Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230974 times)
« Reply #8500 on: Wed, 18 June 2014, 21:04:59 »
TOP 1 LMFAO
Okay okay serious question:
I been working with PCB mount cherry stabs a lot, and whenever they reach my customer the bar always ****ing comes loose from the part they're supposed to clip into. Do I have a bad batch or am I retarded or what?
I believe this has happened on 3 occasions.
EDIT: Might not be so simple... but didn't want to make a thread for it
« Last Edit: Wed, 18 June 2014, 21:07:15 by Sifo »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #8501 on: Wed, 18 June 2014, 21:58:59 »
TOP 1 LMFAO
My PCB mount stabs kept popping out too.  Solved it by cutting up a small plastic card and wedging it in the foot to keep it spread open and locked.
« Reply #8502 on: Wed, 18 June 2014, 22:00:07 »
You might have put the inserts in backwards? I found that they stay put on one side and tend to fall out on the other.
« Reply #8503 on: Wed, 18 June 2014, 22:12:40 »
No no no guys not the black pieces, the bar keeps falling out even though I secure them both sides into the clip thing.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #8504 on: Wed, 18 June 2014, 22:51:20 »
Even if it is snapped into the part circled in red, the bar still falls out?
Offline phoenix1234
« Reply #8505 on: Wed, 18 June 2014, 23:21:20 »
TOP 1 LMFAO
I faced this one at least twice, especially for the ones were rusty so I need to use sand-paper to clean them. I think after I sanded them, the wire bars get smaller so they tend to loose out. So for your case, I think you need to check the diameter of the bar. It should be around 1/15-1/16 inch ~ 1.7-1.6mm
I like linear switches
Offline Lain1911
  • God of the Wired
« Reply #8506 on: Thu, 19 June 2014, 01:19:43 »
Is it unusual to have upside down switches on a stock keyboard? Example: my QFR window and alt key on the left side has the led placement on top and CHERRY is upside down. All other caps are right side up.
Offline Pacifist
  • on hiatus
« Reply #8507 on: Thu, 19 June 2014, 01:23:34 »
nowadays some boards do that for some reason....
Offline BlueBär
« Reply #8508 on: Thu, 19 June 2014, 05:50:06 »
Some manufacturers do this to have the LEDs towards the top, and iirc on the GH60 Rev. A this was used to make some traces easier.
Offline ideus
  • Björkö.
« Reply #8509 on: Thu, 19 June 2014, 08:52:22 »
Do PCB-mounted Cherry stabilizers have the same design than plate-mounted ones?
Offline BlueBär
« Reply #8510 on: Thu, 19 June 2014, 09:25:42 »
Parts of it (slider, wire) are identical to the plate mounted ones but the base is different.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8511 on: Thu, 19 June 2014, 09:26:04 »
No.  They can't be use in place of each other.  PCB mount will not fit through the holes in a plate meant for plate mount, and plate mount stabilizers will not clip to the board.  There is however a hole design that will allow for both plate mount cherry and Costar which is plate mount only.  Alps stabilizers are all (that I have seen) plate mount as well.  Plus, I have yet to see anything with PCB mount Alps switches but I doubt it will happen due to the design of the switch.
Offline kakakowie
  • Make Love not War
« Reply #8512 on: Thu, 19 June 2014, 09:33:33 »
How do I calculate required resistor values for leds when building a keyboard?
I should have to take into account the number of leds and their voltage? Are there other factors? Is it safer just to go higher?
Offline ideus
  • Björkö.
« Reply #8513 on: Thu, 19 June 2014, 09:36:54 »
Where I can get PCB mount stabilizers?
Offline BlueBär
« Reply #8514 on: Thu, 19 June 2014, 09:38:32 »
In the OP.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8515 on: Thu, 19 June 2014, 09:43:46 »
Contact YUIOP. :)
Offline phoenix1234
Offline ideus
  • Björkö.
« Reply #8517 on: Thu, 19 June 2014, 09:44:00 »
In the OP.
I just found this, anyone has experience with them?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8518 on: Thu, 19 June 2014, 09:46:54 »
In the OP.
You'll have to pay $9 + $25 shipping for those. YUIOP will sell some to you for $12 shipped CONUS.
http://geekhack.org/index.php?topic=56052.0
« Reply #8519 on: Thu, 19 June 2014, 09:50:21 »
Though I love GON, shipping from Korea is nuts
listen to epzy
« Reply #8520 on: Thu, 19 June 2014, 09:52:30 »
1) How do I calculate required resistor values for leds when building a keyboard?
2) I should have to take into account the number of leds and their voltage? Are there other factors? Is it safer just to go higher?
1) Ohm's Law
2) Check out this thread
Offline Pacifist
  • on hiatus
« Reply #8521 on: Thu, 19 June 2014, 11:25:40 »
Where can I find a list of all the badges?
« Reply #8522 on: Thu, 19 June 2014, 11:28:19 »
Badges?
I don't follow
Offline intelli78
« Reply #8523 on: Thu, 19 June 2014, 12:39:08 »
What are the differences between Lightsaver v1 and v2?
Offline Pacifist
  • on hiatus
« Reply #8524 on: Thu, 19 June 2014, 12:42:58 »
the case
« Reply #8525 on: Thu, 19 June 2014, 12:43:31 »
the case
That's great.
What's different about the case?
« Reply #8526 on: Thu, 19 June 2014, 12:55:28 »
the case
That's great.
the shape  :blank:
Offline asgeirtj
« Reply #8527 on: Thu, 19 June 2014, 17:04:35 »
I have SP doubleshots caps without crossbars.  This is a big problem since the crossbar on other keycaps they uniform the length from the o-ring.  For example for number row I put two 1.5 mm thick o-rings with no dampening or shortening effect and putting on the 3rd the damp kicks in but the shortening effect is huge and too much.  This is a big problem.  Anyone has a solution for this?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #8528 on: Thu, 19 June 2014, 17:30:33 »
What badges are you referring to.
Think the V1 came in both acrylic and metal. V2 only came in metal and has some PCB updates and case design updates. You can check out more info:
- Duck0113's website on the Lightsavers
- Post your Lightsaver thread, seems to focus on V1
- Lightsaver V2 GB
Could try designing some 3D printed inserts that act like crossbars and get them printed at Shapeways or try combining EK's soft-landing pads with them. You can also try and find rubber mats and punching out spacers similar the to the o2dazone HHKB mod but have them fit for MX.
Offline acalora
« Reply #8529 on: Thu, 19 June 2014, 21:51:20 »
Just curious, what does everyone think about scooped F and J keys vs nubbed? I've heard only good things about scoops so far, what do you guys think?
Offline Pacifist
  • on hiatus
« Reply #8530 on: Thu, 19 June 2014, 21:52:07 »
I love scoops
« Reply #8531 on: Thu, 19 June 2014, 21:52:37 »
Despite my name, scoops are easier to find and use for me.
« Reply #8532 on: Thu, 19 June 2014, 21:56:38 »
the case
Honestly, you're better off saving the time and letting someone else answer the questions in here.
Like this guy.
- Lightsaver V2 GB
« Reply #8533 on: Thu, 19 June 2014, 22:49:44 »
Enough. You all are the prettiest princess.
Offline Melvang
« Reply #8534 on: Fri, 20 June 2014, 07:51:56 »
What sizes of stabilizer wires are the most difficult to purchase a la cart?  Assuming standard sizes of 2u, 6.25, and 7u.  Looking for answers in both cherry and costar.
« Reply #8535 on: Fri, 20 June 2014, 07:57:12 »
6.25x and 7x have been hard to find for Cherry wires. Costar 6.25x can be found on WASD, not sure about 2x and 7x. I haven't looked at buying Costar wires outside of WASD or the classifieds.
Offline Melvang
« Reply #8536 on: Fri, 20 June 2014, 08:00:08 »
Thanks for the info.  I figured if I was going to make wires I should make the ones that can't be found or are difficult/ expensive to ship.  At least cherry wires are easier but tighter tolerance on bend location.
« Reply #8537 on: Fri, 20 June 2014, 09:56:38 »
You're exactly right concerning the Cherry wires being easier to bend, but tighter on the tolerance of the bend location.
Cherry wires are easy to find in 2x sizes; somewhat rare at the moment, but available in 7x and 8x sizes; and almost nonexistent in 6.25x.
Costar have only ever been available for purchase in 6.25x size. All 7x Costar wires in existence have been custom bent.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8538 on: Fri, 20 June 2014, 11:26:31 »
I got 6.25 and 7 (as well as a bunch of 2) unit cherry wires with my 5 piece sets from Sprit.
Offline frosty
  • jukebox hero
« Reply #8539 on: Fri, 20 June 2014, 11:54:04 »
what is wet sanding? any tutorials/guides for it?
what painting method should i use if i just want to paint my keyboard to a solid colour?
painting guide that is very very detailed?
solder sucker + soldering iron to desolder 87 switches, my first project, am i being ambitious?
Offline xavierblak
« Reply #8540 on: Fri, 20 June 2014, 11:58:45 »
You'll probably have to try them yourself. I thought I'd like scoops before I tried them but after I did I found out I preferred nubs.
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #8541 on: Fri, 20 June 2014, 12:37:26 »
Photoelectric has got you covered for a painting guide, check this thread: http://geekhack.org/index.php?topic=44191
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline minho
  • i'm kind of back
« Reply #8542 on: Fri, 20 June 2014, 13:03:17 »
Not really - just make sure your iron isn't too hot that you burn off the solder pads, and don't heat the PCB too long or you could run into that problem (I accidentally did this :()
« Reply #8543 on: Fri, 20 June 2014, 13:05:56 »
1) what is wet sanding? any tutorials/guides for it?
2) solder sucker + soldering iron to desolder 87 switches, my first project, am i being ambitious?
1) Wet sanding is putting water on a part then sanding the part with sand paper. I'm sure YouTube has lots of videos on it but it's pretty self explanatory.
2) Not at all. That was my first project in keyboards as well. There's a lot of good information on this site, such as the living soldering thread and WhiteFireDragon's videos, as well as on YouTube.
I prefer nubs or the little lines over scooped F and J. I find I can't locate the homerow as fast with the scoops. However, GMK/Cherry caps feel so good I just put up with scoops.
Don't worry! You're not the first or last person to pull pads or burn your PCB!
« Reply #8544 on: Fri, 20 June 2014, 13:07:31 »
I prefer nubs or the little lines over scooped F and J. However, GMK/Cherry caps feel so good I just put up with scoops.
I agree with this
The only reason I use scoops is because I love GMK
« Reply #8545 on: Fri, 20 June 2014, 13:08:10 »
skoops4lyfe
Offline intelli78
« Reply #8546 on: Fri, 20 June 2014, 13:22:06 »
Here are a few tips I wish someone had given me before my first desoldering project:
- If it's a dual sided, thick PCB, leave the tip of the iron on the joint for a full 1-2 seconds (with temp around 600f) to ensure all of the solder liquifies. This will make it suck out much easier.
- If you are having trouble with a joint, heat it and add fresh solder, then attempt to remove again. works much better.
- You will probably have many switches where you remove 95% of the solder, but one or two of the pins are still stuck to the pad by a tiny amount of solder (again, mostly with double sided PCBs). If this happens, use the hot iron tip to free the pin while you pull the switch from the other side. If you're unlucky, two pins may do this at once, and you'll have to go back and forth between them. Just don't use force, or you'll pull out the copper trace and have a bigger problem.
Of course, if anyone wants to suggest even better techniques than these, go for it.
« Reply #8547 on: Fri, 20 June 2014, 13:24:14 »
I watched WFD's videos like twice before I did my project and learned what you mentioned from the videos. There's one where he does an ergo-clear mod which was extremely helpful.
« Reply #8548 on: Fri, 20 June 2014, 13:33:15 »
Those are good tips. You should post that in The Living Soldering Thread. I'm sure we have said those things there before, but a reminder is always good.
Offline intelli78
« Reply #8549 on: Fri, 20 June 2014, 13:39:01 »
I'll have to check those out. I got the fresh solder tip from mkawa, the others were trial-and-error whilst borking my Kingsaver PCB. No regrets though, the experience (and exp from repair job) was invaluable.
On that note, I'll add one other thing. You should expect to have some f'ups on this keyboard. It's fairly likely you will lift a pad or two or damage a trace. If that happens, the most important thing is just to NOT MAKE IT WORSE and just keep your cool. If you start getting frustrated, just set it down, come to GH for some advice, and return once you are focused again. You'll be able to repair your f'ups as long as you don't compound them by making angry soldering mistakes.
If you can't handle the idea of having some bubus on this keyboard, you better find another one to practice with first.
Roger that, will do it now
« Last Edit: Fri, 20 June 2014, 13:41:01 by intelli78 »
