Author Topic: wasd key set.  (Read 4075 times)
Offline evolyn
wasd key set.
« on: Mon, 18 February 2013, 03:25:59 »
maybe iam blind but i can't find the freakin button to put the choosen keys to blanks without engraves or lasers just the freakin color^^ and the support guy isn't answering <3 thx for help
Offline Tym
Re: wasd key set.
« Reply #1 on: Mon, 18 February 2013, 04:03:20 »
What site are you talking about? I am presuming http://www.wasdkeyboards.com but you haven't stated/posted in the correct section.
Offline evolyn
Re: wasd key set.
« Reply #2 on: Mon, 18 February 2013, 04:51:18 »
well ithought ur right. i get alot lost sry about that i can delete it later.
exactly ! but you know how to help me ?
wasd key set.
« Reply #3 on: Mon, 18 February 2013, 05:01:03 »
If you're looking on wasdkeyboards, and select the set you want. Where it says "laser method", the blank option will be there.
On some sets it'll say "print options", again, blank option would be in there.
Offline SOROBORU88
Re: wasd key set.
« Reply #4 on: Mon, 18 February 2013, 08:51:17 »
Is there a possibility to get a WASD set but cherry profiled? WASDK sets are higher. I salvaged a set of G81 keycaps and need a WASD set to fit them in height.
You know... sometimes in Terraria **** just get serious...
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: wasd key set.
« Reply #5 on: Mon, 18 February 2013, 11:29:23 »
Like these SORO?
Offline SOROBORU88
Re: wasd key set.
« Reply #6 on: Mon, 18 February 2013, 14:42:13 »
So damn beautiful :'( Thank you sir. Those will definitely be ordered ;)
Offline matt1986
Re: wasd key set.
« Reply #7 on: Tue, 19 February 2013, 17:27:24 »
Had the same problem, you need to load the 'blank' preset design first, then you can customise a blank board.
Offline noons
Re: wasd key set.
« Reply #8 on: Mon, 04 March 2013, 11:47:06 »
Random sort of off topic question.. WASD keys, are they PBT or ABS? I couldnt find any answers on their site.
Tofu65 Turquoise Tealios | Drop ALT LP Alpacas | 2X Leopold FC750R MX Brown | KUL MX Brown w/Cherry Stab MOD | Leopold FC660C BLANK | REALFORCE 87U 45G | HHKB PRO2 | Leopold TKL MX RED | Filco Majestouch 2 TKL MX BLUE
Re: wasd key set.
« Reply #9 on: Mon, 04 March 2013, 11:56:13 »
Cheap ABS caps.
Offline noons
Re: wasd key set.
« Reply #10 on: Mon, 04 March 2013, 12:01:15 »
Cheap ABS caps.
Kind of what I figured. Thanks!
Offline grodo.00
Re: wasd key set.
« Reply #11 on: Mon, 04 March 2013, 13:55:21 »
Cheap ABS caps.
I'm new to this so go easy on me. Why are they 'cheap'?
Re: wasd key set.
« Reply #12 on: Mon, 04 March 2013, 14:17:59 »
I feel they are much lower quality than some alternatives. They are the same as most keyboards stock keycap albeit in more colors. I just don't see the sense in paying more money to replace something of the same quality.
