Author Topic: Cherry ML dampeners  (Read 3951 times)
Offline uzoc
Cherry ML dampeners
« on: Wed, 06 February 2013, 23:18:49 »
Anyone know of any Cherry ML dampeners? Or something that can be used for the purpose?
Offline Vintage
Re: Cherry ML dampeners
« Reply #1 on: Thu, 07 February 2013, 11:23:51 »
You mean like O-rings for cherry ML switches?
I thought that ML switches would be on the quieter side because they are a hybrid between mechanical and rubber?
CM QFR w/ MX Reds  | Logitech G900
Offline uzoc
« Reply #2 on: Thu, 07 February 2013, 12:34:52 »
Yes, O-rings like for MX switches.
They are not quieter (you still get that 'clack' typical of MX keycaps when they hit bottom).
ML have shorter travel (3mm compared to 4mm=MX). I think 1mm or 2mm would be perfect for me (I guess rubber travel distance).
Because of the rectangular stem of the switch AND the almost flat of bottom of the keycaps its difficult to think of something to buy, similar to O-rings.
Trying NOT TO FABRICATE (unless a pre-manufactured solution is impossible)...
Any ideas?
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #3 on: Thu, 07 February 2013, 12:54:41 »
Sheet of thin foam with cut-outs?
A Ghost From The Past
Offline uzoc
« Reply #4 on: Thu, 07 February 2013, 14:22:04 »
Yes, actually double sided tape comes to mind, but one sided; if not, it will stick to the bottom.
I did see someone/some company selling this foam/tape but for MX switches.
Anybody remember what company/link?
Offline uzoc
« Reply #5 on: Thu, 07 February 2013, 19:20:49 »
OK, found them for MX: http://elitekeyboards.com/products.php?sub=access,slpads&pid=sl120_cf
Not for ML. Anybody knows where to get this foam?
Offline sth
  • 2 girls 1 cuprubber
« Reply #6 on: Thu, 07 February 2013, 19:53:06 »
I have what I'm guessing is some sort of 'industrial' ML that came with a thin rubber sheet between the keys and 'plate'. it felt awful so i threw it away.
