Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5347460 times)
0 Members and 13 Guests are viewing this topic.
Offline enchong
« Reply #16950 on: Tue, 30 April 2024, 16:04:20 »
Not really sure tbh, probably the BKE tactile because I want it to be more tactile than the stock hhkb. I used to have a realforce ang I love how that feels. But I also like the hhkb layout.
 Enchong | HHKB Pro2 Blank, DES Silencing Ring #3, DES Domes Carrot 49g | HHKB Pro2 Stamped, DES Silencing Ring #2 | HHKB Hybrid Type-S Snow Blank
Offline _rubik
« Reply #16951 on: Tue, 30 April 2024, 18:01:28 »
I personally put the 56g bke tactile domes on my 87u (iirc). They feel ever so slightly heavier than the original 55g domes mostly because of the increased tactility. If I had to do it over again, I would have gone to the next lowest weight -- somewhere in the mid to high 40gs. It's all subjective, but the added tactility adds just enough resistance to the top of the force curve to make my brain think I'm typing on a heavier switch. Hope that helps
Offline erretter
    • My Merch Shop
« Reply #16952 on: Thu, 02 May 2024, 10:26:51 »
I F'd up the top housing of a soldered in switch (complicated to explain; please just take that info, as it is). The switch is still functioning, but wonky.
Q: Can I swap out the top housing of a switch from the top-side without desoldering it?
« Last Edit: Thu, 02 May 2024, 10:28:55 by erretter »
Offline _rubik
« Reply #16953 on: Thu, 02 May 2024, 12:24:28 »
Some plates have notches cut out on either side of the switch to allow the top housing clips bend outward. I haven't seen those in quite a few years though. If the plate is contacting the switch on all four sides, you're going to have to desolder. That said, it's a pretty simple operation and a great excuse to learn to solder. You got this!  :thumb:
Offline erretter
    • My Merch Shop
« Reply #16954 on: Thu, 02 May 2024, 17:05:09 »
Thank you! Didn't know about the plate specifics. But I have to say, I soldered the switches in by myself, with led free solder and desoldering this is a 50/50 chance damaging the PCB because it's almost impossible to get all the solder out.
Offline _rubik
« Reply #16955 on: Mon, 06 May 2024, 12:39:38 »
It's amazing how much of a difference quality solder makes. I usually go with a 63/37 flux core solder which has the advantage of being eutectic -- a single, lower melting point that avoid that "gooey, semi-fluid" solder state you find on some cheaper solders.
For desoldering, I'd recommend getting a good solder pump with a soft tip (hard plastic tips on solder pumps never seal well around the component, IMO). I went through so many cheap suckers before finding the "Engineer Solder Sucker" on Amazon. I always add an extra dab of leaded solder before sucking just to make sure everything's good and melted. It's also more mass for the sucker to grab onto, in my experience.
Offline erretter
    • My Merch Shop
« Reply #16956 on: Mon, 06 May 2024, 12:50:47 »
TY! I found that pump. Might give it a try or.... I use this wobbly switch to build the next board :-X
Offline jeffs
« Reply #16957 on: Thu, 27 June 2024, 13:10:21 »
What are good search terms for relatively recent information and opinions on ortholinear layouts keyboards, especially reduced size options?
The following did not seem to be very fruitful:
  • ortholinear
  • Planck
  • OLKB
  • 4x12
Edit: Other resources are also welcome.
« Last Edit: Thu, 27 June 2024, 16:57:33 by jeffs »
Offline 5443
« Reply #16958 on: Sun, 07 July 2024, 07:15:55 »
where can I buy keyboard O rings in Toronto, Canada?
something thin and soft, like 40A thin, for cherry MX brown switches
shipping from the US is outrageous! I was shocked at the prices, so there must be something cheaper locally, or at least shipped from Canada? (or perhaps shipped from China?)
« Reply #16959 on: Sun, 07 July 2024, 07:29:39 »
shipped from China?
Outbound international shipping from the US is notoriously expensive. It was always high, but in the last decade or 2 it has skyrocketed, even to our nearest friends.
Shipping from China is nearly free. If you can wait 3+ weeks you can get merchandise at a fraction of the price.
- Bill Roberts 2026-06-17
Offline 5443
« Reply #16960 on: Sun, 07 July 2024, 07:39:23 »
shipped from China?
i am fine with waiting when it comes to shipping from China. do you have any sites that i can go to so i can buy some 40A o rings?
« Reply #16962 on: Sun, 07 July 2024, 09:03:19 »
I am not really a Cherry guy. It has been at least a decade since I bought O-rings for my son's Filco, but those look pretty fat ....
But those are a start and it would not be a big loss if you don't like them. Thickness seems more important to me than hardness, but what do I know?
Offline 5443
« Reply #16963 on: Sun, 07 July 2024, 10:05:51 »
An unrelated question, but this forum does seem pretty slow? then where do all the mechanical keyboard people hang out now? I remember back in the old days, when elitekeyboards.com was around (like 10 years ago?), that geekhack was the place to find all things about mech keyboards
« Last Edit: Sun, 07 July 2024, 10:13:28 by 5443 »
Offline 5443
« Reply #16964 on: Mon, 08 July 2024, 07:31:40 »
ok, so i just ordered 130 1.5mm thick rings, no idea on the hardness (or softness) but i will see how they are when they get here.
I paid $2.56 cad for the set, much better than the rip off prices that the US sites are selling for
« Last Edit: Mon, 08 July 2024, 08:41:22 by 5443 »
Offline 5443
« Reply #16965 on: Wed, 17 July 2024, 17:18:01 »
Well I got the O rings today, 9 days shipping, pretty fast from across the ocean I must say, and you can't beat $2.56, sellers on this side of the planet were charging 6 x that amount of the same thing, I couldn't go through with that.
I tried them out on my Filco, I added them to the Home/End island cluster of 6 keys, from my initial tests those keys were like 20 % quieter and had like 20 % less key travel. I don't know if it is worth it, maybe I should try it on the letter keys before jumping to conclusions. What are you guy's opinions when it comes to O rings on Cherry switches?
And why the hell is this forum so dead? Back in the day it used to be the place to go for all things mechanical keyboards. Nowadays I have to go to Mechanical Keyboard reddit if I don't want to talk to a brick wall here.
« Last Edit: Wed, 17 July 2024, 17:42:34 by 5443 »
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #16966 on: Thu, 18 July 2024, 00:32:30 »
Sorry missed your earlier comment. When it comes to o rings, it's mainly just a preference thing, I personally don't like it though. I just really like full travel when it comes to my switches. But it's pretty easy to add and remove so it's not a big commitment.
Also the hobby has become way less centralized, a lot of the community is now on the many MANY discords, would like to see more people here but discord is definitely a lot more of a convenient place when it comes to the hobby, so it's understandable why people don't move over to this old forum.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Traijan
« Reply #16967 on: Sat, 07 September 2024, 13:12:09 »
If a stabilizer (like the two on my space bar) don't have a wire, are they still considered and named a stabilizer?  I have a ReDragon keyboard and the left shift, space bar, backspace and enter keys all have 3 +
 one + in the center that is the switch and one on each side that don't have a wire connecting them like I've seen in videos.  I'm wondering the pros and cons of not having the wire connecting the 2 outside +'s together.
Thanks
Offline rxq12
« Reply #16968 on: Mon, 16 September 2024, 05:34:05 »
Hi, I have a question about GM60 Poker, I accidentally put a macro on the keyboard, now when you press 1 button, the entire row is pressed, I flashed VIA, nothing helped... The reset of the keyboard also did not lead to anything, the macro remained, please tell me, maybe there is a combination for a complete reset of the bm60? There is no macro in VIA itself.
Offline TheloniousDrunk
« Reply #16969 on: Wed, 16 October 2024, 16:21:09 »
I've been waiting for literal years for a rerun of Aerboards' Aegis keyboard, the southpaw 1800 Compact is without a doubt my favorite layout of all time.
Sadly it doesn't seem like that'll ever be run again so I'm forced to try and find an 1800 compact. I know Hineybush did a run of these years ago and when I looked now I see there's a keychron 1800 compact, but I don't like any of the colors available.
Where can I find an 1800 Compact keyboard kit, ideally with a black or dark colored anodized aluminum case and it'd be nice-to-have but not critical at all for it to have a rotary encoder
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #16970 on: Thu, 17 October 2024, 08:37:55 »
Couple quick questions regarding QMK on Xwhatsit controller for an original Kishy.
I have an original Kishsaver with a 2014 Rev2 Xwhatsit controller that I purchased years ago.  Would this be the correct setup to use QMK for it?  Will it flash over the top of the original firmware or will I have other steps to do to convert from using the original IBM_Capsense_Utility?
Also, can anyone confirm if the solenoid and drivers listed at ModelFKeyboards[.]com will work with that controller and physically fit in the original Kishsaver case without modifications?
I did send a PM to Pandrew over at DT but have not received a reply?  Any other sources I could post these questions?
« Last Edit: Thu, 17 October 2024, 08:40:11 by Melvang »
Offline Norz
« Reply #16971 on: Mon, 18 November 2024, 12:41:32 »
Hello !
I LOVE nice keyboards, but don't really know keyboards. So I'm looking for guidance here. This is what I'm looking for :
Quality, ISO, TKL, nice wood case, green/brown/forest style double PBT, wireless.
Do you keyboard wiz can think of something that'd be easy and fast enough to put together ? Thank you <3
Offline ShangWang
« Reply #16972 on: Tue, 19 November 2024, 16:05:54 »
I have this K10 Pro that I replaced the stabilizers with DUROCK Stabilizer V3s and applied their stabilizer wire and housing pad. I applied 81150 Permatex Dielectric grease to the wires and lubed the housings with G-lube. I had no issues until now, where my right shift key has some resistance when popping back up from being held down, and as a result produces a loud-ping recoil sound. All my other stabilizers are perfectly fine.
https://imgur.com/a/stabilizer-recoil-DkqvUSN
I also took the enter key off and then back on which initially had no issues, and upon putting it back on it had the same recoil sound as the right shift key. The wires are in place and the grease is still there, does anyone know why this resistance/friction of the stabilizers after being held down happens?
Offline Cuby_Ruby
  • Gabber dolbaeb
« Reply #16973 on: Thu, 19 December 2024, 14:36:18 »
Hi all, I'm new here, not sure if I'm asking this question in the right section or if I'll find anyone here with similar keyboards, but I'll ask nonetheless.
I'm a pretty big fan of keyboards from IBM, especially the F models.
I have two keyboards of this model
The model F XT and the model F77.
And after buying the F77 I came across a YouTube video of a person using the F107 without foam and I liked the sound of its springs so much that I also wanted to remove the foam from mine and see if the sound would change to a more resonant sound, of course I realize that the f107 is a different keyboard and it's unlikely I'll get the same sound, but I still want to know if there's a difference in the sound without the foam.
I've already found a couple forums where this topic has been discussed, but there was more talk about whether it would work after removing it and what disadvantages they would get, rather than what sound they would get
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
« Reply #16974 on: Sun, 22 December 2024, 02:59:13 »
Cuby_Ruby Model F keyboards can be used without the inner foam but the barrels would not be secured in place as tightly and may wobble more, and the keyboard will be more prone to dust and debris entry, which may cause typing errors such as double key presses.  I would not recommend it.
Offline gazabi
« Reply #16975 on: Wed, 02 April 2025, 19:29:27 »
Hi, I have an OSA Alice PCB and was wondering what the purpose of the 3 sets of pads on the left of the PCB in the attached imgur link are for. I think they are for capslock/numlock leds, but I found no definitive information or guide on how to use them. I got the pads below the switches to work with LEDs but the 3 sets on the side dont seem to respond to anything.
https://imgur.com/gallery/osa-alice-pcb-xNZ5cYY
If anyone can point me to how I can use them that would be very helpful.
Offline sheepish.alpaca
« Reply #16976 on: Fri, 02 May 2025, 21:06:16 »
What do you guys do with bad switches that have reached their service life and can't be used any more (e.g., because they don't debounce properly anymore & send two keystrokes instead of one; they don't register key presses w/o additional force; etc.)?
I took a quick look on Google and all I'm finding is advice on throwing away entire keebs as e-waste, and I can't find any answers here on GH or /r/MK.
Offline enchong
« Reply #16977 on: Fri, 20 June 2025, 11:32:01 »
How's your HHKB snow holding up?
I just recently bought a new HHKB Hybrid Snow blank key caps. I really love the color. I wonder if this will turn yellow after a few years as how most white electronics does.
Offline Melvang
« Reply #16978 on: Mon, 07 July 2025, 08:24:12 »
Where can I buy Cherry style stabilizers, need both plate and PCB mount (different boards, one won't have a pcb and the other doesn't have a plate), but only in 2u.  Both keyboards are Ergo Dox layouts so no 6.25 or 7u stabs needed.
Offline nico.psd
« Reply #16979 on: Tue, 08 July 2025, 08:27:57 »
Hi everyone
I'm returning to the community after a couple years away. It's nice to be back  :)
I am currently looking for switch recommendations. My main board and my fave switches of all time are the NK Blueberries - I love a heavier tactile! I would like to try some similar switches, so if anyone has recommendations (especially if easy to get in the UK) I would like to know!
Have a good day all! o/
Offline ABunchOfNumbers
« Reply #16980 on: Tue, 15 July 2025, 13:29:36 »
Hi everyone
I’ve had good experiences with Prototypist.net, Mechmods.co.uk and Mechboards.co.uk for UK based orders.
They currently have some variants of the U4Ts and JWK T1s in stock. The U4T has a strong tactile bump but is more rounded and less sharp than the NK Blueberry. If you’re after something with a crisper bump, the T1s might be a closer match.
Prototypist has a few other tactile switches but I cannot comment as I haven't tried any of them.
There aren’t many other UK vendors I’m aware of, but if you’re looking to try other switches, importing could be worth considering. Most switch orders fall below the £130 VAT/import duty threshold, so the only extra cost is usually shipping.
« Last Edit: Tue, 15 July 2025, 13:35:33 by ABunchOfNumbers »
Offline cheater
« Reply #16981 on: Sat, 09 August 2025, 14:44:59 »
Hi there, I've been trying to get in touch with pandrew as well - were you able to get in touch with him in the end?
Thanks
Offline Kerim1te
« Reply #16982 on: Tue, 16 September 2025, 08:47:06 »
Q: Any idea how to change a keyboards Menu/App key to the FN key? New board came with this by default instead of an FN button and I'm not familiar with how to change it with VIA for example.
Offline nescio
« Reply #16983 on: Thu, 11 December 2025, 16:33:44 »
https://docs.qmk.fm/newbs_building_firmware_configurator
Offline Virtual.mp3
  • they/them
« Reply #16984 on: Sat, 13 December 2025, 11:10:47 »
Q: Trying to buy Gateron Type R switches but live in Europe, anyone has a store recommendations based in Europe that has them? Or a store that ships to Europe and does not cost an obscene amount.
Offline nescio
« Reply #16985 on: Tue, 16 December 2025, 10:51:41 »
Regarding "build quality", it seems to me that any of the large companies like Logitech would be able to completely crush anyone competing with them, because they have the resources to hire people full-time and have a million dollar electronmicroscope to do material science, etc.
So, the most likely hypothesis from that worldview is that all those small companies built by hobbyists are basically just producing expensive waste.
Can anyone explain why this isn't true without accusing me of being a troll?
I might be biased, but bigger companies almost always do have better people on the payroll.
Offline nescio
« Reply #16986 on: Tue, 16 December 2025, 14:49:49 »
Why would anyone want a keyboard without a Del key (like one of the keyboards at the top at  https://geekhack.org/index.php?topic=125894.0;topicseen )?
Offline zegonix
« Reply #16987 on: Wed, 17 December 2025, 02:12:47 »
i write this answer from an optica60 (60% as the name suggests).
once you get into layers, you can put delete wherever you want.
Offline nescio
« Reply #16988 on: Thu, 18 December 2025, 17:24:30 »
Why did you buy that instead of the Glove80?
Your keyboard does sound nice, but I still don't get it.
« Reply #16989 on: Mon, 08 June 2026, 03:37:41 »
Are there still people doing custom switch soldering and lubing, or has it become all DIY these days?
Offline zegonix
« Reply #16990 on: Wed, 10 June 2026, 03:21:48 »
because the optica60 looks beautiful.
