending on the type of switch you choose. Cherry MX-Brown] is listed as $133.
Offline deazncy
« Reply #64 on: Thu, 21 March 2013, 18:19:54 »
Dang... I was hoping that it'd be cheaper. Guessing that the build quality must be very good.
Offline mashby
    • Mashby
« Reply #65 on: Thu, 21 March 2013, 18:58:48 »
The build quality is really high. I didn't see any flaws on the board I looked at and it was just a production sample. I'm told that the final production units are even better.
Plus, you're getting an aluminum topped keyboard with a plate for $130, when a plastic tray un-plated Poker is $90, so price wise, it's pretty good.
« Last Edit: Thu, 21 March 2013, 22:09:41 by mashby »
Offline deazncy
« Reply #66 on: Thu, 21 March 2013, 19:15:15 »
Plus, you're getting an aluminum topped keyboard for $130, when a plastic tray Poker is $90, so price wise, it's pretty good.
Seems very convincing. The keyboard does look nice also.
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #67 on: Fri, 22 March 2013, 01:10:42 »
What font is the legend?
I love the design and the price point but I am so anti logo. Make one without the logo!
« Last Edit: Fri, 22 March 2013, 01:12:45 by OnTheBrink »
Offline deazncy
« Reply #68 on: Fri, 22 March 2013, 01:18:28 »
I don't think the logo looks that bad. Better than some of the others I've seen.
Offline developej
« Reply #69 on: Fri, 22 March 2013, 02:24:04 »
i don't like the large top bezel + logo - it is a 60% board, so your goal should be a small factor keyboard, and then you add a 2cm bezel, why :c
logo should be on the bottom really :)
but the thing i dislike the most is the layout, so many 1x1 in bottom right...1x1 shift is a no go for me. pure or poker layout and im in :D
cancel that, gh60 is here :D
« Last Edit: Fri, 22 March 2013, 02:48:58 by developej »
Offline deazncy
« Reply #70 on: Fri, 22 March 2013, 03:07:09 »
You have a good point. And yeah haha, the GH60 will be the answer to everything.
Offline Polymer
« Reply #71 on: Fri, 22 March 2013, 20:45:14 »
You'd probably adjust but who knows..  Filco did the same thing with their 60% keyboard too...I don't really think that is the way to go....If you REALLY want to add dedicated arrow keys to a 60% type board,  probably best to do it the way Leopold and Matias did...where you extend the keyboard out a bit and out the arrows off to the side...
The issue with all of them will be finding replacement keycaps...Which is why things  like the Poker is attractive..you can actually find stuff for it...
Offline mashby
    • Mashby
« Reply #72 on: Fri, 22 March 2013, 21:04:45 »
Is the Tex Mini actually called the Beetle?
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
« Reply #73 on: Sat, 23 March 2013, 09:11:20 »
Hmm,, I think I can answer that , now we this keyboard name is " beetle "
and everyone can check this link : https://docs.google.com/folder/d/0B7TuRf3KQe7GNTE0RmQ2SDEzeEU/edit?usp=sharing
that have datasheet & layout , all pdf file !!
any question can mail to me :)
and thanks everyone suggest
make different
Offline sordna
« Reply #74 on: Sat, 23 March 2013, 11:08:25 »
Justin, will you have a version with small plastic case, to keep the keyboard as compact as possible (like the Poker/Pure) ?
Please consider it!
Offline justin.wu
  • Less is more
    • TEX
« Reply #75 on: Sat, 23 March 2013, 12:11:51 »
sordna , thanks your advise !!
I think we can have this , make small version !!
but not now !
right now , we want make something different , thanks again !!
Please consider it!
make different
Offline 1391406
« Reply #76 on: Sat, 23 March 2013, 12:32:43 »
The bottom looks to be plastic.
Offline justin.wu
  • Less is more
    • TEX
« Reply #77 on: Sat, 23 March 2013, 18:58:05 »
bottom case is plastic .
if all use CNC , that will have 2 problem
1. too expensive
2. too heavy
make different
Offline dmreeves
« Reply #78 on: Thu, 04 April 2013, 16:32:16 »
Very excited for this as it seems to fit the bill perfectly for me. Forgive me, I haven't read the whole thread but is there any idea when this might become available?
Offline justin.wu
  • Less is more
    • TEX
« Reply #79 on: Thu, 04 April 2013, 19:42:52 »
Thanks !!
and which color you guys like ??
make different
Offline sordna
« Reply #80 on: Thu, 04 April 2013, 21:19:11 »
justin, how does the keyboard case look without the aluminum frame? Can you please post a photo? Is it removable?
Offline justin.wu
  • Less is more
    • TEX
« Reply #81 on: Thu, 04 April 2013, 22:30:37 »
sorry , I can't take photo right now , because all module in office , and I'm home !!
I can take some picture after a few days , aluminum case can removable !!
We have decide some special color for you guys !! right now I have red / blue /
make different
Offline mashby
    • Mashby
« Reply #82 on: Fri, 05 April 2013, 09:05:44 »
Those colors look great! Will they be available separately as an accessory, or do you purchase the keyboard in that color.
Also, any thoughts on a green one?  :cool:
Offline tricheboars
  • Keyboards are Important!
« Reply #83 on: Fri, 05 April 2013, 09:17:25 »
i second a green one. or a purple one. or a yellow one. or an orange one.
actually i think i just want more colors.
Offline justin.wu
  • Less is more
    • TEX
« Reply #84 on: Fri, 05 April 2013, 09:55:38 »
sure !! I will make special color , but I have to try !!
green/yellow/gray/purple...etc
when I make that , I will show all the picture to you guys !!
make different
Offline mashby
    • Mashby
« Reply #85 on: Fri, 05 April 2013, 09:59:21 »
Are you Santa Claus?
Offline justin.wu
  • Less is more
    • TEX
« Reply #86 on: Fri, 05 April 2013, 11:10:59 »
No !!
But I want make something different for you guys !
if you guys want check our news , please come to our facebook fans club ,
http://www.facebook.com/pages/TEX-Electronics-Co-Ltd/472792412756463
good day !!
make different
Offline berserkfan
« Reply #87 on: Fri, 05 April 2013, 15:49:56 »
me want! me want!  ;) ;) ;)
(ps if you are making in different colours, please offer the fans a way to choose the colours. eg you could have a website and let people poll their favorite colours, and sell the 3-4 colours with the greatest demand.)
Offline justin.wu
  • Less is more
    • TEX
« Reply #88 on: Fri, 05 April 2013, 23:37:06 »
Thanks your advise !!
I think I will prepare some different color , and special color will let you choose !
If you in USA , you can ask our distributor (MechanicalKeyboard.com first )
make different
Offline jabar
« Reply #89 on: Thu, 23 May 2013, 01:10:05 »
I really wish the top bezel was symmetric with the bottom. That is, narrower, because the top only seems to make extra room for the Tex branding. If it was completely symmetric with less prominent branding (on the back ideally) it would be a very attractive 60% board.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline theeattre
« Reply #90 on: Fri, 24 May 2013, 09:49:31 »
in person, the size of the bezel is actually quite nice. it lends itself to a more classic design (dressier for sure). and the branding isn't that bad. this is my first time living outside of texas so the branding (though just a nice coincidence) reminds me of home...and vintage TI computer gear. i mentioned in another post how the pics make the bezel look bigger than it is. all in all it's still a mini kb for sure. also, i really wanted to add different keycaps to it but the more i use/look at it, the less inclined i am to mess with it (other than adding a blank set of black). i just feel that it's a more conservative alternative to other 60% keyboards.
« Last Edit: Fri, 24 May 2013, 10:31:02 by theeattre »
Offline justin.wu
  • Less is more
    • TEX
« Reply #91 on: Fri, 24 May 2013, 10:51:00 »
Thanks !!
Our first shipment have already arrival USA , hope you can try :)
and TEX will make something different for geek :)
make different
Offline muness
« Reply #92 on: Thu, 29 May 2014, 16:21:10 »
Got mine today. So nice. I am loving the brown switches.
A couple of questions:
* Is there a list of the remappings somewhere?
* Middle clicking isn't working. What could be the issue? I can hold down and scroll, but clicking it doesn't work (e.g. in a browser to open a link in a new tab)
