Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 3559422 times)
Offline Ludovician
« Reply #12350 on: Sat, 16 May 2015, 02:25:28 »
I have a question for any Novatouch owners: Have you ever had trouble putting on a replacement spacebar? I put my set of black blanks from Ivan's GB on my new Novatouch, but the spacebar doesn't seem to fit on properly. I've also tried two other PBT spacebars from different sets (one thick PBT cherry profile, one thin PBT OEM profile) and the stock DasKB spacebar. At this point, only the stock spacebar from the NT and the DasKB stock spacebar will fit.
Does anyone have any insight on why my other spacebars aren't working, or what I can do about it? Thanks.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline Zustiur
« Reply #12351 on: Sat, 16 May 2015, 03:19:51 »
I just ordered 3 teensy 2.0's and I'm pretty sure they'll come without the pre-installed riser pins that my existing teensy has. I got that one from massdrop in an ergodox kit.
What is the correct name for those pins?
I call them risers or standoffs, but if I have to buy some, I want to know what to look for.
Offline njbair
    • nickbair.net
« Reply #12352 on: Sat, 16 May 2015, 07:20:10 »
Why are Koreans so into keyboards as opposed to other countries in Asia? I noticed there are a lot of talk about Korean keyboard around here.
Because they can afford it.
South Korea, is one of the top 3 countries on Asia in terms of per capita GDP.
My boards:
« Reply #12353 on: Sat, 16 May 2015, 09:36:41 »
They are called "pins"
You order the Teensy "with pins" or "without pins" and the pins are an extra dollar or 2.
You can also buy strips of pins cut cut to length and install yourself, but it is probably pretty tight and fussy.
http://www.ebay.com/itm/40-Pin-Header-Pins-Strip-PCB-0-1-2-54mm-for-Arduino-Breadboard-UK-Seller-/301450955714?pt=LH_DefaultDomain_3&var=&hash=item462fe08bc2
« Last Edit: Sat, 16 May 2015, 09:40:36 by fohat.digs »
Citizens United violates the essence of what made America a great country in its political system. Now it’s just an oligarchy, with unlimited political bribery being the essence of getting the nominations for president or to elect the president.
So now we’ve just seen a complete subversion of our political system as a payoff to major contributors, who want and expect and sometimes get favors for themselves after the election’s over.”
- Jimmy Carter 2015
Offline njbair
    • nickbair.net
« Reply #12354 on: Sat, 16 May 2015, 09:50:28 »
Or "header pins" to be more specific. .100" or 2.54mm spacing for the Teensy.
My boards:
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #12355 on: Sat, 16 May 2015, 11:28:20 »
I'm planning to swap springs, add SIP sockets, sticker and thus lube my (brand new) Gateron Black switches.
But while I was taking apart the switches, I noticed that the stem came with some factory grease applied on them.
> How should I clean the stems before applying my own lube (GH thin formula = Krytox GPL 206/1506 mixture) ?
I don't have the ultra-sonic cleaner thing, nor any mysterious (but powerful) industrial detergent  ;D
« Last Edit: Sat, 16 May 2015, 11:30:31 by Lpwl »
« Reply #12356 on: Sat, 16 May 2015, 14:46:06 »
Microfiber cloth
Offline RavenII
« Reply #12357 on: Sat, 16 May 2015, 14:48:44 »
Dude, pay attention!
Offline Zukoi
  • ****posting at 90wpm
« Reply #12358 on: Sat, 16 May 2015, 17:26:12 »
Microfiber cloth
Some isopropyl alcohol soaked in doesn't hurt either.
Offline Lpwl
    • My O-ring Store
« Reply #12359 on: Sun, 17 May 2015, 06:28:35 »
Alright, thank you all !
« Reply #12360 on: Tue, 19 May 2015, 07:41:41 »
Anyone know SP 6u stem spacing? Not 6.25, real 6u.
« Reply #12361 on: Tue, 19 May 2015, 09:17:50 »
Haata and the Input Club would know. They designed one of their boards with 6u.
« Reply #12362 on: Tue, 19 May 2015, 09:20:13 »
That's the reason I need to know, I'm adding an infinity option to the CF case.
Offline Hzza
« Reply #12363 on: Tue, 19 May 2015, 10:07:54 »
« Reply #12364 on: Tue, 19 May 2015, 10:11:06 »
Pretty sure it's on there...
http://deskthority.net/wiki/Space_bar_dimensions
Unfortunately it's non-SP measurements though. Not sure if it's correct to assume that one of the 6u spacing there is the same as SP's.
Offline Hzza
« Reply #12365 on: Tue, 19 May 2015, 10:14:10 »
Oh balls, sorry, I was looking at the 6.25u ones.
No clue what SPs would be, I'm not sure I've got one to check...
Offline appleonama
  • Trollo en USA
« Reply #12366 on: Tue, 19 May 2015, 14:45:38 »
How do you use the DUCK 02D software to program a duck eagle keyboard
« Reply #12367 on: Tue, 19 May 2015, 14:48:36 »
I've never used that exact software but I'd assume it's like the other programs I've used. You build a layout you like then make a hex file. Then use Flip to push the hex file onto your board's chip.
Offline Spopepro
« Reply #12368 on: Tue, 19 May 2015, 14:58:52 »
I don't think you need atmel's FLIP, I think the program accesses the bootloader directly.  Make your layout, and hold down the caps lock key while plugging in the usb cable.  Then upload the firmware.
Note: I also have not used this particular software, but all the cool kids are using direct access loaders that mean you never have to get messy with a hex or eep file if you don't want to.
« Reply #12369 on: Tue, 19 May 2015, 15:00:59 »
That's super handy. Thanks for the heads up.
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #12370 on: Wed, 20 May 2015, 09:29:03 »
1x Winkey formats (like The Cheat), do they have a "special" (i.e. not 6.25x) spacebar?
Bottom Row Math
Ansi:
1.25 * 7 = 8.75
8.75 + 6.25 = 15 units on the bottom row
1x Winkey builds:
1.5 * 4 = 6
1 * 2 = 2
15 - 6 - 2 = 7x Spacebar?
« Last Edit: Wed, 20 May 2015, 09:45:21 by greath »
« Reply #12371 on: Wed, 20 May 2015, 09:53:29 »
I took those measurements from the SP 6u spacebar...
« Reply #12372 on: Wed, 20 May 2015, 09:54:41 »
Bottom Row Math
Ansi:
1.25 * 7 = 8.75
1x Winkey builds:
1.5 * 4 = 6
1 * 2 = 2
Yes.
1.5-1-1.5-7-1.5-1-1.5
Offline Photoelectric
« Reply #12373 on: Wed, 20 May 2015, 22:23:23 »
If anyone here can read Korean, would you mind checking this page for any references or links to KMAC Happy firmware / keymapping software?
http://kbdmod.com/product/detail.html?product_no=15&cate_no=1&display_group=11
Still looking for a working version :(
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12374 on: Thu, 21 May 2015, 20:06:33 »
What would one use to flash a 456gt controller?
« Reply #12375 on: Thu, 21 May 2015, 20:22:59 »
Would flip work?
« Reply #12376 on: Thu, 21 May 2015, 20:34:19 »
https://geekhack.org/index.php?topic=49647.5
Does this work?
Offline clacktalk
  • circa 2015
« Reply #12377 on: Thu, 21 May 2015, 20:34:36 »
I use the one acantha posted a while back. i'll scan the site once i'm home. are you looking for anything specific?
edit: i think anson posted
diary of a clacktalk
radio_killah: too much frank
Offline laden3
« Reply #12378 on: Fri, 22 May 2015, 05:10:30 »
Anybody knows where to obtain one 87% pcb that can be used in a lz board (lz-fe)?
If I am not mistaken, my options are sprit and gon but I am afraid that I might miss another source.
Thanks in advance.
I rrrove brrracks.
« Reply #12379 on: Fri, 22 May 2015, 07:17:43 »
Thanks in advance.
Why not contact LZ and get their PCB?
« Reply #12380 on: Fri, 22 May 2015, 13:45:17 »
Does this work?
No, it doesn't, already tried a while ago.
Yes, I've installed the mirrored software Acantha hosted, because the original files are no longer accessible, and the key mapper executable does not run on 2 different computers I've tried it with.  I just need to generate a modified layout hex file.  If yours still works, I'd PM with a request, if you don't mind.
Offline clacktalk
  • circa 2015
« Reply #12381 on: Fri, 22 May 2015, 13:57:03 »
Does this work?
yeah i can definitely send over a hexfile tonight. i used it this past week to try out a 1u backspace, so my programs are definitely functional
« Reply #12382 on: Fri, 22 May 2015, 14:40:10 »
That would be so great--I've been trying to get this working for weeks now.  Thanks, I'll send you a PM.
Offline pr0ximity
« Reply #12383 on: Fri, 22 May 2015, 17:39:29 »
I haven't quite sacked up and tried to flash my 356 Mini yet, but I've spoken to quite a few people about it and gathered a whole mess of software and firmware for it. Info always seems to be incredibly sketchy on programming OTD boards for whatever reason, but from what I gather it should be very similar if not the same for the Mini, DGE, 456GT, and 360 Corsa, so if you can find someone who has flashed one of those it might help.
The guy I spoke to who wrote a UI for 356 Mini layouts told me I'd need an AVR ISP Programmer and you can load the hex files onto the board with avrdude. The firmware hex can be generated via the version of ps2avr here: http://sourceforge.net/projects/ps2avr/ however you'll need to map the columns appropriately which again, I haven't done. Ditto on the fuse settings, should be similar to the other late-model 356 boards.
| Flickr | KMAC 1.2 | Koala | GSKT-00-Z | GSKT-00-AEK | GON NerD60 | Jane V2 CE | Whale | J80S | Ibis | Pro2 | Pro1 | 356mini | 356CL DGE | G80-5000 HAMDE | IBM 1390120 | IBM F AT | IBM F122 | IBM 3101 | Zenith Z-150
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12384 on: Fri, 22 May 2015, 17:44:35 »
Alright thanks, I'll look into that
Offline Rena
« Reply #12385 on: Sat, 23 May 2015, 01:02:58 »
https://www.massdrop.com/buy/vortex-backlit-doubleshot-pbt-keycaps
would these fit a ducky mini fine? kind of tempted to get them but I have no idea what I'd do with the extra caps from it
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #12386 on: Sat, 23 May 2015, 01:20:43 »
Yep. Those will fit.
Some of Ye ole  Keyboards -->
OTD Koala:  62g Old MX-Blacks   |   LZ-GH V2:  MX-?62g   |   KMAC2:   62g Tactile MX-Greys   |   LZ CLS s:   62g Vintage MX-Blacks   |   X60:   62g Vintage MX-Blacks   |   GON NerD 60:  62g Old MX-Clears   |   Filco MJ2 (Beige) TKL's:  62g MX-Clears  &   62g Vintage MX-Blacks   |   IBM '91 SSK
WTB/WTS/WTT ---->
Offline laden3
« Reply #12387 on: Sat, 23 May 2015, 02:24:01 »
Thanks in advance.
Don't like his pcb. The keymapper doesn't allow macro activation from 1 keypress.
I rrrove brrracks.
Offline asgeirtj
« Reply #12388 on: Sat, 23 May 2015, 07:13:31 »
How do I disassemble my pok3r case, I don't see any screws?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #12389 on: Sat, 23 May 2015, 08:53:43 »
Did you take ask the keycaps off and check under all the stickers? Poker X you could only see the screw heads after you took ask the caps off.
Offline azhdar
  • Praise the AZERTY god
  • 65% Enlightened
« Reply #12390 on: Sat, 23 May 2015, 09:46:06 »
you will find screw on the position of the standoffs underneath the keycaps.
Azerty Propagandiste
Offline asgeirtj
« Reply #12391 on: Sat, 23 May 2015, 10:05:40 »
I see, thx.
Another question: http://winkeyless.kr/product/b-87-ex-x2-pcb/
will this pcb work with ikbc 104 case and plate? (if I go standard layout)
« Reply #12392 on: Sat, 23 May 2015, 10:07:06 »
I've never heard of an ikbc case or plate. Could you link me?
Thanks in advance.
I was under the impression LZ cases on fit LZ PCBs. I thought I had heard that they made theirs unique to prevent drop ins like you're suggesting. I'm not 100% sure though.
Edit: My LZ expert says that most LZ stuff is going towards beastmask/monstermask PCBs so I think you're right in that you can drop in GON, sprit, or Winkeyless PCBs. And the b.87 or Beastmask PCBs should work. I think Monstermask and beastmask are the same PCBs but I could be mistaken.
« Last Edit: Sat, 23 May 2015, 11:05:20 by CPTBadAss »
Offline asgeirtj
« Reply #12393 on: Sat, 23 May 2015, 10:22:09 »
http://www.mechkb.com/vortex-ikbc-f-104-double-shot-pbt-mechanical-keyboard
« Reply #12394 on: Sat, 23 May 2015, 10:38:07 »
Got it. I've never seen that board or PCB in person so I'm not sure. You might want to contact winkeyless and ask them. I'm not very familiar with full size boards and their dimensions as there's been very few options for custom full sizes lately.
Offline Spopepro
« Reply #12395 on: Sat, 23 May 2015, 11:07:40 »
I see, thx.
I'm on my phone, so I don't have links and leave the google to you, but if you have the keyboard in question, GON provides a DXF of his PCB and winkeyless provides DWGs of his cases. You could download those and take measurements from the computer, or even print a layer on large paper and line it up to check.
Offline alienman82
« Reply #12396 on: Sun, 24 May 2015, 21:55:12 »
removed.
« Last Edit: Thu, 01 March 2018, 17:28:43 by alienman82 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #12397 on: Sun, 24 May 2015, 23:04:12 »
I saw on gonkeyboard works that his sample picture for the gonpad numpad has cherry keycaps with F13,F14,F15,F16 keycaps.  What cherry boards came with more than 12 F keys?
I don't know a full list but the G80-8113 has 12 F keys plus 12 remappable keys.
Offline Rena
« Reply #12398 on: Mon, 25 May 2015, 00:10:49 »
Offline BakaPhoenix
« Reply #12399 on: Mon, 25 May 2015, 09:20:52 »
What happens if i put a red 3mm led on my keyboard that normaly have white led?
AFAIK red led have lower tension from white led, so i'll burn the led? or something worse?
