Author Topic: Hardware Programmable Keyboards?  (Read 3213 times)
Offline TheGrey
« on: Tue, 05 February 2013, 09:03:18 »
Dear all,
I know of the Rapoo V7, but are there any mechanical keyboards around that allow you to store custom key functions?
Cheers,
TheGrey
Offline davkol
  •  Post Editing Timeout
Re: Hardware Programmable Keyboards?
« Reply #1 on: Tue, 05 February 2013, 09:21:16 »
I can think of only custom designs (ErgoDox, the Korean stuff), some vintage/POS keyboards, and the Kinesis Contoured.
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Tue, 05 February 2013, 13:22:35 »
Pos boards - both tipro and access-is are programmable.   The access will be nkro if it's ps/2.
Offline SmallFry
« Reply #3 on: Tue, 05 February 2013, 13:28:21 »
The Filco tenkeyless boards are custom programmable if you put in an HID Liberator.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #4 on: Tue, 05 February 2013, 13:34:43 »
Phantoms yo
Offline SmallFry
« Reply #5 on: Tue, 05 February 2013, 13:35:52 »
I thought that was covered in Davkol's post, hence why I didn't include it.
Offline rknize
    • metaruss
« Reply #6 on: Tue, 05 February 2013, 13:36:38 »
If you are looking for something you can pick up right now in retail, then only the POS boards come to my mind.  If you are willing to build your own kit, then there are some options now (Phantom) with more to come.  Then there is the aftermarket controller for Filco, as SmallFry mentioned.
Russ
Offline SmallFry
« Reply #7 on: Tue, 05 February 2013, 13:38:58 »
Also, Biphany may be working at getting a few other drop in replacement controllers in the future including the QFR, the Rosewill RK9* series, and Filco Fullsize(may be the same as Rosewill).
Offline davkol
« Reply #8 on: Tue, 05 February 2013, 13:53:37 »
I guess Roccat Ryos should be programmable, but I'm not sure about release date. If you don't need mechanical switches, Cherry G86 are quite common.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #9 on: Tue, 05 February 2013, 14:00:50 »
Autohotkey is also an option, however your mappings will not be saved at the keyboard level, but rather the computer you are using. Could be a simple solution for what you might need though.
Offline sordna
« Reply #10 on: Tue, 05 February 2013, 14:04:01 »
The Kinesis Advantage as well the Comfort Keyboard System are programmable from the keyboard itself, no software or drivers needed.
Offline iri
« Reply #11 on: Tue, 05 February 2013, 14:19:38 »
pos, pos... which ones?
-Ray Bradbury
Offline davkol
« Reply #12 on: Tue, 05 February 2013, 14:32:08 »
Most if not all models by Tipro, Access-IS, Elcom,... Some Cherry keyboards as well (especially higher-end G86).
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #13 on: Tue, 05 February 2013, 15:54:11 »
In theory, any keyboard is programmable to a limited extent. The problem is that you have a fixed set of scancodes which are valid, a fixed set of memory, and potential layout issues. (e.g. impossible to create certain Function Layer combinations in matrix layouts without true dioded NKRO.)
Roccat Ryos is probably going to be your best bet, depending on how open the SDK is - 94 key layer and 2MB of addressable memory for layers. There was another keyboard - Korean IIRC - we were recently discussing that offers a high level of programmability but the name escapes me.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
