Author Topic: HHKB and Realforce Keycap Height  (Read 3370 times)
Offline flacman
  • I have oneness with cup rubber
« on: Tue, 12 February 2013, 22:01:28 »
I just received a yellow Enter key from one of the members on gh and after sticking it on - it's of a slightly higher profile than the HHKB Return key making a transition from " to 'return' slightly weird.
Are all coloured (red/WASD cluster from EK) keycaps that fit HHKB designed for Realforce profile?
It'd be good to know before I splash out on some more keys only to have an uneven keyboard surface.
HHKB Pro 2 | Realforce 87U 55g | Realforce RGB | RAMA Kara
Offline sth
  • 2 girls 1 cuprubber
Re: HHKB and Realforce Keycap Height
« Reply #1 on: Tue, 12 February 2013, 22:04:02 »
i'm looking at my yellow enter and OEM hhkb enter and they look identical. i think maybe you got a backspace key instead of an enter key?
Offline flacman
« Reply #2 on: Tue, 12 February 2013, 23:13:18 »
Nope, there's a laser etched "Enter <-" label on it. It's about 1-2mm taller than the other hhkb keys. Comparing my enter key and the RF one - the former is definitely shorter.
