Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6231401 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8100 on: Sun, 01 June 2014, 03:42:36 »
What size wire is used for key pullers?
Offline asgeirtj
« Reply #8101 on: Sun, 01 June 2014, 04:26:59 »
I just lubed my stabilizer and now the stabilizer keys feel mushy, is it because I overlubed or is this normal?  I used http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
And if I overdid it, how long till it will feel good again? Or should i try and clean up the lube?
« Last Edit: Sun, 01 June 2014, 04:30:39 by asgeirtj »
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline phoenix1234
« Reply #8102 on: Sun, 01 June 2014, 04:41:17 »
May I know which kind of stabilizers you have?
I suppose you have Cherry Stabilizers, then maybe you need to use it awhile until it is break-in the high viscosity of Mech lube 1. If you lube it too much, then you may need to use a brush to clean it a bit.
I like linear switches
Offline maxtortheone
« Reply #8103 on: Sun, 01 June 2014, 05:12:56 »
Does Unicomp make black keycap sets any more? Can't find them on the site.
Keyboards: IBM Model M 122 Key Terminal Board;  Logitech G710+; Focus FK-2001 w/ Complicated ALPS
« Reply #8104 on: Sun, 01 June 2014, 05:25:31 »
http://pckeyboard.com/page/Buttons/KSET
Select Black from the dropdown.
Space bar extra: http://pckeyboard.com/page/Buttons/SB
« Reply #8105 on: Sun, 01 June 2014, 05:56:26 »
Awesome, thanks!
Also, does the PC122 dust cover go well on an IBM Model M 122 key?
« Last Edit: Sun, 01 June 2014, 08:02:05 by maxtortheone »
Offline asgeirtj
« Reply #8106 on: Sun, 01 June 2014, 08:14:08 »
I have mj2, they have costar stabilizers right?
Offline combataran
« Reply #8107 on: Sun, 01 June 2014, 08:28:23 »
Can someone explain what this means:
其实说到金属键盘,我之前也接触过一些,韩国基友的356mini也给我玩过2个月
但当时由于没有WIN键,FN层设置不符合我的习惯,所以基本上没有细细品味
最后导致2个月后,我总共才玩了1个小时不到…… 现在想起来真后悔啊
而后来的各次KMAC团购、456GT团购,以及基友出售的各种金属键盘
不是由于价格较贵、就是无WIN键,总之不符合自己的要求,所以没有去购买
由于我主要还是玩老原厂键盘,当时对金属键盘抱着可有可无的心理
对我来说,我需要一把86键,兼容原厂101键位RGB,带WIN键,356系列键盘
但反观所有356系列键盘,貌似从来就没有一款符合我要求的
而这个时候河马哥,大疯哥的LZ、KMAC系列,深深的感染了我
这个时候我决定,一定要弄一把接近我要求的金属键盘
虽然会有不习惯,虽然不会弄到最顶级的,但我可以慢慢去适应……
最后看准356mini,使用101键位的电路板,虽然不是80%,但满足大部分要求
其实这一款电路板是在356mini团购完毕后一年才推出的选购版本
主要区别就是兼容樱桃原厂101键位的RGB键帽,其他功能没有任何区别
但据说101键位版本的做工稍比104版本要稍微差一些,并且出售的量也够多
And before anyone says otherwise, yes, this is keyboard related.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Candyflip
« Reply #8108 on: Sun, 01 June 2014, 08:40:17 »
Yes.
« Reply #8109 on: Sun, 01 June 2014, 08:50:47 »
I have made several from the large size paper clips, but commercial ones have thinner wires. Maybe half the diameter of large paper clip wire. But small paper clips don't work because the wire is so flimsy, although they would fit between keys much better.
Pullers made from guitar strings used to be pretty popular.
I did not answer your actual question, sorry, I don't know.
- D Trump 2026-10-24
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8110 on: Sun, 01 June 2014, 08:52:44 »
I have a wire key puller. I will get a caliper on it later today and give you a Guage.
« Reply #8111 on: Sun, 01 June 2014, 08:56:29 »
Awesome, thanks!
I could not get it to show me a photo, but there are at least 3 different case styles of IBM M-122s, and Unicomps may be different, too. If you have a metal badge on the right, it is almost sure NOT to work.
« Reply #8112 on: Sun, 01 June 2014, 09:17:34 »
Hmm, I'll just shoot them an e-mail then.
« Reply #8113 on: Sun, 01 June 2014, 12:30:54 »
Basically, 356 mini is best keyboard, and all of the other metal keyboards suck in comparison.
And what are you doing on the Chinese forums?
Google translate?
Offline combataran
« Reply #8114 on: Sun, 01 June 2014, 14:03:19 »
Google translate?
Nah, just checking out some threads. What I wanted to know was the part about "兼容原厂101键位RGB" and "使用101键位的电路板". What does he mean by that?
Offline BsTyler
    • https://www.youtube.com/user/Durden391
« Reply #8115 on: Sun, 01 June 2014, 14:31:50 »
Hi guys just a quick one i have the http://gaming.coolermaster.com/en/products/keyboards/quickfireultimate/
brown switch ,i'm just wondering if the retro keycaps will fit in size?
http://techkeys.us/collections/keycap-sets/products/retro-set
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8116 on: Sun, 01 June 2014, 14:33:49 »
The bottom row won't fit.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8117 on: Sun, 01 June 2014, 14:34:06 »
Everything except for the modifiers. Someone correct me if I'm wrong those are 1.5x with 1x1
Offline BsTyler
« Reply #8118 on: Sun, 01 June 2014, 14:42:01 »
So the Ctrl", "Alt", "win" "Shift and Spacebar" won't fit  :( hmm
« Last Edit: Sun, 01 June 2014, 14:44:22 by BsTyler »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8119 on: Sun, 01 June 2014, 14:47:24 »
No, both shifts would fit. Only the bottom row wouldn't fit, e.g. spacebar, x2 Ctrl, x2 Winkey, Menu and x2 Alt.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8120 on: Sun, 01 June 2014, 14:49:27 »
on the retro set, the modifiers are all 1.25x. on the cm, the alt and ctrls are 1.50x , and the win's and fn are 1x1
Offline Melvang
« Reply #8121 on: Sun, 01 June 2014, 14:54:02 »
Thanks swill, actual dimension works better than gauge.  The site I get material from sizes by inch dimension.
Offline BsTyler
« Reply #8122 on: Sun, 01 June 2014, 15:02:08 »
Thanks @hwood34 and @epzy for quick reply.
« Reply #8123 on: Sun, 01 June 2014, 15:18:09 »
Just measured my TechKeys puller. The diameter I measured with my calipers is .035".
You probably overlubed your Costar Stabilizers. Take the keys off, and wipe away some of the lube.
If I understand correctly, he's basically saying it fits 1.5x Winkeyless RGB keycaps. Google translate gives me this translation:
101 key compatible with the original 101-bit keys using RGB and board
So he's saying it fits the original WKL RGB sets. 101 is Winkeyless, 104 is with Winkey.
For most questions Unicomp, it's usually best to email them with questions.
« Reply #8124 on: Sun, 01 June 2014, 16:16:09 »
If you end up finding a really good material, and buying a mile of it, there might be some of us who would gladly pay you a couple of bucks for a foot of it.
« Reply #8125 on: Sun, 01 June 2014, 17:07:25 »
Is the Apple M0116 any good?
Offline Melvang
« Reply #8126 on: Sun, 01 June 2014, 17:12:47 »
After you guys see what I have planned I am sure people would be willing to spend a touch more for a completed piece.  They will be truly unique.
And thanks CPTBadass for that dimension.
I will get some wire ordered.
Offline Dubsgalore
« Reply #8127 on: Sun, 01 June 2014, 17:13:42 »
If you can find one for £5, i'd say get it
« Reply #8128 on: Sun, 01 June 2014, 17:17:17 »
Why would I take your advice on alps?
Offline Dubsgalore
« Reply #8129 on: Sun, 01 June 2014, 17:19:16 »
Because Sprit has taught me the alps ways :]
« Reply #8130 on: Sun, 01 June 2014, 17:20:42 »
Ah, good enough for me.
« Reply #8131 on: Sun, 01 June 2014, 17:29:22 »
I liked the one I owned, I just didn't care for Salmon Alps and sold it. I really like the Apple Alps boards in general though. And the M0116 I bought was a really good price. I think I paid $15-20 shipped from eBay for it.
« Last Edit: Sun, 01 June 2014, 17:31:57 by CPTBadAss »
« Reply #8132 on: Sun, 01 June 2014, 17:36:10 »
Thanks for the input! :thumb:
« Reply #8133 on: Sun, 01 June 2014, 17:37:45 »
Oh I should also say I really liked the layout as well. And you're welcome. I sold it to fohat.digs who may also have some input as well if he seems this :D.
« Reply #8134 on: Sun, 01 June 2014, 19:05:35 »
I sold it to fohat.digs who may also have some input as well if he sees this.
I stripped it for the switches and keys. I just can't abide weird layouts, even on an 87 I am constantly reaching for the numpad. Especially numpad Enter, that is my most-used key over there.
My plan is to transplant switches and keys into a Dell AT101W (with infill from elsewhere, of course) to make something that I can really use with pleasure.
Offline combataran
« Reply #8135 on: Sun, 01 June 2014, 19:48:29 »
Thanks! So do the other OTD boards like the 456gt or the KMAC/2 support such layouts? Or is it just the 356mini?
« Reply #8136 on: Sun, 01 June 2014, 20:10:43 »
Most customs come in Winkeyless (WKL) or Winkey layouts. You can pick usually. WKL seems more popular. I didn't read the whole thing you posted. Usually 101 key = ANSI WKL and 104 key = ANSI winkey.
Offline Dubsgalore
« Reply #8137 on: Sun, 01 June 2014, 20:23:41 »
84 = WKL w/ blockers
86 = WKL w/o blockers
87 = Winkey
(for tkl)
Offline combataran
« Reply #8138 on: Sun, 01 June 2014, 20:44:27 »
I'll make this easier for you cap: http://www.pcwaishe.cn/thread-460297-1-1.html
I just need to know why he chose the 356mini over the other OTD boards(except the 456gt). He has both plus a KMAC 2 but the mini is what I'm interested in.
« Reply #8139 on: Sun, 01 June 2014, 20:45:30 »
Why am I reading the thread for you? That's not making it easier for me. Here's the thread in through Google Translate. Does that help you?
Edit: yab says in the beginning why he likes the 356 mini. He likes the layout of the 356 mini over the KMAC2.
Because the price is not expensive, is no WIN key, short does not meet their requirements, so did not go to buy
Since I mainly play the old original keyboard when holding the metal keyboard dispensable psychological
For me, I need a 86 keys, compatible with the original 101 key bits RGB, with WIN buttons, 356 Series Keyboard
« Last Edit: Sun, 01 June 2014, 20:49:22 by CPTBadAss »
Offline Dubsgalore
« Reply #8140 on: Sun, 01 June 2014, 20:53:40 »
Just an FYI, yab8433408 aka Dragonbro is one of the longest active, most experienced, highest end users for mechanical keyboards in the world, any kustom you can think of he probably has possession of..
Also, if you're just asking for translations here in this thread, it's probably not the best place honestly
« Reply #8141 on: Sun, 01 June 2014, 21:03:10 »
He's the guy with the insane Cherry switch collection too, I believe.
Right, unless there's a person who speaks really good Chinese *and* English and is actively reading this thread, you're not going to get a really accurate answer other than what I can glean from Google Translate.
Offline Dubsgalore
« Reply #8142 on: Sun, 01 June 2014, 21:10:25 »
ya ya
all actually from cherry corp I believe, mx mount and alps mount
Offline combataran
« Reply #8143 on: Sun, 01 June 2014, 21:13:25 »
Actually I'm fluent in 5 different languages, including Chinese. Reading the thread wasn't the problem for me, understanding what the terms meant was. Plus, Google Translate can't understand context, so there's that.
This should be:
It's either too expensive, or because it's WKL, they don't satisfy my personal (keyboard)needs, that's why I didn't get them. And since I usually only go for old(?, I'm guessing vintage) cherry boards, it didn't matter whether I had custom aluminium boards or not.  As for me, I just need a 86key board that's able to fit original 101key RGBs, not WKL and from the 356 series. But looking at most of them, none fit the description.[/qoute]
Wait, did I just answer my own question? What are the RGB sizes for a 101 US standard layout?
« Last Edit: Sun, 01 June 2014, 21:15:46 by combataran »
« Reply #8144 on: Sun, 01 June 2014, 21:19:35 »
I can't read Chinese so I can't find the terms for you...it would really help if you could just isolate the terms you needed help with them post them instead of having me read a whole thread in a language I can't read and then is ruined with Google Translate.
1.5x
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8145 on: Sun, 01 June 2014, 21:22:17 »
Sorry for the delay.  I got a measurement of .8mm on the wire on my filco puller.  That would be 0.0315" in standard.
Offline combataran
« Reply #8146 on: Sun, 01 June 2014, 21:34:29 »
No worries, I'll keep that in mind next time. Thanks for trying.  :thumb:
« Reply #8147 on: Sun, 01 June 2014, 21:37:58 »
It's not that I don't want to help you. It's that I literally can't read the language :(
« Reply #8148 on: Sun, 01 June 2014, 23:41:46 »
Can anyone identify this terminal keyboard?
« Reply #8149 on: Mon, 02 June 2014, 07:52:00 »
I'll take a wild guess that it's a Honeywell or a IBM beamspring board. I have no substantiation for that guess at all.
