Author Topic: It's getting to me  (Read 1755 times)
Offline uJalled
  • Shrimp cracker enthusiast
It's getting to me
« on: Sat, 09 February 2013, 18:12:30 »
I thought I would never be insane enough to do it, but I'm gonna do it. I've decided to spray paint my Filco TKL. Could anyone redirect me to a good thread on spray painting cases and such? That would be awesome. The main reason I'm not deciding on which one to use myself is because I have no experience in such matters.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
Re: It's getting to me
« Reply #1 on: Sat, 09 February 2013, 20:22:38 »
What color?
Quote from: Samuel Adams
« Reply #2 on: Sat, 09 February 2013, 20:23:42 »
I think the search may yeild results. My only tips would be a spray paint made for plastic, and some sanding to rough up the case beforehand.
« Reply #3 on: Sat, 09 February 2013, 20:47:32 »
I've had the crazy idea of taking one of my keyboard housings to a good auto paint shop for a professional paint job. I wonder how much they would charge?
Here's the "white widow" thread:
http://geekhack.org/index.php?topic=16360.0
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sat, 09 February 2013, 20:59:45 »
For doing it yourself I will once again recommend vinyl dyes as the top choice. It is easy to get a good end result with minimal effort as it requires no sanding, nothing more than starting with a clean case body. I did some mice with it and after almost 3 years it is now only starting to wear thin. Keep in mind I have contact with the mouse for many hours every day, much more than a typical person would with keyboard casebody so it should last even longer theoretically. The major con to them is they tend to have a pretty limited color selection.
Second choice with similar pro is Krylon Fusion, though it does not seem to be quite as resilient to wear. It has a much larger color selection though.
Third option is professional. Some body/chopper shop might be warm to the idea of doing such small pieces after hours for a reasonable price. But it all depends so you might need to make numerous calls to find one. Other similar option if you have any in your area might be some of airbrushing shops.
« Last Edit: Sat, 09 February 2013, 21:01:29 by lysol »
Offline uJalled
« Reply #5 on: Sat, 09 February 2013, 21:19:14 »
I'm thinking blue case, and my white PBT caps, so vinyl dye would work great. One of these right?
http://www.amazon.com/VHT-SP950-Vinyl-Dark-Satin/dp/B000CPAVKW/ref=sr_1_6?ie=UTF8&qid=1360466325&sr=8-6&keywords=vinyl+dye
