Author Topic: Tool to remove spherical cherry keycaps (maltron)? Normal tool not fitted  (Read 2961 times)
Offline urlwolf
Looks like the keys are wider at the bottom, and the plastic walls are thicker...
I have one of those plastic rings with two legs; those work on all cherry keycaps I have but maltron's.
Workaround?
keyboards: Cherry G80-3494- cherry reds | filco majestytouch - cherry browns | kinesis contour - cherry browns | cherry G80 - 1800 cherry blacks.
mice: filco touchpad | logitech G9x | wowpen joy | kensington orbit trackball | zalman fpsgun | intellimouse v1 | logitech rx1500
Offline SmallFry
Re: Tool to remove spherical cherry keycaps (maltron)? Normal tool not fitted
« Reply #1 on: Wed, 30 January 2013, 08:37:30 »
You may want a wire keycap puller from TechKeys, WASD, or EK.
Offline natas206
  • * Commercial Vendor
« Reply #2 on: Wed, 30 January 2013, 15:35:01 »
Offline Lu_e
« Reply #3 on: Thu, 31 January 2013, 15:22:33 »
In a pinch? get a few different sized paperclips, some pliers, 10 minutes, and get creative;
xD
« Last Edit: Thu, 31 January 2013, 15:24:08 by Lu_e »
Just say NO to ABS keycaps
Offline SmallFry
« Reply #4 on: Thu, 31 January 2013, 15:23:53 »
I used bobby pins for the longest time (until late last fall actually) bent into J hooks or something similar. It took me about an hour to strip a board once.
Offline deepthawt
  • ︻̷̿┻̿═━一
    • my programming hobby site, interactive jigsaws, photos &c
« Reply #5 on: Thu, 31 January 2013, 15:40:51 »
ooOOOo add some duct tape to that paperclip key puller and it'd be an instant classic :P
luv it!
[| Ducky Shine II 9087 Yellow LED/BlueMX  |  Saitek Eclipse II  |  IBM Model M 1391401  | Cherry G80-5000  |  Logitech diNovo Mini  |  Microsoft Natural Ergonomic 4000  |  Matias Quiet Pro PC  |  Dell TH836  |  NEC KB-6923  |  Fujitsu FKB4700  |  GearHead Mini USB  KB1700U (89 key) | Filco Majestouch-2 ninja/blues  |   Matias Mini Quiet Pro PC | Ducky Shine 4/Clear MX | E Element RGB Silver/Black Outemu |]
