Author Topic: Buying PCB mount cherry stabilizers?  (Read 3132 times)
Offline BoxWithADot
« on: Fri, 15 February 2013, 20:04:51 »
Is there anywhere I can buy them? Or should I just post in the classifieds. I need a regular spacebar stabilizer (6.25x I think?)
« Last Edit: Fri, 15 February 2013, 20:11:01 by BoxWithADot »
Offline SmallFry
Re: Buying PCB mount cherry stabilizers?
« Reply #1 on: Fri, 15 February 2013, 20:26:18 »
Mouser may have stock of the plastic parts, you'll need to bend a wire, I think.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Fri, 15 February 2013, 21:20:51 »
Mouser does not stock the PCB mount.  OLC also has not had stock for some time.  I have placed an order with them that should be coming in mid April.  Depending on what goes on between now and then I should have complete sets to sell.
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #3 on: Fri, 15 February 2013, 21:21:25 »
^Stabilizer whiz himself speaks! :D
Offline jabar
« Reply #4 on: Fri, 15 February 2013, 21:38:03 »
http://deskthority.net/marketplace-f11/cherry-mx-taking-pre-orders-t2760.html
DT has this group buy, but there is a significant delay til the next order.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline SmallFry
« Reply #5 on: Fri, 15 February 2013, 21:42:35 »
He was asking for stabilizers, unless I missed something in the DT post.
Offline BoxWithADot
« Reply #6 on: Fri, 15 February 2013, 22:09:02 »
Ahh okay! Well if I can't snag some before then I suppose I'll be waiting a while then. Meh.
