Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6231795 times)
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8250 on: Sun, 08 June 2014, 05:34:48 »
Is there enough clearance for a foam sheet under the Filco pcb, and do I have to desolder everything if I wanted to lube, respring and sticker the switches(of the Filco)?
1. No idea.
2. Yes.
Offline ajx
« Reply #8251 on: Sun, 08 June 2014, 09:26:28 »
http://www.ebay.fr/itm/Pure-60-Programmable-Mechanical-Keyboard-Red-MX-Switch-/331057414849?pt=LH_DefaultDomain_0&hash=item4d148f42c1
Stock-on Keycaps: ABS (OEM profile)
Does it mean lettering could be an issue with wearing off?
Not particular true, in my case, i got Poker X and Pure, and on both, some letters wore off quite quickly
Those stock keycaps are pad-printed and may-or-may-not have as issue with the legends wearing depending on a number of factors.
Lettering from my Poker X keycaps wore off after couple days
I have hands that get quite often greasy and sweaty
is there any level of ABS except for lettering etching mode?
Offline exitfire401
  • The Force is Re/\l
« Reply #8252 on: Sun, 08 June 2014, 09:29:24 »
In your case, I would look for double shot caps. The legends are a separate shot of plastic in the mold, so you'll have to wear the caps down to nothing before the legend disappears.
Offline ajx
« Reply #8253 on: Sun, 08 June 2014, 09:38:30 »
Thanks but i would stay on ABS which i love feeling lol.
ABS shinning issue doesnt bother me as long as lettering doesnt wear.
By the way, i dont have enough budget to get double shot caps.
« Reply #8254 on: Sun, 08 June 2014, 09:40:24 »
Lasered ABS is probably the way to go then. It won't wear for quite a while and is cheap.
Offline minho
  • i'm kind of back
« Reply #8255 on: Sun, 08 June 2014, 09:42:06 »
Double shot ABS can be found for pretty cheap through Taihao group buys. You can post on classifieds for them or join the ongoing Taihao dolch group buy if you're willing to wait.
« Reply #8256 on: Sun, 08 June 2014, 10:07:46 »
1) Is there enough clearance for a foam sheet under the Filco pcb
2) Do I have to desolder everything if I wanted to lube, respring and sticker the switches(of the Filco)?
1) Yes
2) Yes
You can try looking for Tai Hao ABS doubleshots. I think Keypop still has some but they pop up in the Classifieds. They're usually around $10-20 for the set.  Fits your budget and your needs.
« Last Edit: Sun, 08 June 2014, 10:10:46 by CPTBadAss »
Offline combataran
« Reply #8257 on: Sun, 08 June 2014, 11:03:03 »
And can a 38gt+alu plate combo from GON fit into a stock Poker 2 case?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
« Reply #8258 on: Sun, 08 June 2014, 12:59:56 »
Think so but I'm not sure. Would be a waste to do that though imo.
Offline cphead
« Reply #8259 on: Sun, 08 June 2014, 14:19:22 »
Hi guys. This black thing on the pcb came off through an unfortunate series of events.  :( What is it and how can I go about replacing it? I'm guessing its a resistor or diode of some sort? Thanks for any help  :)
« Reply #8260 on: Sun, 08 June 2014, 14:20:59 »
It was a diode. It looks like you maybe able to solder another one on if you're careful but someone else might have better insight than I do. I'm not that knowledgeable about SMD components.
Offline Pacifist
  • on hiatus
« Reply #8261 on: Sun, 08 June 2014, 14:21:08 »
Originative has their taihao in stock but you know...its originative
Offline BlueBär
« Reply #8262 on: Sun, 08 June 2014, 14:37:17 »
There's also a GB still going on afaik.
« Reply #8263 on: Sun, 08 June 2014, 14:38:17 »
I have a very important question. I have a $50 Visa card. Do I use it to buy a next level fountain pen or invest in a set of keycaps. SOMEONE HELP ME SPEND MY MONEY :3
« Reply #8264 on: Sun, 08 June 2014, 14:41:30 »
Put it towards keycaps. Who needs to write when you can type?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8265 on: Sun, 08 June 2014, 14:41:30 »
Give it to me :p
Offline BlueBär
« Reply #8266 on: Sun, 08 June 2014, 14:41:37 »
Now for a few rules:
  • This is not a sale/trade thread. Please use the Classifieds or PMs to handle that kind of business.
  • Please try and ask yes/no questions or questions that can be answered in a single post or two
  • Please don't ask about prices, we have a thread for that already.
  • Please try and quote the question you're answering. This thread is now big enough that multiple questions and answers are being asked at once and it can get confusing.
  • Please try to limit the discussions here, we have countless other threads and places to discuss. I'd like to keep this thread true to its title. Sorry if I stifle the discussion from time to time
  • Please don't bump your question. I know I'm usually fast with answers (or someone else is fast), but if you don't get an answer in an hour, just be patient. I might actually be doing researching/digging and you might not even know. I think the longest someone waited for an answer is 3-4 days. Just wait or PM me.
  • Please don't post memes or gifs in this thread
  • Please keep this keyboard (keyboards, keycaps, springs, mods, soldering, etc) related.
  • Please don’t bicker in this thread. I will have it cleaned up if I feel it’s needed.
« Reply #8267 on: Sun, 08 June 2014, 14:42:29 »
Wow Bluebar, you could've just said keycaps. :(
Offline BlueBär
« Reply #8268 on: Sun, 08 June 2014, 14:43:50 »
But I've always wanted to do this :3
« Reply #8269 on: Sun, 08 June 2014, 14:44:24 »
I should use that $50 to buy you some manners.
Offline BlueBär
« Reply #8270 on: Sun, 08 June 2014, 14:49:19 »
You should use those 50$ for a large print of your own thread's rules! >:D
« Reply #8271 on: Sun, 08 June 2014, 15:04:15 »
Guys, guys, put them away, we already have a winner:
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
« Reply #8272 on: Sun, 08 June 2014, 15:12:07 »
Where can I find a cherry profile 7x spacebar that will match a Desko set that I ordered from IMSTO. Been lookign everywhere but I cannot seem to fine one. Thanks!
Offline Pacifist
  • on hiatus
« Reply #8273 on: Sun, 08 June 2014, 15:16:17 »
Pretty much the only way to get it would require getting a complete set, Cheapest is get an DE iso dyesub set, usually for $85+
Offline intelli78
« Reply #8274 on: Sun, 08 June 2014, 16:45:02 »
Pacifist, what about the MX11800 spacebar that we discussed previously? It's a great match with BSP/OG.
Offline Pacifist
  • on hiatus
« Reply #8275 on: Sun, 08 June 2014, 16:50:08 »
color is off
Offline intelli78
« Reply #8276 on: Sun, 08 June 2014, 17:09:33 »
Well, Pacifist is right that the color is not an exact match, but it's pretty close. Here are a couple pics of an MX11800 spacebar on top of Cherry dyesubs. First pic no flash, second pic has flash. Under most normal lighting conditions, I think most people wouldn't notice the mismatch unless you called attention to it. The color difference is more exaggerated in pics than in real life, I'd say. That said, if you can get German dyesubs for only a little more money, you might want to do that.
Offline Pacifist
  • on hiatus
« Reply #8277 on: Sun, 08 June 2014, 17:15:44 »
If you put the 11800 bar on a dyesub set with RGB, its not as noticeable, but pure black on white is quite visible imo
Offline combataran
« Reply #8278 on: Sun, 08 June 2014, 18:59:44 »
Why is that?
Offline intelli78
« Reply #8279 on: Sun, 08 June 2014, 19:04:04 »
Because why would you want to put a premium GON PCB into a crappy plastic Poker case?  :(
Offline BlueBär
« Reply #8280 on: Sun, 08 June 2014, 19:04:20 »
Why is that?
A Korean PCB in a plastic stock case? You should rather invest in the case instead in the PCB imho.
« Reply #8281 on: Sun, 08 June 2014, 19:04:28 »
Why is that?
Fancy custom PCB, fancy plate, stock plastic case.
Offline combataran
« Reply #8282 on: Sun, 08 June 2014, 19:53:38 »
Does the case really make that much a difference?
Offline Pacifist
  • on hiatus
« Reply #8283 on: Sun, 08 June 2014, 20:00:20 »
yes
Offline minho
  • i'm kind of back
« Reply #8284 on: Sun, 08 June 2014, 20:07:50 »
A big part of why GON's keyboards are so attractive is because of the cool lighting effects underneath the keyboard, which would be completed eliminated by a Poker case. Additionally, what is the point in spending a premium price on a keyboard if it basically has the same aesthetics and functionality as the $100 Poker?
Offline BlueBär
« Reply #8285 on: Mon, 09 June 2014, 03:54:22 »
I would even say that the case is the most important part of a custom keyboard.
« Reply #8286 on: Mon, 09 June 2014, 07:43:10 »
Yup, if you're going to be picking between that GON PCB in a plastic case and a Poker 2, might as well just get a Poker 2 and save yourself the hassle. For me, the point of having a custom is having a nice PCB *AND* a nice case. Otherwise I can just stick with Filcos and Duckys and the like.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8287 on: Mon, 09 June 2014, 09:07:34 »
fountain pen of course or ink................ :thumb:
http://www.shopwritersbloc.com/noodlers-eel-lubricating-ink-eel-cactus-fruit.html
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #8288 on: Mon, 09 June 2014, 11:56:58 »
My package arrived at Tenso and I paid the fees.
Anyone know how long it generally takes to get here? I live in NYC if that helps.
« Reply #8289 on: Mon, 09 June 2014, 11:59:42 »
Tenso's site says 2-4 days after Tenso gets the package. Seems pretty fast. I've never used them before so I have no personal experience with it.
« Reply #8290 on: Mon, 09 June 2014, 16:28:46 »
I use Tenso all the time to get dem Japanese snacks
nothing but good experiences
it's pretty quick for what it is, too
« Reply #8291 on: Mon, 09 June 2014, 16:36:26 »
What's your experience for "pretty quick"? 4 Days? Lightspeed?
« Reply #8292 on: Mon, 09 June 2014, 18:54:50 »
2 days from when they get my stuff it's usually on it's way to me
then it's maybe 5 more days to me
Offline Pacifist
  • on hiatus
« Reply #8293 on: Mon, 09 June 2014, 18:59:55 »
**** that's fast. I'm going to try it out for some mousepads
« Reply #8294 on: Mon, 09 June 2014, 19:00:28 »
Got it, Tenso = lightspeed from Japan.
Offline Pacifist
  • on hiatus
« Reply #8295 on: Mon, 09 June 2014, 20:12:16 »
How far do we need to clip the stems on pcb switches to be able to use on plate without any issues?
« Reply #8296 on: Mon, 09 June 2014, 20:12:56 »
So they sit right? Just try it out. It doesn't need to be an exact measurement...
Offline Pacifist
  • on hiatus
« Reply #8297 on: Mon, 09 June 2014, 20:15:26 »
I don't have any non PCB mounted boards to test it out. When I clip them, there's probally 2 mm sticking out, and if I focus the stump, it goes to .75mm
« Reply #8298 on: Mon, 09 June 2014, 20:20:25 »
Clip it so it's flush with the bottom of the switch?
Offline Dubsgalore
« Reply #8299 on: Mon, 09 June 2014, 22:26:27 »
The grips on my HASRO are absolutely gone. Anyone know of any good replacement grips for keyboards? small enough to not make the keyboard slanted or anything..just to add a little grip underneath
