Author Topic: [WTS] Poker acrylic case [Shipping Done]  (Read 188080 times)
Offline MKULTRA
  • Trade Count: (0)
  • telling it how it is
Re: [WTS] Poker acrylic case [Shipping]
« Reply #550 on: Tue, 30 July 2013, 11:27:18 »
The suspense is killing me
Offline blueasjim
  • Trade Count: (0)
« Reply #551 on: Tue, 30 July 2013, 12:42:54 »
Link http://imgur.com/a/j1SCq to potato picks I took. Better ones eventually.
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
Offline Glod
  • Trade Count: (0)
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #552 on: Tue, 30 July 2013, 15:15:02 »
i did get mine saturday and i have to say i have mixed feelings about it
from the top down it looks awesome but there are some quality issues: the way the frame is glued together (the top and bottom layers), is sloppy and has obvious quality control problems.
because i have a clear bottom you can see the the glue isn't even and it looks like trapped bubbles, there are fibers that were trapped in it also almost looking like hairs and ,some of the glue got on the frame/sides and it wont come off and some got on the exposed part where it doesn't come with a protective sheet on it and it looks like scratches.
its so bad i think i am going to cover the bottom with vinyl like i did my ergodox to cover up these smudges and bubbles and fibers.
ergodox example: http://www.flickr.com/photos/panicfx/9161500795/in/photostream/
If i didn't get clear then i think i would be satisfied, i would actually get another one of these cases for a GH60 if there is a round 2, but not in clear.
these are potato pics but i plan on taking better pics during a build log of my poker mod.
ill be happier once i put the poker together.
Offline turtle
  • Trade Count: (0)
« Reply #553 on: Tue, 30 July 2013, 15:56:27 »
I want my case :( isn't all black and bottom red common?! Sigh
  • Trade Count: (0)
« Reply #554 on: Tue, 30 July 2013, 16:41:18 »
I got white and black colors...super common...
And of course I didn't get any shipping notice so I don't even know if it's been shipped...
Offline blueasjim
  • Trade Count: (0)
« Reply #555 on: Tue, 30 July 2013, 19:45:41 »
I'm sure it has been shipped. I didn't get a shipping notice either and received mine. So be patient, I'm sure it'll be there asap :D
Offline guilleguillaume
  • Trade Count: (0)
« Reply #556 on: Wed, 31 July 2013, 07:45:54 »
Received mine today  ;D
No pictures yet though but I like a lot the case. It's light but it feels really solid. Still thinking about adding the acrylic plate or not when I mount the Poker inside.
Offline duc_nckt
  • Trade Count: (0)
« Reply #557 on: Wed, 31 July 2013, 09:51:46 »
Beautiful noodles box
ali =))
Offline Glod
  • Trade Count: (0)
    • YouTube Channel
  • Trade Count: (0)
« Reply #559 on: Thu, 01 August 2013, 23:01:41 »
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #560 on: Fri, 02 August 2013, 00:33:49 »
So I ordered around April 8th and still don't know if my case has shipped......
Offline turtle
  • Trade Count: (0)
« Reply #561 on: Fri, 02 August 2013, 10:12:11 »
I emailed him regarding my case and It seems like he have sent all orders out. He told me to wait 2-3 weeks. If it doesn't arrive then contact him and he'll go to his local post office to check on status
Offline turtle
  • Trade Count: (0)
« Reply #562 on: Fri, 02 August 2013, 10:12:53 »
And my case still hasn't arrive yet if it makes you feel any better :(
  • Trade Count: (0)
« Reply #563 on: Fri, 02 August 2013, 10:19:58 »
When did you contact him?  I'm wondering what date + 2-3 weeks to be looking at.
Offline komar007
  • Trade Count: (0)
    • komar's blog
« Reply #564 on: Fri, 02 August 2013, 10:33:19 »
Neither has mine. Still waiting.
Offline turtle
  • Trade Count: (0)
« Reply #565 on: Fri, 02 August 2013, 12:06:17 »
I asked what was the ship date so I know what 2-3 weeks frame I should be receiving it but he never responded =X
  • Trade Count: (0)
« Reply #566 on: Fri, 02 August 2013, 12:21:25 »
Oh gosh, haha.  Well then.  I will wait and hope for the best.
Offline MKULTRA
  • Trade Count: (0)
« Reply #567 on: Fri, 02 August 2013, 12:27:31 »
I wish I just had a tracking number...
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #568 on: Fri, 02 August 2013, 17:00:55 »
My case arrived today, panic mode concluded. Now I just need some GH60 goodness to put inside. I also didn't expect any layers of the acrylic to be glued together, I figured the screws would do all the work holding it together. Mine came with a second plate that was the exact same as an entire plate layer instead of the smaller plate the fits into the grooves inside. I'm not sure that I have any use for it, but one small corner piece that had a cut out for the USB cable to go was broken.
What kind of glue is good to reattach a small piece of acrylic?
Offline Glod
  • Trade Count: (0)
    • YouTube Channel
« Reply #569 on: Fri, 02 August 2013, 17:15:27 »
yeah i mentioned earlier  when i showed pictures of how crappy the glue is, nobody commented on that, if you have a clear bottom it looks like crap due to the glue.
you are supposed to use BOTH plates like a sandwich, you don't just use one because the P:oker or GH60 will sit too low and not work, the acrylic plates are flush onto the top of the pcbs there isnt any space between the plate and the pcb and it works fine and should work fine with the GH60. also without the double plates it would be too flexible if it did fit (which it doesn't).
edit ^ did you not get the smaller plate that goes in the groves? there is a thin plate and then a second plate that is a full layer, it wont work if you just got two of one of the kinds of plates, it would be too thin or too thick.
« Last Edit: Fri, 02 August 2013, 17:20:48 by Glod »
Offline elton5354
  • Trade Count: (0)
« Reply #570 on: Fri, 02 August 2013, 18:51:23 »
Finally received mine today. Thanks Ali!
I also have 2 plates.  I can't use both plates because the switch holes don't align. I think one is for the Poker and one is for HHKB layout.
Nevermind....both plates do fit...lol
« Last Edit: Fri, 02 August 2013, 19:30:14 by elton5354 »
Offline gnubag
  • Trade Count: (0)
« Reply #571 on: Fri, 02 August 2013, 20:45:21 »
still haven't heard or seen anything of my case. :|
I really hoped for a tracking number, but nope.
Offline Turkishrambo
  • Trade Count: (0)
« Reply #572 on: Fri, 02 August 2013, 20:46:39 »
relax. And no u wont get one.
Offline gnubag
  • Trade Count: (0)
« Reply #573 on: Sat, 03 August 2013, 01:45:13 »
well, i know. still sad.
Offline Kayliss
  • Trade Count: (0)
Re: [WTS] Poker acrylic case [Shipping Done]
« Reply #574 on: Mon, 05 August 2013, 20:12:56 »
Mine arrived safely today, thanks Alixinhzai.  :D
Offline Lumune
  • Trade Count: (0)
« Reply #575 on: Mon, 05 August 2013, 20:42:33 »
Got mine as well, thanks.
Offline MKULTRA
  • Trade Count: (0)
« Reply #576 on: Mon, 05 August 2013, 21:51:51 »
Shipping done hmmmmmm so mine should arrive any day now.  Very disappointed with the lack of communication here.  Haven't heard from ali in quite awhile.
Offline komar007
  • Trade Count: (0)
    • komar's blog
« Reply #577 on: Mon, 12 August 2013, 05:27:03 »
Mine came today. Thanks alixinhzai!
It's a shame I won't be home until Wednesday:/, but it's waiting there...
Offline turtle
  • Trade Count: (0)
« Reply #578 on: Mon, 12 August 2013, 10:24:55 »
Still waiting for mine. Friday will be 3 weeks since mine been shipped. Hopefully mine will arrive soon.
Offline orlando
  • Trade Count: (0)
« Reply #579 on: Tue, 13 August 2013, 12:03:56 »
Received mine yesterday.
I do have to say ordering a clear top / bottom was a horrible idea. The glue was applied very poorly, as others have stated, which ruins the entire look of the case.
Will be forced to modify it since the glue has essentially rendered it useless.
Offline ForestFunK
  • Trade Count: (0)
« Reply #580 on: Wed, 14 August 2013, 11:06:42 »
Got my case today and it looks great! Thanks ali!
Qpad-MK-50 | ReɅlforce 88u
Offline turtle
  • Trade Count: (0)
« Reply #581 on: Wed, 14 August 2013, 16:39:20 »
Case received. Now gotta figure out how to piece this together. Thanks Ali!
Offline Noko
  • jolonarr: a tough dude who takes no esses!
  • Trade Count: (0)
    • Noko's Leatherworks
« Reply #582 on: Wed, 14 August 2013, 17:32:39 »
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Online Halverson
  • Trade Count: (3)
« Reply #583 on: Wed, 14 August 2013, 17:34:38 »
Northern Ontario, Canada
Still waiting
  • Trade Count: (0)
« Reply #584 on: Wed, 14 August 2013, 19:35:43 »
Still waiting
I predict it will be soon.
Offline turtle
  • Trade Count: (0)
« Reply #585 on: Fri, 16 August 2013, 10:22:28 »
Post some pics up!
Offline Glod
  • Trade Count: (0)
    • YouTube Channel
« Reply #586 on: Fri, 16 August 2013, 13:07:35 »
yep the glue sucks as i stated before
im glad i didn't get a clear top, i used vinyl to cover the bottom
only those who got a clear top or bottom or both will notice this issue.
Post some pics up!
http://flic.kr/s/aHsjHdYkuH
Offline Noko
  • Trade Count: (0)
« Reply #587 on: Wed, 28 August 2013, 12:59:55 »
Anyone else still not get theirs yet? :(
« Last Edit: Wed, 28 August 2013, 13:03:25 by jolonnar »
Offline pasph
  • Trade Count: (0)
« Reply #588 on: Wed, 28 August 2013, 18:25:42 »
me
Offline pasph
  • Trade Count: (0)
« Reply #589 on: Thu, 29 August 2013, 05:09:22 »
alixinhzai has promptly let me know the tracking number and the case arrived in my town Yesterday.
Thank you alixinhzai!
Offline Glissant
  • Trade Count: (0)
« Reply #590 on: Thu, 29 August 2013, 16:51:04 »
I've got to say, I was positively surprised by the fact that the tool for the screws was included with the case. I actually needed that tool for my mx-mini too, so it was a double bonus for me.
Thanks again, alixinhzai!
Offline Noko
  • Trade Count: (0)
« Reply #591 on: Tue, 03 September 2013, 11:50:38 »
I finally got mine today as well.  I'm very happy with it (I got solid colours though).
Thanks again.
Offline pixel5
  • Trade Count: (0)
    • pixel5
« Reply #592 on: Tue, 03 September 2013, 16:12:40 »
Are there any of these left over?
Poker II
Quickfire Rapid
BUY MY CRAP
Offline domoaligato
  • Trade Count: (0)
« Reply #593 on: Tue, 03 September 2013, 16:34:02 »
I have one all black in poker layout if your interested please pm me.
Edit: sold a while ago.
« Last Edit: Mon, 09 December 2013, 13:02:41 by domoaligato »
Offline jinxedx84
  • Trade Count: (0)
« Reply #594 on: Thu, 28 November 2013, 12:24:09 »
If anyone has a blue one they dont need PM me i would love one!
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline blueasjim
  • Trade Count: (0)
« Reply #595 on: Mon, 02 December 2013, 10:06:30 »
I have a red for trade should anyone be interested.
