Author Topic: [IC] Small lube station  (Read 24639 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Tue, 19 February 2013, 23:34:25 »
Is there any interest in a small lube station? I'm thinking 3 rows of 11 and bent so that the switches aren't touching the table. Or maybe even a 1 x 10...
I'm guessing the cost would be around $45 + shipping (for the bigger one), but that depends on quantity ordered.
Re: [IC] Small lube station
« Reply #1 on: Wed, 20 February 2013, 00:08:58 »
Interested
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Wed, 20 February 2013, 12:49:08 »
No one else?
Offline esoomenona
  • Gnillort?
« Reply #3 on: Wed, 20 February 2013, 12:53:32 »
:/ sorry, I would've been, but I snatched a full size one up out of someone's sale. I would think others would be though. C'mon people.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Wed, 20 February 2013, 12:59:14 »
Do you have a micrometer or caliper?
Offline esoomenona
  • Gnillort?
« Reply #5 on: Wed, 20 February 2013, 13:03:44 »
I actually can get my hands on both. Which would you prefer? And what are you thinking?
Offline esoomenona
  • Gnillort?
« Reply #6 on: Wed, 20 February 2013, 13:04:36 »
Shoot, nevermind. I'm thinking I can get my hands on them, but I'm in California right now and the station is in Texas. I will have to look at what is available when I get back home. It's a possibility though.
« Reply #7 on: Wed, 20 February 2013, 13:05:17 »
Measurements. Ahahahahaha. I crack myself up.
Offline SmallFry
« Reply #8 on: Wed, 20 February 2013, 13:05:53 »
Go to Harbor Freight or similar. They have them, typically open box, that you could quick measure for Beast.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #9 on: Wed, 20 February 2013, 13:06:44 »
Well, I could just use one of the phantom plate drawings I have and increase the size of the hole so it doesn't actually mount onto the plate or I could have you measure it and take the guess work out of it
Offline SmallFry
« Reply #10 on: Wed, 20 February 2013, 13:08:31 »
I use an old Phantom plate as a lube plate, it works well enough for me, though widening the holes isn't a bad idea.
« Reply #11 on: Wed, 20 February 2013, 13:08:47 »
You also need the little diamonds (45 deg rotated squares) to sit the stems in
Offline SmallFry
« Reply #12 on: Wed, 20 February 2013, 13:10:22 »
I put mine in ziploc containers or into the switch itself right away. Just my .02 however.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Wed, 20 February 2013, 13:10:41 »
I find that if I mount a switch, unmount it, and remount it in another plate, the switch because a lot looser or it looses the tabs on the switch that hold it to the bottom of the plate. I don't really think this matters too much when it's all soldered up but I'd rather not do that.
For sure, I'm sure it would make it a lot easier than holding stems with a tweezers lubing the sliders
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #14 on: Wed, 20 February 2013, 13:16:06 »
I could be interested
Offline esoomenona
  • Gnillort?
« Reply #15 on: Wed, 20 February 2013, 13:16:20 »
I will make an effort to measure things when I return home.
Offline RickyJ
« Reply #16 on: Wed, 20 February 2013, 15:52:26 »
I'd be interested in a small/medium one, 3x10 or so would be a good manageable size. :)
If you made 1mm cutouts for the plate retention tabs, that'd be perfect too.
« Last Edit: Wed, 20 February 2013, 15:53:58 by RickyJ »
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #17 on: Wed, 20 February 2013, 17:43:00 »
Very interested!  :p
Offline Caaaarrrt
« Reply #18 on: Wed, 20 February 2013, 18:08:23 »
I might be interested, depending on price and shipping to Australia. Well the shipping is the biggest problem, might not be worth it if it doubles the cost.
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
Offline The_Beast
  • I like wood ಠ_๏
« Reply #19 on: Wed, 20 February 2013, 19:09:30 »
A little bird told me that he has a dwg for a lube station, I'll just have to modify it and we should be good.
So esoomenona if you could get measurements that would be great, if not, don't worry about it ^___^
Offline Atlas
« Reply #20 on: Wed, 20 February 2013, 19:22:46 »
I would be interested in this
Offline AKIMbO
  • HHKBro
« Reply #21 on: Wed, 20 February 2013, 19:43:47 »
Interested too.
| KBD75 (box reds)
Offline Gupgup
« Reply #22 on: Wed, 20 February 2013, 22:01:40 »
Veryyy interested!
Offline WhiteFireDragon
    • youtube
« Reply #23 on: Thu, 21 February 2013, 01:37:23 »
This should be super easy to just design, you don't need the original Korean dwg file for that. I can probably draw one from scratch in ~45min. The switch hole needs to be greater than 0.580" but less than 0.614" if you want the switches to sit in the hole without locking. 0.595" length and 0.570" width are good numbers to have the switches sit in there just loose enough so it doesn't lock.
When you mount the switches on, push in the plastic locking tabs as you put the switches in the hole instead of letting the plate auto-forcing it in. That way the plastic clips won't wear out or deform and become loose.
    • youtube
« Reply #24 on: Thu, 21 February 2013, 02:38:07 »
Mini station with staggered hole spacing. This would probably be the size I'd want so it doesn't take up tons of space.
« Reply #25 on: Thu, 21 February 2013, 06:15:15 »
^ I'll take one of those, please. :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #26 on: Thu, 21 February 2013, 15:30:12 »
Which layout do you guys like more?
I like this one a bit more:
2nd:
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #27 on: Thu, 21 February 2013, 15:41:56 »
I like the first one as well! Will it drive up the cost if there's a dedicated space to hold springs or brush/oil/grease? :D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #28 on: Thu, 21 February 2013, 15:43:55 »
I didn't think of that, I can put it on one of the sides so it doesn't need to be bent funny like the original stations. What is the hold dia.?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #29 on: Thu, 21 February 2013, 15:55:47 »
I'll confess my suggestion wasn't original, I saw it on here first http://www.kbdmania.net/xe/index.php?mid=photo&page=15&document_srl=5942678
I'm not 100% sure on what the sizes will be
Offline The_Beast
  • I like wood ಠ_๏
« Reply #30 on: Thu, 21 February 2013, 15:58:12 »
Ohhh, I like the hole + slot to hold the stem instead
Brb, gotta make revisions :P
Offline TheQsanity
  • SmallFry Lovin'
« Reply #31 on: Thu, 21 February 2013, 19:12:47 »
Maybe just the smaller one for the cost.
SmallFry! <3
Offline alixinhzai
« Reply #32 on: Sat, 23 February 2013, 07:28:25 »
I like it :) but scare on shipping fee :P
Offline cancelx
« Reply #33 on: Sun, 24 February 2013, 19:34:57 »
I might be up for a small one, but it depends on the cost
Model M SSK - WASD V1 - CM Storm QFR - Ducky Year of the Rabbit - Realforce 87U - WASD V2 - K-Type
Offline Gupgup
« Reply #34 on: Wed, 27 February 2013, 11:05:38 »
On another lubing note, when people are lubing their clicky switches what lube do you use?
Because when I've tried and lubed my blues the sound isn't very uniform. I use a thick grease though, does anyone have a lighter oil based lube to recommend?
P.S. I couldn't be more interested in this lube station :)
Offline RickyJ
« Reply #35 on: Wed, 27 February 2013, 14:11:12 »
No lube on clicky stems and slider guides in the housing, only a bit in the ends of the springs to dampen ringing. My Poker came used and had light oil in the clicky stems, and the noise and feel was completely inconsistent. Had to disassemble the stems and clean them all.
Offline Gupgup
« Reply #36 on: Wed, 27 February 2013, 15:12:11 »
When you say end do you mean the bottom or top?
Offline RickyJ
« Reply #37 on: Wed, 27 February 2013, 18:16:41 »
Both, but just a light touch.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #38 on: Sat, 02 March 2013, 00:46:04 »
suddenly interested. need a damn switch tool too.....
Offline esoomenona
  • Gnillort?
« Reply #39 on: Tue, 05 March 2013, 10:13:13 »
Well now that we're adding new ideas and things, I am interested. Also, sorry I haven't been able to get those measurements. No time to rest before I had to travel again...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #40 on: Wed, 13 March 2013, 15:29:11 »
and off to the cutter she goes. I'm doing a single one to check measurements but then a GB or a FS thread will be up!
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #41 on: Wed, 13 March 2013, 15:30:25 »
Very cool, hope 1 proto is all you'll need :)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: [IC] Small lube station
« Reply #42 on: Wed, 13 March 2013, 15:54:52 »
I want one now!!!!!
-Enzo Ferrari
« Reply #43 on: Wed, 13 March 2013, 15:59:26 »
Me too! I need this ASAP. :D
Offline esoomenona
  • Gnillort?
« Reply #44 on: Wed, 13 March 2013, 16:09:05 »
I'm in for one. Will this come with more switch tools? :D
Offline mashby
    • Mashby
« Reply #45 on: Wed, 13 March 2013, 17:31:33 »
^^^ this  ^^^
Please Mr. Santa-Beast! Can we have some tools too!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #46 on: Wed, 13 March 2013, 19:55:33 »
^^^ this  ^^^
Yup, I was planning a mod kit. Switch tools + lube station + maybe something else
Offline esoomenona
  • Gnillort?
« Reply #47 on: Wed, 13 March 2013, 20:03:09 »
More something elses!
Offline Glod
    • YouTube Channel
« Reply #48 on: Wed, 13 March 2013, 21:27:58 »
^^^ this  ^^^
oh awesome
Offline pasph
« Reply #49 on: Thu, 14 March 2013, 04:31:59 »
^^^ this  ^^^
This is really interesting!
