Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6201111 times)
Offline Dubsgalore
« Reply #4100 on: Fri, 13 September 2013, 15:02:46 »
that first photo looks more like dolch alphas with white on black mods
Isn't that what Dolch is? White on Grey Alphas with White on Black mods? Just called Dolch because that's the board the color scheme originally came from.
not what i thought, in fact, in MMB's photo here, the mods are dolch, with the one exception of the right shift, which is white on black
edit: also those 1x caps on the bottom row are from the hashbaz tsangan buy, white on black SP to match the SP white on black right shift
« Last Edit: Fri, 13 September 2013, 15:07:17 by Dubsgalore »
« Reply #4101 on: Fri, 13 September 2013, 15:03:43 »
Dolch is actually medium gray and very-dark gray.
Offline Dubsgalore
« Reply #4102 on: Fri, 13 September 2013, 15:04:27 »
Photekq wanna help me out? Hunt down a picture of both and add them to that post? Gonna add it to the OP.
I'm not phobro, but winrar?
Moogle on top; Tsangan on bottom
« Reply #4103 on: Fri, 13 September 2013, 15:12:38 »
For anyone who's reading this later. This is what I learned today. :D
Offline Dubsgalore
« Reply #4104 on: Fri, 13 September 2013, 15:13:45 »
Bro, check dem quotes  :)) :))
also, is that photo of moogle vs tsangan ok?
« Reply #4105 on: Fri, 13 September 2013, 15:14:01 »
Woops, was in dota and missed your post CPT. I think dubs pretty much covered it though.
« Reply #4106 on: Fri, 13 September 2013, 15:15:09 »
Yeah dude....I edited the wrong post and was like WTF HAPPENED.
* CPTBadAss IS DUMB
Could you possible do some sick Paint editing to it too? Box the moogle and the tsangan and label both?
Offline Dubsgalore
« Reply #4107 on: Fri, 13 September 2013, 15:22:17 »
LOL all good
i got so confused while reading it
i think some of us might remember vaguely my master paint skills..http://geekhack.org/index.php?topic=43183.msg879446#msg879446
also, for the first 3 months i was on Geekhack, i thought the difference between Moogle and Tsangan was profile..i thought they were both 1.5 mods but with different seperate profiles..CPT can vouch for me
« Reply #4108 on: Fri, 13 September 2013, 15:23:24 »
Thanks dubs, appreciate it. I'll add that to the OP later. And fixing the quotes...that was a mess...
Offline stancato9
« Reply #4109 on: Fri, 13 September 2013, 21:40:41 »
Quick question.. Where can I get dark grey / charcoal pbt?
I know imsto has thick grey pbt but I would like something darker."
Thanks.
Poker 2 - MX Red
Offline Dubsgalore
« Reply #4110 on: Fri, 13 September 2013, 21:43:45 »
Thanks.
not sure those exist, to be 100% honest
Offline stancato9
« Reply #4111 on: Fri, 13 September 2013, 21:45:30 »
Thanks.
I've seen them on here somewhere. Can't remember where though. And the owner said they were darker than imsto I believe.
Poker 2 - MX Red
« Reply #4112 on: Fri, 13 September 2013, 21:50:19 »
There are probably some thin PBTs or ABS ones that are darker. There are no thick PBTs that are darker though..
Offline dndlmx
« Reply #4113 on: Fri, 13 September 2013, 21:51:09 »
Any good wrist rests for smaller keyboards? 60%, TKL, HHKB, etc...
That are available, easy to get at the current time, mind you.
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #4114 on: Fri, 13 September 2013, 21:51:44 »
Beast's?
« Reply #4115 on: Fri, 13 September 2013, 21:54:21 »
Beast's?
He's not making them right now because of school.  They're pretty easy to make though and I've made several myself.
If you just want a padded one, Grifiti makes a decent one.
Offline stancato9
« Reply #4116 on: Fri, 13 September 2013, 21:55:36 »
I think I remember Keyboard King being where they were from.. if that's even a store / person. :p
Poker 2 - MX Red
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4117 on: Sat, 14 September 2013, 13:34:30 »
There was some dark charcoal with black dyesubs sets made by vortex at one point, Ducky had some black pad print on black sets awhile ago too. Both are OEM profile thin caps though.
Offline jonathanyu
« Reply #4118 on: Sat, 14 September 2013, 13:50:24 »
where can I get  LED stand-offs for filco-style LEDs?
I never realized they had a standoff but i found a picture from Photoelectric. I bet you could just order some plastic bushings and cut it down to size from McMasterCarr or a hardware store. I don't know the diameter though. And I wonder if you actually need them or if you could just put a bit of insulation, like plastic, between the LED and plate.
They are 5mm in diameter x 8mm in height. You can get 400 of them for $6.83 shipped, from Amazon.
someone tell mkawa he can buy a pack and add them to the geekhackers store ;)
Hmmm, 2000 pcs is only $21.91 shipped, from Hong Kong. http://www.ebay.com/itm/310577934164
just bought it  :) thanks!
Offline jonathanyu
« Reply #4119 on: Sat, 14 September 2013, 15:17:44 »
just got the music wire today, 1/16" is the right size. But another question come out? what kind of cutter can I use to cut it? I have tried edsyn kp111, it to hard for kp111.
and....how to bend it? I use a Du-Bro EZ Bender, but the wire break up every time just before it get to 90 degree.
« Last Edit: Sat, 14 September 2013, 15:29:49 by jonathanyu »
Offline frogamic
« Reply #4120 on: Sat, 14 September 2013, 20:56:21 »
What type of steel do you use when making a plate for switch mounting?
Filco TKL | Filco ISO105 | Acer 6311-K71
« Reply #4121 on: Sat, 14 September 2013, 21:28:16 »
Cherry specs call for 0.060" thickness. You can use any type of steel, but these have typically been made using 16-gauge stainless steel. 16-gauge is 0.0625" but is close enough to work well for our purposes.
Offline MKULTRA
  • telling it how it is
« Reply #4122 on: Sun, 15 September 2013, 18:33:55 »
Have you seen litster's video?
« Reply #4123 on: Sun, 15 September 2013, 18:40:09 »
His video has the EZ Bender in in but metalliqaz said its apparently too weak to bend music wire. I know he tried to bend some wire for his Epsilon project. More info can be found in that thread.
Offline jonathanyu
« Reply #4124 on: Sun, 15 September 2013, 18:50:49 »
I have seen it, and I tried the same, but mine broke every time.
seems that mine music wire just doesn't match with the ez bender  :(
« Reply #4125 on: Sun, 15 September 2013, 19:50:10 »
Doesn't the DuBro EZ Bender have different dies for different sizes of wire? Are you using the correct one?
Offline jonathanyu
« Reply #4126 on: Sun, 15 September 2013, 20:10:18 »
I am using the 062-.072 die
« Reply #4127 on: Sun, 15 September 2013, 20:29:32 »
Well then, I got nothing. :)
I use a vice and pliers.
Offline jonathanyu
« Reply #4128 on: Sun, 15 September 2013, 20:35:00 »
Finally, I bend the wire to 90 degree successfully.  I found that the wire won't break if you bend it really fast.  :p
Offline phx
« Reply #4129 on: Mon, 16 September 2013, 13:02:21 »
say I have a board with mx brown and I want to mod it to ergo clear, would my best/easiest option be just open up the switches and swap the stem, spring, etc?
are the housings universal?
Offline BlueBär
« Reply #4130 on: Mon, 16 September 2013, 13:07:59 »
With a PCB mounted keyboard, yes, but with a plate mounted keyboard without a solderless plate you will have to desolder the switches and remove them from the plate, so it would actually be easier to swap the whole switch instead of opening each one.
Apart from the PCB mounting pins, yes.
Offline lcs
  • はやく
« Reply #4131 on: Mon, 16 September 2013, 13:09:40 »
You need the sliders from the clears and the springs from the browns, if I am not mistaken.
« Reply #4132 on: Mon, 16 September 2013, 13:15:28 »
1) say I have a board with mx brown and I want to mod it to ergo clear, would my best/easiest option be just open up the switches and swap the stem, spring, etc?
2) are the housings universal?
1) Depends on the keyboard you have. If its plate mounted and stock or PCB mounted with LEDs you'll have to desolder the switches. If you have a custom plate that allows you to open the switches without desoldering then yes, swapping the stem and spring would be easiest. If you have a custom plate and LEDs, you'll have to desolder the LEDs. You can mod the housings to work with the custom plate and LEDs.
2) Yes
If you're doing the "traditional" ergo-clear mod then yes, this is correct. I think there's a bit of confusion with ergo-clears since some people, including myself, refer to anything that's not stock clears as ergo-clears. However, the precedent is that ergo clears are Brown/Red/Blue springs with a Clear stem. And everything else should be referred to by spring weight. For example: 55g Clears or 62g Clears.
Offline lcs
  • はやく
« Reply #4133 on: Mon, 16 September 2013, 13:17:45 »
Yes, it'd be better. I believe this comes from the DT wiki, right?
« Reply #4134 on: Mon, 16 September 2013, 13:20:07 »
Correct.
Offline phx
« Reply #4135 on: Mon, 16 September 2013, 13:59:23 »
aww crap, I have a QFR which means it's plate mounted.
guess it's time to buy a soldering iron...  :rolleyes:
people seem to be suggesting this one:
http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UC/ref=sr_1_4?ie=UTF8&qid=1379358026&sr=8-4&keywords=soldering+iron
or can I be cheap and get a cheaper one?
« Last Edit: Mon, 16 September 2013, 14:01:01 by phx »
Offline whiskytango
  • Don't touch the trim
« Reply #4136 on: Mon, 16 September 2013, 14:22:52 »
guess it's time to buy a soldering iron and a desoldering iron...  :rolleyes:
ftfy
I have used the RadioShack desoldering iron with the built in bulb with some success. The tips wear out quickly, but it's very cheap (around $15 I think) Edit: you can also use a solder sucker for even cheaper, but I don't care for those too much. I really like my Hakko 808 but they're not cheap
People have widely varying opinions on which soldering iron to get. Some people get by with cheap ones. Some people prefer expensive ones. I think that buying a decent iron will pay off down the road. I have been using a XYtronic 258 for 10 years or so, but I don't use it very often. I like it. If I had it to do over again, I'd probably buy one with a base station instead of one that has the thick heavy power cord running straight from it to the plug.
There's a whole thread on this: Living Soldering Thread
« Last Edit: Mon, 16 September 2013, 14:27:05 by whiskytango »
« Reply #4137 on: Mon, 16 September 2013, 14:29:54 »
Issue with the Radio Shack Bulb is that the tip isn't fine enough for LED/smaller solder joints. I had to get a Soldapult, which has worked fine.
Cheaper soldering iron would might be a Yihua 936. Follow WhiskyTango's link for more info and details.
FWIW, I have a Radio Shack Desoldering Bulb, a Soldapult DS017, and a Hakko 936 with a Chisel Tip.
Offline phx
« Reply #4138 on: Mon, 16 September 2013, 14:30:45 »
hmm... I have a solder sucker so I thought I could just use that instead of buying a desoldering iron, I guess desoldering would be much easier if I had an iron just for that.
« Reply #4139 on: Mon, 16 September 2013, 14:32:34 »
I've had HORRIBLE results with a solder sucker. Definitely spring for a Soldapult if you want to go that route. Otherwise other popular options are Hakko 808 and the Radio Shack bulb. I like the Soldapult after getting some time to practice with it.
Offline phx
« Reply #4141 on: Mon, 16 September 2013, 14:39:34 »
Yihua 936
lol it is in the Soldering Thread....
but damn that's a good deal, will pick that up, thanks!
edit: bought it, and will pick up a desoldering iron and solder next time I'm at radioshack :d
« Last Edit: Mon, 16 September 2013, 14:53:40 by phx »
« Reply #4142 on: Mon, 16 September 2013, 14:41:47 »
At work I just have the generic gel wrist pads they sell at Staples. At home I have a 3G gel wrist rest for my keyboard and a IMAK bead wrist rests that I bought at Amazon and MicroCenter respectively. I've heard good things about Griffiti wrist rests too.
Don't think I've ever seen this color in thick PBT either.
Offline sga101
« Reply #4143 on: Mon, 16 September 2013, 15:04:17 »
Is there a device which can graft on extra features like remapping and macros to an existing USB keyboard?
Something which looks like one of those USB keyloggers perhaps?
If not, I suspect there would be a market for it....
Since my electronics skills are almost zero, I'm ideally looking for something that comes ready assembled.... :)
« Reply #4144 on: Mon, 16 September 2013, 16:53:45 »
Soarer converter assembled by someone in the Professional Services thread. Pro Service link in the OP. Soarer Converter is a sticked thread in Making Stuff Together.
« Reply #4145 on: Mon, 16 September 2013, 17:01:18 »
The soarer works great if you have a PS2 keyboard. For USB, I know of the QIDO qwerty to dvorak converter. I think someone is working on usb host support, possibly hasu's tmk firmware, but it's surely in the alpha stage right now, if that.
Offline keymaster
  • Topre Revolution Theorist
« Reply #4146 on: Mon, 16 September 2013, 22:49:47 »
Does anyone know what type of switch this keyboard uses? It looks like a Topre rubber cup but I've never seen this keyboard before.
http://www.ebay.com/itm/Solbourne-102691-Computer-Keyboard-/261268991231
Offline loadstar81
« Reply #4147 on: Mon, 16 September 2013, 22:58:49 »
What combination of switch/o-ring/spring(?)/etc would give the absolute quietest setup for office use?
LOAD "*",8,1  | kbtpure | cm qftk
Offline ComradeSniper
  • HHKB Pro
« Reply #4148 on: Tue, 17 September 2013, 00:50:07 »
For MX, Browns, Clears, Reds, and Blacks will be equally loud.
« Reply #4149 on: Tue, 17 September 2013, 00:56:46 »
Naw linear Is quieter, you can hear the actuation on clears. Get blacks
