Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230188 times)
0 Members and 8 Guests are viewing this topic.
« Reply #6300 on: Mon, 17 February 2014, 15:04:41 »
And again another personal preference being marketed as the gospel.  There really is not best or worst switch with the possible exception to cheap rubber domes.  Try the stock clears, if you find them two stiff or would like to feel a bit more of the tactile bump then go ahead and mod them.
Or try Blacks. Or Blues. Whatever, but decide for yourself. Don't just believe the hype that something is good because some people say it is. There are probably a great many people using MX Browns, Reds, etc. who never claim their favorite switch to be the "best," they just use them.
Offline Pacifist
  • on hiatus
« Reply #6301 on: Mon, 17 February 2014, 15:20:19 »
You won't get off the shelf ergo clear soon. I am not aware of any PCB mounted TKL on the market right now, but you can get a phantom and just PCB mount the switches and have a case cut
G80-1800 comes close. And Phantom PCB doesn't have holes for PCB-mounting the switches.
Is it possible to drill holes in the PCB for mounting switches? Or are there traces in those places?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6302 on: Mon, 17 February 2014, 15:21:49 »
What sort of mods are available to unicomp BS keyboards?
« Reply #6303 on: Mon, 17 February 2014, 15:24:33 »
The same ones that you can do to Model Ms:
Bolt mod
Floss mod
Grease mod
65% mod
Foam/blanket replacement
Layout changes
I can provide links if you want.
Offline Melvang
« Reply #6304 on: Mon, 17 February 2014, 15:26:30 »
Bolt mod
Floss mod
Grease mod
65% mod
Layout changes
A link would be nice for the floss mod.
Offline Zeal
    • Zeal Generation Inc.
« Reply #6306 on: Mon, 17 February 2014, 16:36:34 »
Does anyone know if this has mechanical switches?
http://www.ebay.com/itm/Rare-Vintage-Nickelodeon-Keyboard-by-Brain-Works-1994-Tested-w-USB-adapter/181322784654
Well...That's a colourful keyboard.  :eek:
I can say for sure that it's not Cherry switches  :))
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6307 on: Tue, 18 February 2014, 04:50:00 »
To remove and add a detachable cable to my Filco, would that require soldering? (Never opened up one before.)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6308 on: Tue, 18 February 2014, 05:04:23 »
No, you just have to open the case.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #6309 on: Tue, 18 February 2014, 05:09:12 »
This video from WFD shows it pretty well.  Go to 4:47
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6310 on: Tue, 18 February 2014, 05:38:55 »
Thanks guys. :)
  • Cherry Peasant
  • keycult.com
« Reply #6311 on: Tue, 18 February 2014, 06:27:09 »
What are the highest-quality ANSI Alps keycaps available? For example, for MX switches, OG Cherry keycaps are regarded as best-in-class.
« Reply #6312 on: Tue, 18 February 2014, 07:39:00 »
The bad thing about Alps is that you'll probably have to harvest caps from a keyboard. You can't pick up aftermarket ones at the moment. I really like the caps on the Apple AEKII, Dell AT101W, and Focus FK-2001. Unfortunately, none of these are the modern ANSI layouts we're used to.
The only two boards that have that board are the Filco Zero and Ducky 1087XM. The Ducky caps are really bad in my opinion; they're thin and low quality. The Zero caps are the standard Filco caps but with an Alps stem; problem is they're almost impossible to find.
Along with WFD's video, I also have some pictures from when I swapped cables in my Majestouch 2 here.
Bolt mod
Floss mod
Grease mod
65% mod
Layout changes
Floss mod for BS keyboards
Unfortunately I can't figure out what switches it uses. I did find out some background history here. It was made at the same time as the Alps Kidboard, and the company Brainworks actually made the Star Trek keyboard. Here is[url] a link from the catalog that sold the Nickelodeon keyboard. But no helpful hints about it being mechanical.
My best guess is that since it's a competitor to the Kidboard, it's some form of Alps, but I'm *totally* guessing. It's also priced at $69.99 as opposed to the $99 for the Kidboard. That might be a clue one way or another.
« Last Edit: Tue, 18 February 2014, 07:41:11 by CPTBadAss »
  • Cherry Peasant
  • keycult.com
« Reply #6313 on: Tue, 18 February 2014, 07:44:14 »
The Dell AT101W is a standard layout, no? (With stepped caps.)
What's the quality like on Matias' caps? You mentioned that he's theoretically running a group buy or making them available at some point in the future.
« Reply #6314 on: Tue, 18 February 2014, 08:03:36 »
Yes besides the caps lock it's standard. You can actually snip the step off, it just makes the cap look weird. Since the caps lock is stepped and is hard to replace, I would say it's not the standard ANSI. However, I really do like the AT101W caps.
I've actually never seen Matias' keycaps alone. They've always been on the keyboards. From what I remember, I liked the Matias' keyboards overall, keycaps included. You can check out the Matias schedule for aftermarket keycaps and their 60% Matias GB here.
  • Cherry Peasant
  • keycult.com
« Reply #6315 on: Tue, 18 February 2014, 08:12:25 »
Great, thanks CPT!
« Reply #6316 on: Tue, 18 February 2014, 10:31:32 »
Are there any US cable makers left?
« Reply #6317 on: Tue, 18 February 2014, 10:33:32 »
tjcaustin's MiMiC Cables
« Reply #6318 on: Tue, 18 February 2014, 10:33:55 »
Can't buy from TJ he blocked me  ::)
« Reply #6319 on: Tue, 18 February 2014, 10:35:04 »
TheFlyingRaccoon is making cables for Bunnylake's Ctrl Alt Store.
« Reply #6320 on: Tue, 18 February 2014, 10:36:13 »
Yeah only for those sets. He doesn't have time for other stuff.
I'll just buy a cable off ebay.
« Reply #6321 on: Tue, 18 February 2014, 10:48:09 »
TJ blocked you on mimic-cables.com too? Should still be able to order from the website there.
« Reply #6322 on: Tue, 18 February 2014, 10:49:38 »
Now why would I do that? If I can't PM a vendor on geekhack and ask them questions about a product I would like to purchase then why bother.
« Reply #6323 on: Tue, 18 February 2014, 10:50:43 »
Now why would I do that? If I can't PM a vendor and ask them questions about a product I would like to purchase then why bother.
It was a suggestion. No need to be defensive.
« Reply #6324 on: Tue, 18 February 2014, 10:56:24 »
/Back on topic.
Many modern PC's don't have PS2 and the PS2 port on my workstation's PS2 port is in an awful location.
I realize that the G80-3700 needs to be connected through the PS2 interface to program but is there some sort of adapter that would make USB work for this?  I know two different protocols etc but I've seen magic happen around here.
« Reply #6325 on: Tue, 18 February 2014, 11:01:47 »
If you program it on PS/2 first then use a PS/2 to USB adapter, does it lose it's programming? I'm not 100% on how the 3700 works. If not, you could just program it then use the adapter. Or maybe you can find a PS/2 to USB cable like how the Orihalcon cables are. Otherwise wouldn't a Teensy conversion work as well?
Offline Melvang
« Reply #6326 on: Tue, 18 February 2014, 11:04:51 »
Does the entire board need to be desoldered on the Ducky full size non back lit to clip the stabs?  Or does it have the cut outs so you can remove it just by desoldering those couple switches?
« Reply #6327 on: Tue, 18 February 2014, 11:11:16 »
I have a Ducky in my apartment right now that I could take apart to look at. I'll look at it tonight. But since I'm forgetful, PM me if you don't see a post on this by tomorrow. Hopefully someone else knows though ^__^.
Offline Melvang
« Reply #6328 on: Tue, 18 February 2014, 11:14:34 »
Will do Cpt.  The board is in MN right now and I live in IA so I can't really just take a quick look.
« Reply #6329 on: Tue, 18 February 2014, 11:18:25 »
Melvang what model year is it? The newer boards are coming with clipped stabs according to laffindude.
Offline Melvang
« Reply #6330 on: Tue, 18 February 2014, 11:24:43 »
I bought it last fall
« Reply #6331 on: Tue, 18 February 2014, 11:41:36 »
Ok it was one of the ducky boards with thick pbt caps right?  i'm not sure what those have. :(
« Reply #6332 on: Tue, 18 February 2014, 12:03:12 »
Ray, Laffindude says the clipped stabilizers go forward from his post. So does that mean the Shine 3s only have clipped stabilizers starting in Winter of 2013? I'm not sure. And the post only pertains to the Shine 3. If Melvang has a nonbacklit Ducky, then it wouldn't be a Shine model.
« Reply #6333 on: Tue, 18 February 2014, 12:06:32 »
^^ yeah i dunno, i've only got a shine 2
And I'm assuming all shine 3's and any models released since they were released will have the factory clipped stabs.
Offline Melvang
« Reply #6334 on: Tue, 18 February 2014, 12:08:42 »
Offline Zaskar
« Reply #6335 on: Tue, 18 February 2014, 16:07:46 »
Curious if anyone knows what happens when you enable dip switch 4 and 5 together on a HHKB? (4 changes the meta key to a Fn key, and 5 swaps the meta and alt keys)
Does the Fn key replace the new or original meta key's spot? (Also does it replace both meta keys giving you a total of 3 Fn keys, or just the left one, leaving the right alone?)
« Reply #6336 on: Tue, 18 February 2014, 19:38:41 »
From what I saw on this Team OMG keyboard, which is a Ducky 2108S Zero Shine, and what I'm done on my KMAC I don't think that you can just desolder the switch and replace the stabilizer. The issue is the stabilizer wire and how it sits. I was able to tinker with my KMAC's spacebar stabilizers because it was at the edge of the keyboard so I could get tools inside. Because the backspace, enter, and shifts are slightly shifted away from the edges, it would be very hard to reset the wire I think.
Offline intelli78
« Reply #6337 on: Tue, 18 February 2014, 21:30:57 »
Approximately how many times can a set of doubleshot ABS caps be taken on and off a board before they'll start to get loose? Is it much different for other plastics? What variables, if any, affect the rate of wear?
« Reply #6338 on: Tue, 18 February 2014, 21:37:20 »
I don't remember where but I think we had an entire thread arguing about this once.
« Reply #6339 on: Tue, 18 February 2014, 22:07:00 »
The oldest model M plates and model F backplates. What treatment do they have to make them that awesome colour?
also:
just a guess, but probably a few hundred times at least. If you run into issues, you can up plastic bags and use them.
« Last Edit: Tue, 18 February 2014, 22:14:22 by dorkvader »
Offline Pacifist
  • on hiatus
« Reply #6340 on: Tue, 18 February 2014, 22:11:13 »
IIRC that thread was about how long the stem lasts on the switch not the cap.
Offline intelli78
« Reply #6341 on: Tue, 18 February 2014, 22:15:12 »
Sorry if I was unclear. I am indeed asking about stems.
« Reply #6342 on: Tue, 18 February 2014, 22:18:38 »
I'm guessing here, but it's probably from the heat applied to melt the plastic rivets, at least in the case of the M.
I can't think of a good reason for it on the F, unless it was some sort of heat application like happened to that droid in Jabba's palace when they tortured him by applying red hot irons to his feet.
« Reply #6343 on: Tue, 18 February 2014, 22:22:16 »
I think the discolourations around the rivets are because it's pre-drilled and then treated.
« Last Edit: Tue, 18 February 2014, 22:30:41 by dorkvader »
Offline Melvang
« Reply #6344 on: Tue, 18 February 2014, 22:49:27 »
That discolorations is distinctly from some from of heat treating.  My guess would be annealed to work with easier then hardened a bit to hold the shape.
« Reply #6345 on: Wed, 19 February 2014, 07:53:40 »
I'd agree with this. It definitely looks like a heat treat process.
I've had my Valentine's set since I started on Geekhack about a year ago. I've swapped it on and off different boards probably 10-20 times. I haven't had any issues with wear. I suspect it's negligible wear since you're only doing it say once a day.
If you really want, you can look up the material properties and then see what the durability, creep, and modulus of elasticity is. This will give you a general idea of how much wear and usage the material can take.
Dorkvader is saying you can use cut up plastic bags as shims if the caps become loose.
Links guys?
« Last Edit: Wed, 19 February 2014, 07:56:31 by CPTBadAss »
« Reply #6346 on: Wed, 19 February 2014, 08:16:34 »
Links guys?
I think this was one of them -> http://geekhack.org/index.php?topic=49060.0
I thought there was another but my search-fu is weak sauce this morning.
Offline intelli78
« Reply #6347 on: Wed, 19 February 2014, 09:26:46 »
Thanks for the info dudes  :thumb:
Offline yasuo
  • spanengan puyeng newbie
« Reply #6348 on: Wed, 19 February 2014, 11:09:13 »
What is keyboard using 4.5 spacebar?
Logitech MK220 Colemak DH
« Reply #6349 on: Wed, 19 February 2014, 11:21:16 »
Pure Pro. I believe this is the only keyboard that has this spacebar size.
