Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6201143 times)
0 Members and 6 Guests are viewing this topic.
Offline ComradeSniper
  • HHKB Pro
« Reply #4150 on: Tue, 17 September 2013, 01:01:37 »
Naw linear Is quieter, you can hear the actuation on clears. Get blacks
I'd call it a wash considering you'll most likely bottom out with blacks whereas you might not with clears. Even though blacks are heavy I find it really hard to not bottom out as a result of the linear-ness. The actuation on clears is really quiet anyway.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4151 on: Tue, 17 September 2013, 05:24:42 »
Couple quick questions.
1.  Which spring has the most ramp up in the spring rate?  Better way to say it which one has the highest rise in force from actuation to bottom out?
2.  Does Teensy 2.0 firmware support function layers on a toggled switch via MX lock or any other toggled switch?
Offline BlueBär
« Reply #4152 on: Tue, 17 September 2013, 05:44:19 »
Looking at this this I would say clear.
That depends on the firmware. I think you misunderstand how a Teensy works?
« Reply #4153 on: Tue, 17 September 2013, 06:07:17 »
What combination of switch/o-ring/spring(?)/etc would give the absolute quietest setup for office use?
Quietest switches I've ever tried: Jailhouse Blues, Matias Quiet, Topre
Offline Melvang
« Reply #4154 on: Tue, 17 September 2013, 06:31:37 »
Nevermind, with what I was thinking the Teensy would just see it as having the button pressed for the duration of the MX lock being down as it would just close the circut until I push it again.  I think I am right on this anyway.
Offline llovro
« Reply #4155 on: Tue, 17 September 2013, 08:20:07 »
What kind of caps are the og dolch (found on dolch keyboards)? Are they doubleshot, printed or what? Thanks
« Reply #4156 on: Tue, 17 September 2013, 08:32:38 »
Doubleshot thick ABS from Cherry.
Offline llovro
« Reply #4157 on: Tue, 17 September 2013, 08:57:44 »
No, I mean the original ones. From dolch keyboards not from sherry.
Offline Melvang
« Reply #4158 on: Tue, 17 September 2013, 09:03:33 »
How many leads will connect to a Teensy 2.0 hard wired matrix for a TKL layout minus the entire Esc row.  Only using 5 rows not 6.
Offline MKULTRA
  • telling it how it is
« Reply #4159 on: Tue, 17 September 2013, 09:12:14 »
Does anyone know what type of switch this keyboard uses? It looks like a Topre rubber cup but I've never seen this keyboard before.
http://www.ebay.com/itm/Solbourne-102691-Computer-Keyboard-/261268991231
I have no clue.  Mousefan has nothing on it.  Just looks like traditional rubber dome but still an interesting design.
« Reply #4160 on: Tue, 17 September 2013, 09:13:00 »
Right, as I said, doubleshot ABS from Cherry. Originative sells doubleshot ABS from GMK. :)
« Reply #4161 on: Tue, 17 September 2013, 09:16:59 »
16 columns and 5 rows, so 21 pins total, right?
Offline Melvang
« Reply #4162 on: Tue, 17 September 2013, 09:20:49 »
Wouldn't it be 17x5?
`, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, -, =, Backspace, Insert, Home Page Up
Tab
Caps Lock
Shift
Ctrl.
« Reply #4163 on: Tue, 17 September 2013, 09:23:04 »
Tab
Caps Lock
Shift
Ctrl.
You are correct. :)
Offline Melvang
« Reply #4164 on: Tue, 17 September 2013, 09:25:20 »
So where I am going with this is what I need minimum for wires in a ribbon cable for a hard wired TKL layout.  I would need 22 wires in the cable correct?
« Reply #4165 on: Tue, 17 September 2013, 09:36:50 »
At a minimum, plus another 1-3 if you use lock status LEDs.
Offline Melvang
« Reply #4166 on: Tue, 17 September 2013, 09:43:22 »
Excellent thanks jd.  Now if I can just find a screw together hood for this connector that I am using for this project.
Offline esoomenona
  • Gnillort?
« Reply #4167 on: Tue, 17 September 2013, 11:08:59 »
What color are stock Model M SDL cables? Are they beige/tan or grey? I've seen both, but I'm curious as to whether they might appear to be beige/tan due to being old? Or are there multiple colors of them?
Offline Melvang
« Reply #4168 on: Tue, 17 September 2013, 11:34:26 »
While I personally have not used any since high school my guess would be both beige/tan and gray.  With the gray for the industrial models that had the gray case as well.
Well couldn't find any screw together ones but I found a site that had snap together ones in black so that will work.
« Reply #4169 on: Tue, 17 September 2013, 11:59:26 »
Just FYI: Sherry is not Cherry. Sherry = Sheraton = Owner of Originativeco.com who sells GMK caps. Cherry is the keyboard/keycap company.
The one that came with my SSK is beige.
Edit: The one in this video and from ClickyKeyboards looks beige. This one from Unicomp looks tan. Seems like there's multiple colors.
I also don't know. If you don't get an answer soon, I'll PM haata, danielsbeardsmore, or Dorkvader.
« Last Edit: Tue, 17 September 2013, 12:06:07 by CPTBadAss »
Offline e4stw00t
« Reply #4170 on: Tue, 17 September 2013, 13:14:56 »
Hey dudes, just got myself a filco and recognized that the space bar sounds different when pressing it on the right end compared to the left one. It also is a bit loose on the right side, it moved a bit towards the upper end if I press the bottom right hand corner in that direction. On the left side it's rather firm and doesn't move at all. Not a deal breaker at all at that stage but just want to get some feedback from long term users if this is normal or something that worsens over time - having paid 169 € for the board I might be a bit paranoid at that stage though.
« Reply #4171 on: Tue, 17 September 2013, 13:17:57 »
I'm typing on a Filco and I can't replicate your issue. Take the spacebar off and see if the Costar inserts and wire are all seated correctly.
Offline divito
« Reply #4172 on: Tue, 17 September 2013, 17:35:36 »
Before (possibly never), I go towards a 60%, and as I collect keyboards, I'll be going towards TKL and slightly smaller. Of keyboards I've seen, KBT Race is one of the closest in the layout I'd like in the smallest footprint. Keycool 84 is even closer I think.
As such, I'm keeping my eye out for unique and small layouts with arrows/6-key functionality.
Anything with similar layout to this?:
http://www.ebay.com/itm/Zalman-ZM-K500-Mechanical-Keyboard-/150957596201?pt=PCA_Mice_Trackballs&hash=item2325c61e29
« Last Edit: Tue, 17 September 2013, 18:05:56 by divito »
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
  • HHKB Pro
« Reply #4173 on: Tue, 17 September 2013, 17:42:50 »
Have you considered the Filco Minila?
Offline divito
« Reply #4174 on: Tue, 17 September 2013, 17:50:33 »
Saw it awhile back, and it's quite close. Though I wouldn't be able to really use the space bar given my typing and where I hit the space bar, and I'd prefer 6-key not on a function layer. Will still keep it for consideration in the future, maybe simply as part of my collection.
« Reply #4175 on: Tue, 17 September 2013, 17:59:14 »
I've never seen a layout like that, but it's just a compact tenkeyless yeah?
Offline divito
« Reply #4176 on: Tue, 17 September 2013, 18:09:49 »
Technically, yes. Basically desire TKL functionality, without the use of a function layer, in even smaller footprints than TKL. Will plan to own the KBT Race and Keycool 84, as like I said, they're the closest to what I want short of designing my own.
Just using the simple thread for other potential options from the vast knowledge of GH members. :DD
« Reply #4177 on: Tue, 17 September 2013, 18:19:04 »
With the right plate, you could do pretty much the same thing with a Phantom.
Offline frogamic
« Reply #4178 on: Tue, 17 September 2013, 18:55:52 »
Is there a standard rake/incline for keyboards? I just held a protractor up to my filco and seems to be about 4 degrees but it was difficult to be accurate.
Filco TKL | Filco ISO105 | Acer 6311-K71
« Reply #4179 on: Tue, 17 September 2013, 19:06:47 »
Think it's 9 degrees or 11 degrees.
Offline Melvang
« Reply #4180 on: Tue, 17 September 2013, 22:34:08 »
Based off measurements I took off my costar Das it was 10.2 degrees if I remember correctly.  I can double check when I get off work though.  And that was with the feet extended.
« Reply #4181 on: Tue, 17 September 2013, 22:40:31 »
Filco is 5.5 with feet up, 10 with feet down.
Offline frogamic
« Reply #4182 on: Tue, 17 September 2013, 23:15:45 »
Thanks, just measured mine again more accurately and it was very close to 5, thought 11 sounded too much.
Offline Lastpilot
  • Power stance
« Reply #4183 on: Wed, 18 September 2013, 15:35:54 »
How does one usually go about hunting down a KBD mania key? Only on KBD mania?
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #4184 on: Wed, 18 September 2013, 15:38:42 »
Ask zenuty?
« Reply #4185 on: Wed, 18 September 2013, 15:42:27 »
do you have a pic?
Offline Lastpilot
  • Power stance
« Reply #4186 on: Wed, 18 September 2013, 15:47:43 »
Sorry I don't. I've just seen them every now and then while browsing the Media subforum and I began to get curious.
@lcs: Good advice, if anyone on GH knows it would be him.
« Reply #4187 on: Wed, 18 September 2013, 15:48:20 »
I've seen a couple floating around here in the classifieds. And ray, look at the addon pack for the old Valentine's buy if you want a picture as reference.
« Reply #4188 on: Wed, 18 September 2013, 15:49:30 »
Ok I didn't know if there were other KBD keys. I think I've had a few here and there in my mess of key caps.
Offline MTManiac
« Reply #4189 on: Wed, 18 September 2013, 16:17:07 »
How common are pink costar stabs?
I decided to retrobright my 5181 and start using it and to my surprise I found pink costar stabilizers
they may be common, but they sure surprised me!!!
« Reply #4190 on: Wed, 18 September 2013, 16:17:50 »
I've never seen anything but white costar stabilizer inserts.
« Reply #4191 on: Wed, 18 September 2013, 16:19:01 »
Those aren't exactly Costar stabs. They look proprietary. But  close enough, I guess. :)
« Reply #4192 on: Wed, 18 September 2013, 16:21:34 »
Id agree with jdcarpe
« Reply #4193 on: Wed, 18 September 2013, 16:29:52 »
I've seen pink, blueish green, and white stabs like that with Alps.
Offline MTManiac
« Reply #4194 on: Wed, 18 September 2013, 16:47:46 »
ahhh gotcha, well it would make sense in an ironic sort of way that they would be semi clones considering it came from the monterey blues era
thanks for the clarification :)
Offline keymaster
  • Topre Revolution Theorist
« Reply #4195 on: Wed, 18 September 2013, 18:10:01 »
I'm trying to find the color codes from Signature Plastics for Dolch colors (DCS profile, ABS).
Basically, I want to get four 1x blanks.
Here is their list of colors:
and here is the Dolch set:
« Reply #4196 on: Wed, 18 September 2013, 18:17:21 »
DSA Dolch was in GE and GX.
« Reply #4197 on: Wed, 18 September 2013, 18:17:52 »
From domoaligato's GB
The base colors are GE and GX
And he says that the legends/letters/fonts are WFK or white. But I think OG Dolch is a lighter grey and not WFK. But since you don't care about the legends, I don't think it matters too much right?
Edit: rowdy on that sniper flow.
Offline keymaster
« Reply #4198 on: Wed, 18 September 2013, 18:19:09 »
Thanks. You guys are awesome.  :thumb:
Offline whiskytango
  • Don't touch the trim
« Reply #4199 on: Wed, 18 September 2013, 18:40:34 »
Rescued a space invaders type keyboard from the e-recycler today. Model # RT8Z55C+
The cable was cut off right at the keyboard, so I will have to replace the cable. Does anyone know what type of connector this uses? I'm assuming ps/2.
