Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5857241 times)
0 Members and 6 Guests are viewing this topic.
Offline 1swt2gs
  • DOGE
« Reply #13700 on: Sat, 07 November 2015, 22:48:46 »
Relatively speaking are all Bros equal?
As in, would a rustler or something from the Halloween sale be able to be traded with a Grumpkin, Lycan, Zombro be able to be traded 1:1 for a brobot or a reaper?
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline ideus
  • Björkö.
« Reply #13701 on: Sat, 07 November 2015, 22:52:11 »
Isn't this belong into one of the dedicated Bro threads / subforum?
Offline 1swt2gs
  • DOGE
« Reply #13702 on: Sat, 07 November 2015, 23:01:06 »
Sorry if I posted it in the wrong section! I figured I would post it here as it keycap related and a pretty straight forward question!
Offline Bomble
« Reply #13703 on: Sat, 07 November 2015, 23:05:01 »
Ugh, I couldn't find a good side by side but maybe this thread is helpful?
Yeah, understandably. Was kind of hoping against likelihood that someone would happen to have a set and a bro that matched with the purple really well. It's a good idea for me to look in that thread though, cheers!
Offline byker
  • Literally Canada
« Reply #13704 on: Sat, 07 November 2015, 23:09:28 »
Trades are generally determined by what each party wants, so those trades could definitely happen. Generally though, I find most people consider older caps more rare, and may not straight up trade one for a newer cap (although if they want one, they may). When it comes to artisan trades, as long as each side is happy, it was a good trade :)
Offline ideus
  • Björkö.
« Reply #13705 on: Sat, 07 November 2015, 23:26:30 »
Do not be sorry, you may have some answers here, it was just to comment that there are threads focus on Bro things, as this thread is in the keyboard subforum.
Offline 1swt2gs
  • DOGE
« Reply #13706 on: Sun, 08 November 2015, 00:22:21 »
Thanks for the answers! Looking to acquire my first Bro or reaper, and finally have something hopefully worth trading!
Offline VinnyCordeiro
« Reply #13707 on: Sun, 08 November 2015, 09:22:46 »
When designing custom keyboards, everyone uses a 16MHz crystal. Is there any technical problem to use crystals with different frequencies, like 12MHz or 20MHz? On the firmware side it is just a matter of changing the frequency on the makefile, but I don't know if there is any issue with USB communication.
Offline alienman82
« Reply #13708 on: Sun, 08 November 2015, 09:56:44 »
removed.
« Last Edit: Thu, 01 March 2018, 17:02:08 by alienman82 »
« Reply #13709 on: Sun, 08 November 2015, 10:22:38 »
Correct me if I'm wrong, but I believe it's because ATmel ic's are typically used which like to run at 16mhz.  Probably could use different frequencies, but the timing may be affected?
But that is precisely what I want to know. I already saw an old PlayStation-to-USB adapter project that used a 12MHz crystal, so I'm under the impression that it isn't an issue.
It seems that I will need to make an experiment to know that. Better use a through hole crystal.
Offline dante
« Reply #13710 on: Sun, 08 November 2015, 20:16:59 »
Does the Unicomp 103/104 (non Classic) use a metal backplate?  I haven't/don't want to open mine but I've heard either A) there is no backplate or B) there is one but it is very thin.
Assuming there is one - will this also have all the plastic rivets that will break in time?  If there isn't one - will there be anything to be concerned with 5+ years later?
« Reply #13711 on: Sun, 08 November 2015, 21:34:13 »
I opened up a Wildcats board because that's what I had laying out that's Unicomp. I don't have a 103 or 104. Yes there was a backplate. You can judge the thickness. Yes there are rivets. Looks like an M as far as I can tell. So everything you have to worry about with an M you'll have to worry about with the Unicomp board.
Don't bump your questions please.
Offline pabile
    • pabile online
« Reply #13712 on: Mon, 09 November 2015, 06:52:50 »
this is the back of din plugs i will be using for an external converter. are the pin assignments correct for model m?
I always refer to this: (remember this is the socket, not the plug)
thanks, fohat! my re-trace seem to match the DIN 45322 guide (see bottom plug; top is for my videcom)
Offline alienman82
« Reply #13713 on: Mon, 09 November 2015, 11:44:33 »
removed.
« Last Edit: Thu, 01 March 2018, 17:01:11 by alienman82 »
« Reply #13714 on: Mon, 09 November 2015, 13:24:50 »
How do I remove ink from abs keys?
Baby wipes, cleaning wipes, and isopropyl alcohol all have worked for me. I've spilled fountain pen ink on my boards more than I care to admit.
Offline alienman82
« Reply #13715 on: Mon, 09 November 2015, 13:48:21 »
removed.
« Last Edit: Thu, 01 March 2018, 17:01:07 by alienman82 »
« Reply #13716 on: Mon, 09 November 2015, 14:13:06 »
That makes two of us. :-[
Offline raymogi
« Reply #13717 on: Mon, 09 November 2015, 19:25:27 »
Is it possible to remap the F-row keys on the SSK to the media keys for OS X?
Please feed my addiction.
« Reply #13718 on: Mon, 09 November 2015, 19:52:31 »
I think if you throw a Teensy in it, you can.
Offline raymogi
« Reply #13719 on: Mon, 09 November 2015, 19:54:55 »
So no way to do it with the stock controller huh?
Thanks Cap!
« Reply #13720 on: Mon, 09 November 2015, 19:57:39 »
Thanks Cap!
No unfortunately I don't think you can do any remapping at all with stock M controllers. I'm 95% sure you'll need to mod it with a Teensy.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #13721 on: Mon, 09 November 2015, 21:36:33 »
Thanks Cap!
Or one of Phosphorglow's "Universal Model M Controllers"
http://phosphorglow.net/store/products/universal-model-m-usb-controller/
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #13722 on: Mon, 09 November 2015, 21:38:34 »
CommonCurt good catch man. I definitely forgot about that!
Offline raymogi
« Reply #13723 on: Mon, 09 November 2015, 21:44:21 »
Thanks Cap!
Yeah I'm getting that one so I can use custom USB cables too.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #13724 on: Mon, 09 November 2015, 22:03:50 »
Thanks Cap!
Got one in my SSk, and I love it  :thumb:
WTB/WTS/WTT ---->
Offline alienman82
« Reply #13725 on: Mon, 09 November 2015, 23:43:44 »
removed.
« Last Edit: Thu, 01 March 2018, 17:00:46 by alienman82 »
Offline heedpantsnow
  • Old enough to know better
« Reply #13726 on: Wed, 11 November 2015, 09:58:37 »
I'm shipping a keyboard to Singapore.  I have 2x of the ~9x13x2.5 inch USPS Priority boxes.  Can I stagger/nest them to fit the board, and send it using normal USPS First Class?  Or do I have to use Priority if I'm using Priority boxes?
I'm back.
Offline trees
  • I like bagels.
« Reply #13727 on: Wed, 11 November 2015, 10:01:35 »
They will not let you send priority boxes first class. You could wrap them in brown shipping paper, but that has the chance to fall off.
B.Face HHKB - B.mini - Black/Purple Custom
« Reply #13728 on: Wed, 11 November 2015, 10:26:30 »
OK thank you for the quick answer!
I'm back.
« Reply #13729 on: Wed, 11 November 2015, 10:33:13 »
You'll run the risk that if they see the priority mail box at all, you or the recipient will get slapped with the fee for trying to dodge paying. I don't know how likely that is but it is a risk.
Offline E3E
« Reply #13730 on: Wed, 11 November 2015, 10:59:59 »
Since I'm a cheap bum, I save a lot of the boxes for packages that I receive, so there's been a few times I've sent out international first class packages with a USPS priority mail box. That said, I did buy a label online for the correct postage, and it was a package pick up (just leaving a note to grab the package off the porch, safe neighborhood), which tbh, has a bit more leeway compared to dropping a package of at the PO.
As long as you buy the correct postage for the box, it should be fine.
« Last Edit: Wed, 11 November 2015, 11:01:30 by E3E »
« Reply #13731 on: Wed, 11 November 2015, 13:49:49 »
My Office Depot has a mailing center in the print area. They almost always have the game board boxes. It will be $78 but probably not much more than other postage (well, with the keyboards I use, anyway - little plastic ones may go in the $50 range).
- Oliver Willis 2026-08-01
Offline alienman82
« Reply #13732 on: Wed, 11 November 2015, 13:54:54 »
removed.
« Last Edit: Thu, 01 March 2018, 17:00:09 by alienman82 »
« Reply #13733 on: Wed, 11 November 2015, 14:00:03 »
Depending on size and weight you can easily get closer to $55 using your own box using priority international and definitely cheaper if the weight is low enough to go first class international using your own box. The last model m I shipped to the UK was ~$64 but I put quite a bit of other stuff in that box.
But as others have said I wouldn't even attempt to ship a probity box first class.
« Last Edit: Wed, 11 November 2015, 14:01:48 by SpAmRaY »
« Reply #13734 on: Wed, 11 November 2015, 14:26:40 »
I think I can find another box; my risk tolerance is not very high.
You are a braver man than me  :-*
I'm hoping I can get it cheaper/smaller than the ole board game box.
You could desolder the switches and remove caps and probably fit everything in a small flat rate box if the case and pcb aren't needed.
lol I don't think so bro
I think I will try to find my own box and do first class.  He's paying shipping, so I'll present him with the different options and let him decide.
If I he does decide to do priority, can I use the two priority boxes nested or do I have to use only one?
I'm back.
« Reply #13735 on: Wed, 11 November 2015, 14:45:08 »
So long as its sturdy and well put together it shouldn't matter. But I do agree with fohat the gameboard boxes are the way to go if you want to ship a large keyboard priority. The keyboard I sent that is on its way to you was sent in a gameboard box, so you could possibly re-use it if that is how you decide to go.
Offline Dernubenfrieken
« Reply #13736 on: Wed, 11 November 2015, 18:55:15 »
Whats a good source for USB cable wire? Preferably on amazon?
Also I'm a bit confused about paracord, is there any specific size or type I need to purchase for custom cables?
Offline E3E
« Reply #13737 on: Wed, 11 November 2015, 19:38:28 »
Monoprice cables are popular for using as bases for custom cables and I know of some pretty well know cable makers who use monoprice cables. :)
http://www.ebay.com/itm/160814471418
This is generally what you should look out for. I've used this stuff a few times. 550, Type III, though there are wider paracord types and then there's also techflex or PET plastic sleeving that is popular for doing double sleeved cables (usually over the top of paracord).
There's also a bunch of varieties of shrink tubing you can get. I like high ratio shrink tube like 3:1 or 4:1. At those ratios, you can just buy some 1/2" tube and it will hold snug against both the connector and cable without the need for additional shrink tubing.
« Last Edit: Wed, 11 November 2015, 19:40:44 by E3E »
Offline myotherteeshirt
« Reply #13738 on: Thu, 12 November 2015, 01:15:02 »
Hi there!
I recently opened a quickfire TK to install zealios switches as well as fix a broken trace - Everything worked perfectly, no chatter as reported by some people, no early actuation either.
Fast forward a week and now my keyboard is going crazy. Some keypresses don't register, and sometimes they appear after a 10 second delay, but only sporadically - so if i typed "the quick brown fox" it may show up as "tquuuuuuuukbfffffffff".
Any idea on what the problem may be or where i can start attempting to diagnose it?
« Reply #13739 on: Thu, 12 November 2015, 07:34:52 »
Hi there!
I'd get a multimeter and check all your soldering connections. Might have a cold soldering joint.
« Reply #13740 on: Thu, 12 November 2015, 08:33:43 »
I'm curious,  how would a cold solder joint affect all the keys on the board?
I'll def do the multimeter thing. Is there a resource somewhere where I can see a circuit diagram of how a keyboard is wired?
I assume the basic wiring is similar for most keyboards?
« Reply #13741 on: Thu, 12 November 2015, 09:29:48 »
The soldering might be throwing off how the matrix is being sensed or strobed. I don't know about a circuit diagram nor can I give you a definitive answer as to why your keyboard is chattering. I just know that I've had a similar issue and that's how I solved it.
I've also had the same issue and solved it by putting some drawer liner between the PCB and the bottom of the case. For some reason the PCB acted up when it touched the case.
Offline tofgerl
« Reply #13742 on: Thu, 12 November 2015, 10:59:16 »
Yeah, when just one thing is connected wrong it can give the weirdest errors.
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #13743 on: Thu, 12 November 2015, 12:12:34 »
Does GH have a section where people just post images of their builds?
[WTB] HHKB Black
« Reply #13744 on: Thu, 12 November 2015, 12:15:37 »
https://geekhack.org/index.php?board=113.0 - This is where a lot of pictures go in general.
https://geekhack.org/index.php?board=117.0 - A lot of build logs go in here.
« Reply #13745 on: Thu, 12 November 2015, 18:05:13 »
Ok. I'm pretty sure there were some joints that were less than acceptable, so i'll take a look at that again. I guess it makes sense that if it were set up in a matrix then one bad joint might mess with the signals. One more question though - if you had to put liner between your PCB and case - could it have been a static/grounding issue?
« Reply #13746 on: Thu, 12 November 2015, 18:06:06 »
I believe it was yes.
« Reply #13747 on: Thu, 12 November 2015, 20:06:07 »
Ah. well i may have covered the top of the screw hole with spray paint - the one that the ground wire is screwed on to. I guess thats something i should look into.
Offline edb5s
« Reply #13748 on: Fri, 13 November 2015, 07:44:58 »
So I found an interesting board on an auction site I frequent: http://www.shopgoodwill.com/auctions/Atari-1040ST-PC-Keyboard--Thomson-Monitor-Base-25610947.html
Anyone have any details about this board, specifically what switches it uses?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13749 on: Fri, 13 November 2015, 08:37:24 »
Dome
