Author Topic: Cherry ML keycaps  (Read 4267 times)
Offline Lorem-Ipsum
  • (╯°□°)╯︵ɯnsdı-ɯǝɹoן
    • mattwall.co.uk/
Cherry ML keycaps
« on: Wed, 13 February 2013, 07:12:14 »
I've just purchased an ML switched board for use with my laptop.
I've had a look around for custom ML keycaps and have come up with nothing.
Is it possible to get custom ML keycaps at a reasonable price? Do group buys for these pop up occasionally?
Currently Using: Corsair K65 (MX Reds)
Own: IBM Model M | Logitech Illuminated | Filco Majestouch 2 (MX Blues) [Waiting for Toxic] | Cherry D-91275
OS: ArchLinux | Herbstluftwm | Termite | Zsh
"In a world without walls and fences, who needs windows and gates?"
Re: Cherry ML keycaps
« Reply #1 on: Wed, 13 February 2013, 07:37:35 »
Is ML really better than your laptop's scissor switches?
Offline SmallFry
« Reply #2 on: Wed, 13 February 2013, 07:43:01 »
I believe that Signature Plastics may have stock of a few ML keycaps, but don't hold your breath considering how seldom people use them. ML keycaps, by default, are typically PBT-thus people seldom replace them. Sth can correct me if I am wrong.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Wed, 13 February 2013, 16:41:57 »
You might look for some old Tandberg boards, they have some wicked spherical style
Offline SmallFry
« Reply #4 on: Wed, 13 February 2013, 16:43:42 »
Huh. Nifty!
« Reply #5 on: Wed, 13 February 2013, 16:45:15 »
Oooo, those caps look sick.
Offline sth
  • 2 girls 1 cuprubber
« Reply #6 on: Wed, 13 February 2013, 16:48:25 »
There really isn't much out there.. lysol will probably always know more about them than me but here's the basics:
you can get lasered, pad printed and dyesubbed keys. if you want the PBT dyesubs you need to look for model # 410xSPAUS where x is some number. Mine is a 4101SPAUS, not sure if they did other dyesubs with a different number.
You can find the switch+PCB assembly alone on ebay here and there -- it has no controller but you can either drop the whole board in and solder the connector in or just swap the keycaps -- probably easier. also keep in mind that newer ML boards have different bottom rows (win/menu keys and a smaller spacebar).
i've been trying to get people to make custom ML caps (mostly transformers but i did once PM mr. clack... no response :)) ). been thinking about doing some molding this summer with JesusWasAZombie so we'll see :)
Lys- er, Ivan :P Do you have any ML boards with that foam dampener? How does it feel?
« Reply #7 on: Wed, 13 February 2013, 16:55:29 »
I don't own ML anything actually. I'm not even sure if I have ever touched one.
