Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230224 times)
0 Members and 9 Guests are viewing this topic.
Offline Pacifist
  • on hiatus
« Reply #8750 on: Tue, 01 July 2014, 17:05:23 »
ducky quality is defintly way better than keycool. But keycool is dirt cheap
Offline Vitaly
« Reply #8751 on: Tue, 01 July 2014, 17:13:58 »
Usually thick PBT is considered better.
Where I can buy thick keycaps? Tried to find but out of stock.
« Reply #8752 on: Tue, 01 July 2014, 17:15:24 »
You wanna try and find IMSTO keycaps for thick PBT. Or anything cherry profile.
Offline Vitaly
« Reply #8753 on: Wed, 02 July 2014, 02:03:23 »
Thanks, sent message to IMSTO, maybe he have blank pbt in stock
Offline FrostyToast
  • Litshoard
« Reply #8754 on: Wed, 02 July 2014, 14:00:57 »
Where can I get some screws, nuts, and washers for a Model M bolt mod?
Quote from: elton5354
« Reply #8755 on: Wed, 02 July 2014, 14:02:18 »
McMaster-Carr or Fastenal. Here is the wiki article.
« Last Edit: Wed, 02 July 2014, 14:03:49 by jdcarpe »
« Reply #8756 on: Wed, 02 July 2014, 14:04:01 »
McMaster-Carr or Fastenal. Let me get you some part numbers...
For McMaster-Carr, check out this link.
Edit: Jinx on jdcarpe's ninja-edit!
« Reply #8757 on: Wed, 02 July 2014, 14:04:36 »
Dat ninja edit... :D
Offline FrostyToast
  • Litshoard
« Reply #8758 on: Wed, 02 July 2014, 16:13:46 »
I ordered from McMaster a while back, however they said that they couldn't deliver to people unless they were a company or something along those lines.
« Reply #8759 on: Wed, 02 July 2014, 16:15:09 »
I order from them all the time. You just use a credit card, and where it says Company on the shipping address, put your full name.
Offline Pacifist
  • on hiatus
« Reply #8760 on: Wed, 02 July 2014, 16:25:07 »
Is it possible to handmake traces in clear acrylic or other see through materials as a PCB?
« Reply #8761 on: Wed, 02 July 2014, 16:39:00 »
I don't see why not. It would be harder though since it's not conductive so your traces would have to be solid. You'd get this translucent PCB with little copper/metal traces in it. Could always do a simple test by taking one of those conductive pens, drawing on some plastic, then seeing if the multimeter would pick up a connection.
That being said, my forte is *not* in electronics or electrical engineering so YMMV.
Offline Smasher816
  • HHKB Master
« Reply #8762 on: Wed, 02 July 2014, 18:14:58 »
Offline minho
  • i'm kind of back
« Reply #8763 on: Wed, 02 July 2014, 19:03:04 »
Does anyone know if the KUL ES-87 PCB is backlighting compatible? Has anyone added backlighting to it before?
« Reply #8764 on: Wed, 02 July 2014, 19:03:25 »
IIRC it's not but I'll have to look again
« Reply #8765 on: Wed, 02 July 2014, 19:06:12 »
Nope, it's not. But backlighting is for plebes anyway. :P
Offline Pacifist
  • on hiatus
« Reply #8766 on: Wed, 02 July 2014, 19:36:11 »
Can somebody identify the caps here?
Base is DE
Top row starts at 13-24, don't know from where
Numpad has blue legends, also don't know what
Looks like GMK for the RGB and the enter
Offline phoenix1234
« Reply #8767 on: Wed, 02 July 2014, 23:36:36 »
Base is DE
Top row starts at 13-24, don't know from where => It should be from Cherry MX 2550 HPD
Numpad has blue legends, also don't know what => It should be from Olivertti German layout the same Cherry MX 2550 HPD, DE layout - Cherry Double Shot
« Last Edit: Thu, 03 July 2014, 00:17:46 by phoenix1234 »
I like linear switches
Offline Eszett
« Reply #8768 on: Thu, 03 July 2014, 01:11:11 »
What acutally is the HID Liberation Device? Is it a product of some company? An industry standard? I don’t get it.
« Last Edit: Thu, 03 July 2014, 01:13:21 by Eszett »
« Reply #8769 on: Thu, 03 July 2014, 01:12:26 »
What is an HID Liberation Device? A product from a company? A industry standard? I don’t get it.
It's a custom fully programmable controller designed by bpiphany for TKL Filcos.
Offline do_Og@n
« Reply #8770 on: Thu, 03 July 2014, 01:13:51 »
To answer your question further. http://geekhack.org/index.php?topic=40501.msg1244354;topicseen#msg1244354
Offline Eszett
« Reply #8771 on: Thu, 03 July 2014, 01:14:13 »
Ah, that answers my question, thanks!
Offline cphead
« Reply #8772 on: Thu, 03 July 2014, 01:43:13 »
What's the best way to fix a busted trace on a pcb? As far as I can tell there's just a tiny exposed piece of copper, but the LEDs it connects to don't light up. :rolleyes:
« Reply #8773 on: Thu, 03 July 2014, 01:47:36 »
Personally I would just grab a small wire and follow the trace to another spot and light up the led that way. Or you could try a conductive writing pen.
Offline cphead
« Reply #8774 on: Thu, 03 July 2014, 01:58:33 »
Will try the pen. Thanks for advice, based legit-baller.
Offline Pacifist
  • on hiatus
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8776 on: Thu, 03 July 2014, 16:29:40 »
Is this paracord good for making cables? I need to replace my broken one
http://www.ebay.com/itm/550-Paracord-Mil-Spec-Type-III-7-strand-parachute-cord-25ft-50ft-100-ft-/380718097522?pt=LH_DefaultDomain_0&var=&hash=item58a4912472
It may depend on the size of the cable.  I am using 28/24 cables (24 gauge power and 28 gauge data) and I don't think paracord will fit over it.  I know that paracord is often very tight.
I have been using this and I am very pleased with the results.  It is plastic though, not paracord...
« Reply #8777 on: Thu, 03 July 2014, 17:33:48 »
 That stuff isn't bad, but it's worth spending a little more on some Bitspower, Kobra HD, or MDPC.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8778 on: Thu, 03 July 2014, 19:27:21 »
I found MDPC to be substantially more expensive. I am sure it is nicer. The stuff I linked is closer to the price point of paracord, but is a nice middle ground between the two. I will look into the others you linked (not that I need it, I have more of that stuff than I can use). :)
Thanks for the additional details.
Offline Jalberstone
« Reply #8779 on: Thu, 03 July 2014, 19:57:31 »
Would the function keys on a realforce tkl board have any use on a mac?
« Reply #8780 on: Thu, 03 July 2014, 20:03:32 »
Do you personally use function keys on your Mac? Hard to make blanket statements when we don't know what you're using when you're on your Mac.
For example, I have to have a numberpad and function keys for my work keyboard so I have to have a full size or 1800 layout. This is due to the software I use at work.
Offline Jalberstone
« Reply #8781 on: Thu, 03 July 2014, 20:06:14 »
On my mac I just use what is there, like the brightness and volume controls. Will those work on the Realforce? Otherwise what would the function keys do or is there a way to program them to do something?
Offline MJ45
  • HHKB Pro
« Reply #8782 on: Thu, 03 July 2014, 20:25:26 »
With KeyRemap4MacBook you could make the function keys do anything you want. In the system preferences you can set function keys also.
Offline Pacifist
  • on hiatus
« Reply #8784 on: Thu, 03 July 2014, 20:47:45 »
http://www.ebay.com/itm/Bare-Conductive-Electric-Paint-Pen-10ml-PCB-Repair-Electrical-Circuits-/111388550151?pt=LH_DefaultDomain_0&hash=item19ef466407
is this good for making traces on a clear surface?
That's what I suggested using in the earlier post. However, the video that Smasher816 found was using copper wire. Buy both and see what happens?
Don't see why it wouldn't but I'm not a Mac or Topre user. But MJ45 seems to have a good point.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8785 on: Thu, 03 July 2014, 20:48:41 »
This is what I do. I use my F keys as volume, brightness, etc.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8786 on: Thu, 03 July 2014, 20:51:59 »
I am getting a 500 error with that link on my phone. Is the -/ correct? That does not look like a correct url.
« Reply #8787 on: Thu, 03 July 2014, 20:54:06 »
URL Is working fine for me.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8788 on: Thu, 03 July 2014, 21:04:21 »
Sorry, my bad.  It works fine on the computer...  Wasn't working on my phone for some reason.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8789 on: Thu, 03 July 2014, 22:10:28 »
If I remember correct mkawa (someone at least) tried using them for tweaking traces on a Model M membrane and found the resistance of it to be to high to use for more than just fixing cracked/broken traces.
Offline intelli78
« Reply #8790 on: Thu, 03 July 2014, 23:07:08 »
Do you have an ad-blocking hosts file on your phone? I sometimes have problems with Tapatalk and other links, and i suspect that is the cause.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8791 on: Thu, 03 July 2014, 23:12:30 »
no, i think it has something to do with where the url wrapped and I think only part of the url was followed.  not entirely sure, but thats my hunch...
Offline nukec
  • that rug really tied the room together
« Reply #8792 on: Fri, 04 July 2014, 03:02:13 »
Still looking for KBC or Ducky Blank Black PBT keycaps, anyone sees anything in stock anywhere? :(
60% alu plate anywhere in stock?
« Last Edit: Fri, 04 July 2014, 03:35:03 by nukec »
HHKB Pro2, Poker2 Blue, KBPV60 Brown, DuckyShine3 Brown
Offline BlueBär
« Reply #8793 on: Fri, 04 July 2014, 06:23:36 »
Ducky Nordic on Deskthority has some blank black sets in stock.
Imsto seems to be out of stock for plates but GON still has some: http://www.gonskeyboardworks.com/accessaries/17-universal-frameplate-for-60.html
« Reply #8794 on: Fri, 04 July 2014, 08:37:12 »
Does it have to be aluminum? I think Imsto has some stainless steel plates as well. But I'm not sure I've seen many aluminum 60% plates.
Edit: I can't read. See BlueBar's post above about Imsto's stock :(
« Last Edit: Fri, 04 July 2014, 08:44:29 by CPTBadAss »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #8795 on: Fri, 04 July 2014, 08:41:27 »
GON sells a Universal Frame/Plate for 60%:
Offline Kblavkalash
« Reply #8796 on: Fri, 04 July 2014, 15:35:58 »
I just received my new white PBT keycaps, but space key is bent as you can see in the pic. For using it works perfectly, but still would be nice to have it straight, I wonder is it possible to straighten it somehow or not really?
« Reply #8797 on: Fri, 04 July 2014, 15:37:33 »
Get a hair dryer and warm it up a bit, then put something heavy on top of it (make sure to distribute weight evenly). PBT warps easily
« Reply #8798 on: Fri, 04 July 2014, 15:45:40 »
you can ensure even weight distribution with a flat object, like a few books
Offline Kblavkalash
« Reply #8799 on: Fri, 04 July 2014, 15:53:38 »
Thanks guys!
