Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230824 times)
Offline esoomenona
  • Gnillort?
« Reply #6150 on: Wed, 05 February 2014, 16:40:54 »
Haven't been in here in so long...
Does the Silent Realforce have the purple sliders and little plastic rings?
It looks like it: http://imgur.com/a/TlIl7
Thank you very much.
Offline yasuo
  • spanengan puyeng newbie
« Reply #6151 on: Thu, 06 February 2014, 00:50:41 »
what is name this GB? :)
Logitech MK220 Colemak DH
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #6152 on: Thu, 06 February 2014, 01:59:11 »
The TKL "Bluegreen" Keycap Set
http://geekhack.org/index.php?topic=49147
Offline phx
« Reply #6153 on: Thu, 06 February 2014, 11:25:27 »
so I got an ergodox recently, I need a set of caps to put on it.
brainstorming some ideas:
I really dig light colors caps, and preferably with prints on. I understand it's difficult to have all printed caps on an ergodox since I might change the layout and whatnot, has to be all printed, it looks weird to have some printed and some not. =\
probably also has to be DSA profile, SP does sell them in blank sets, hmm, are they any good?
edit: if i remember correctly, there were some GBs on here with ergodox kits. but the matching alpha set is always large centered text legend, argh
this set looks pretty good: http://i.imgur.com/210xlYF.jpg
« Last Edit: Thu, 06 February 2014, 11:32:18 by phx »
« Reply #6154 on: Thu, 06 February 2014, 12:46:53 »
What's your question exactly? If the SP DSA caps are good?
Offline phx
« Reply #6155 on: Thu, 06 February 2014, 13:17:57 »
sorry I was being vague.
I'm just looking for some suggestions on ergodox keycap sets. I prefer something printed.
« Reply #6156 on: Thu, 06 February 2014, 13:48:10 »
I don't know too much about eDox kits but off the top of my head I remember that these GBs have eDox options:
Penumbra
Round 5 from Deskthority
Calm Depths
Also Hyperfuse had a kit.
And there's the caps that came from Massdrop:
SP PBT DCS
Clear Ergodox Caps
« Last Edit: Thu, 06 February 2014, 13:55:07 by CPTBadAss »
Offline lilky
« Reply #6157 on: Thu, 06 February 2014, 16:12:04 »
Hi, I recently purchased an A87 ps2avr and I need to buy a moogle kit to accomodate the old-style 86 key layout. Does anyone know where to purchase blank white thick PBT moogle sets? Preferably cherry profile.
Also, on the new signature plastics website, which of these spacebars http://keyshop.pimpmykeyboard.com/product/spacebar-inventory will fit the cherry profile? Thanks!
Offline dnny3000
« Reply #6158 on: Thu, 06 February 2014, 16:47:44 »
Hi. I have a Ducky mini, and would really want to swap the left ALT and WIN.
How?
in PN layer I figured out how to do it. As I would like this to be allways I think I should do it by DIP switches, but how to setup the DIP switches?
Offline gh_pp
« Reply #6159 on: Thu, 06 February 2014, 17:18:27 »
Once I commented on a thread, it forever goes into my "Show new replies to your posts." list
I have clicked the unWATCHed, unNOTIFied buttons at the top inside the thread, but it still won't do anything.
Is there any way to unsubscribe?
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
« Reply #6160 on: Thu, 06 February 2014, 17:26:27 »
I dont think so.
1) Does anyone know where to purchase blank white thick PBT moogle sets?
2) Also, on the new signature plastics website, which of these spacebars http://keyshop.pimpmykeyboard.com/product/spacebar-inventory will fit the cherry profile? Thanks!
1) I've never seen a PBT Moogle set. Maybe you can find a Cherry keyboard such as the ones suggested here.
2) Anything in SP's inventory that is "DCS" will fit the Cherry Profile. DCS is their Cherry Profile. There's a link in the OP.
How?
Check out the Ducky Mini Manual.
Offline hasu
  • @tmk
« Reply #6161 on: Thu, 06 February 2014, 21:26:35 »
Hi guys and gals.
How can I remove this green parts without taking apart  completely?
Offline lilky
« Reply #6162 on: Thu, 06 February 2014, 22:21:11 »
I dont think so.
How?
Awesome, thanks CPTBadAss! Can you explain what all the different types of spacebars are? For example for 7x spacebars there is BFP, GA, GAL, etc. What are the differences between these?
Offline yasuo
« Reply #6163 on: Fri, 07 February 2014, 04:28:14 »
how many ohm/watt resistors for LED? :)
« Reply #6164 on: Fri, 07 February 2014, 05:39:04 »
Use Ohm's Law to figure it out. A discussion that might help is here.
Different colors.
Hasu I believe those are press fit. You should be able to remove those with a small screwdriver or a pair of needle nose pliers. If they're the same as the white stabilizers on Model Ms, I just put some of those inserts into my 6019284 Kishsaver.
Offline MsYutai
« Reply #6165 on: Fri, 07 February 2014, 11:14:02 »
I'm sure this has been asked somewhere before but...
What mech kb are easy to mod? I was thinking about trying clears and then maybe switching to ergo-clears-- any suggestions?
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #6166 on: Fri, 07 February 2014, 11:14:40 »
Any PCB mount keyboard allows you to open the switches without desoldering, I think.
Offline BlueBär
« Reply #6167 on: Fri, 07 February 2014, 11:42:01 »
Would recommend a PCB mount board as well. Also get some of Beasts switch tools, they make opening switches very easy!
Offline MsYutai
« Reply #6168 on: Fri, 07 February 2014, 11:58:39 »
I see. Sounds like there aren't too many PCB mounted boards out there... Thanks for your help!
As a PCB mount lover I keep a look out for them, sadly there are not a whole lot of them.
Cherry G80 series are generally PCB mount except for a few models. There are also many rebranded Cherry like Peacock, Schneider, Nixdorf, Highscreen, Scitex, Olivetti, Commodore, Amiga, Compaq, APC, etc, though usually there are only certain times where they had some G80 as a high end option so most of them are not.
Vortex Poker, Pure, Race.
Plum 96 and Neo Zelia.
WEY EK and HK series, though they are not useable without the hard to find proprietary KVM box that is required.
Alcatel MMK, some of which have a proprietary connection and protocol to be used with their thin terminals.
GH60 can be if you build it as such.
Offline bcg
« Reply #6169 on: Fri, 07 February 2014, 17:18:35 »
PS/2 protocol has a host-to-keyboard to request a specific codeset (F0, according to http://wiki.altium.com/display/ADOH/PS2+Commands) ... if you request code set 3 from a "normal" Model M with a PS/2 connector (1391401 for instance) will it honor that and use code set 3?
:wq!
Offline Soarer
« Reply #6170 on: Fri, 07 February 2014, 20:54:41 »
Yes.
« Reply #6171 on: Fri, 07 February 2014, 20:56:16 »
Yes.
Thank you Soarer! Time for me to read up :D.
Offline bcg
« Reply #6172 on: Fri, 07 February 2014, 21:34:17 »
Yes.
Thanks Soarer that was exactly what I was looking for :)
:wq!
Offline Comment
« Reply #6173 on: Fri, 07 February 2014, 21:37:53 »
Not sure if this was asked yet but I couldnt find it anywhere. Does anyone know how to make your forum picture a gif?
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline Pacifist
  • on hiatus
« Reply #6174 on: Fri, 07 February 2014, 21:38:33 »
Just upload the file but make sure its small enough
Offline Comment
« Reply #6175 on: Fri, 07 February 2014, 21:40:17 »
Wow Pac, nice 40 second response! Can I size down through imgur?
« Reply #6176 on: Fri, 07 February 2014, 21:48:30 »
Some more detailed information here. You can resize in Paint.
Offline augustoitapoa
« Reply #6177 on: Fri, 07 February 2014, 21:55:07 »
Anyone knows if the Rapid-I will be available with an aluminum case?
« Reply #6178 on: Fri, 07 February 2014, 22:02:57 »
Probably not. There's not many stock aluminum cases. There will probably be aftermarket stuff though.
Offline hasu
  • @tmk
« Reply #6179 on: Fri, 07 February 2014, 23:12:48 »
Thank you CPTBadAss
Unfortunately it didn't work for me or I didn't understand what you mentioned correctly. Stupidly I had to remove all plastic revets and take apart thoroughly to get only those parts.
Yes, that is exactly what I want to do. I sacrificed  a poor M to the beast :D
« Reply #6180 on: Fri, 07 February 2014, 23:13:43 »
Thank you CPTBadAss
Ugh sorry you had to go through the effort :( . I shouldve posted a picture or a video.
Edit: For future reference
Unless those green inserts were a different shape, which I don't think they were, you can just pull them out of the barrel plate with some needle nose pliers. You'll have to pull pretty hard. Tested this with my 6019284 and SSK. SSK is shown in the potato picture above.
« Last Edit: Fri, 07 February 2014, 23:34:54 by CPTBadAss »
Offline yasuo
« Reply #6181 on: Sat, 08 February 2014, 01:07:59 »
What tool to test switches still works or not? :)
Offline Pacifist
  • on hiatus
« Reply #6182 on: Sat, 08 February 2014, 01:55:13 »
Solder it into a keyboard?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6183 on: Sat, 08 February 2014, 06:39:36 »
You can use a multimeter to test continuity.
« Reply #6184 on: Sat, 08 February 2014, 09:04:58 »
Or if it's still soldered on your keyboard, you can use AquaKeyTest.
Offline ajx
« Reply #6185 on: Sun, 09 February 2014, 07:32:57 »
Hey, quick question
where can i find wrist rest for 60% size keyboard?
preferably ship to EU
thanks
  • Cherry Peasant
  • keycult.com
« Reply #6186 on: Sun, 09 February 2014, 07:42:10 »
Hey, quick question
thanks
There's a gentleman with a thread in GH classifieds that makes custom leather wrist rests.
Offline yasuo
« Reply #6187 on: Sun, 09 February 2014, 12:27:17 »
where i can get cherry stabs plate mount?
Offline BlueBär
« Reply #6188 on: Sun, 09 February 2014, 12:28:51 »
That is in the FAQ.
Offline jonathanyu
« Reply #6189 on: Sun, 09 February 2014, 19:09:12 »
What is the color code of the grey and beige in the original cherry beige/grey set?
« Reply #6190 on: Sun, 09 February 2014, 19:16:47 »
I think it's U9 and L9 in this picture.
Offline yasuo
« Reply #6191 on: Mon, 10 February 2014, 07:36:12 »
for handwired What  i can glue diode to switch with super glue?
Offline BlueBär
« Reply #6192 on: Mon, 10 February 2014, 07:46:56 »
No, bad idea. Put solder on the tip of your iron or on the switch pin and the diode.
« Reply #6193 on: Mon, 10 February 2014, 07:59:31 »
Glue isn't electrically conductive so the electrical current wouldn't flow...
Offline BlueBär
« Reply #6194 on: Mon, 10 February 2014, 08:18:42 »
I meant putting solder on the ends as a tip on how to connect the two. If you put solder on both ends and heat it up again when you get them next to each other you should get a good connection.
« Reply #6195 on: Mon, 10 February 2014, 16:30:33 »
Does anyone with a Ducky Shine board notice a high pitched buzz/hum when your backlights are turned on?
Offline Photoelectric
« Reply #6196 on: Mon, 10 February 2014, 16:33:45 »
Have not noticed that with either of my Shine IIs, and I'm normally sensitive to those sorts of sounds (and my rooms are very quiet).   My larger monitors are definitely making a high-pitched faint whistling sound though :(
« Reply #6197 on: Mon, 10 February 2014, 16:43:40 »
Hmm ok...I never use the backlighting and just turned it on to check something and noticed it, oh well.
« Reply #6198 on: Tue, 11 February 2014, 09:04:09 »
I have a Team OMG keyboard in my apartment, which I think is a special edition Shine II or Shine. It doesn't create any noise when the backlight is on.
« Reply #6199 on: Tue, 11 February 2014, 09:20:22 »
It gets ever weirder. I thought maybe it was the aftermarket cable so I switched to the stock USB cable and tried different USB ports. Same high pitched noise but if I turn the brightness down the 'volume' of the noise goes down as well  ???
