Author Topic: Thick PBT Caps  (Read 5359 times)
Offline cobraj
Thick PBT Caps
« on: Wed, 20 February 2013, 00:46:52 »
Hey guys.
I was just wondering if anyone knew if the following existed: Thick Blank Black PBT Caps.
So if they do exist, does anyone know where I can get some of these?
Thanks in advance guys.
Offline sherryton
  • Kībōdo
    • Originative
Re: Thick PBT Caps
« Reply #1 on: Wed, 20 February 2013, 01:08:34 »
Offline WhiteFireDragon
    • youtube
Re: Thick PBT Caps
« Reply #2 on: Wed, 20 February 2013, 02:11:25 »
Dude I've been looking for a set like this for 100 years. Thick, blank, PBT, cherry profile, and either black or charcoal dark grey.
Sherry, are these from GMK and they're PBT?
    • youtube
Re: Thick PBT Caps
« Reply #3 on: Wed, 20 February 2013, 02:13:57 »
@ cobraj - the exact combination you're looking for doesn't exist (yet?). You'll have to compromise on the color, material, or thickness.
Thick PBT Caps
« Reply #4 on: Wed, 20 February 2013, 02:18:32 »
I know another person looking for these, heck I may even want a set, bet these would be sick. Get on it sherry! :D
Offline Loligagger
Re: Thick PBT Caps
« Reply #5 on: Wed, 20 February 2013, 02:22:31 »
This would be my ideal set of caps. I'd buy a set or two in a heartbeat.
Offline cobraj
Re: Thick PBT Caps
« Reply #6 on: Wed, 20 February 2013, 05:35:52 »
Yeah. I can't believe no one has made these yet :O
Always a sad day when you have to compromise for your keyboard haha :P.
DO IT PLEASE =D
Definitely. And because it's black, might be cheaper to produce?
Offline kboardvintage
Re: Thick PBT Caps
« Reply #7 on: Wed, 20 February 2013, 08:26:46 »
Offline Jocelyn
  • 조셀린
Re: Re: Thick PBT Caps
« Reply #8 on: Wed, 20 February 2013, 08:47:33 »
Perhaps soon...
http://geekhack.org/index.php?topic=40081.0
what do u mean??
Yes, I saw "dark grey" mentioned once in that thread and the caps mentioned are barely regular gray.
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
Re: Thick PBT Caps
« Reply #9 on: Wed, 20 February 2013, 09:35:46 »
what about those blank cherry POM caps?
Offline Jocelyn
  • 조셀린
« Reply #10 on: Wed, 20 February 2013, 09:39:32 »
Link?
« Last Edit: Wed, 20 February 2013, 09:41:49 by Jocelyn »
Offline dante
« Reply #11 on: Wed, 20 February 2013, 09:42:51 »
« Last Edit: Wed, 20 February 2013, 16:48:44 by dante »
Offline tauburn
Re: Thick PBT Caps
« Reply #12 on: Wed, 20 February 2013, 11:29:53 »
what is the benefit of thick caps?
Offline alaricljs
  • I be WOT'ing all day...
Re: Thick PBT Caps
« Reply #13 on: Wed, 20 February 2013, 11:33:54 »
Mostly they sound different.  There is possibility that they effect the feel of a switch due to the higher mass, but honestly the mass differential is bound to be imperceptible by human fingers.
Filco w/ Imsto thick PBT
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Thick PBT Caps
« Reply #14 on: Wed, 20 February 2013, 12:04:23 »
I can tell the difference between old thicker Cherry PBT and the really light and thin current production. It is pretty subtly though, barely noticable on linear but a little more evident on clicky type. To me the biggest advantage to these thick is that they are Cherry profile which I do find much more pleasant to type on personally. While it dosen't actually change the travel distance it seems like it is less since they are not so tall and I find there is less side to side wobble which is another good thing.
