Author Topic: A DELAY!!!!!  (Read 76843 times)
Offline Burz
  • maybe get a blister on yo' little finger...
Re: A DELAY!!!!!
« Reply #100 on: Fri, 09 August 2013, 18:17:06 »
Elvis QP has landed!!!
Are you in the US? What carrier was used?
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline BucklingSpring
Re: A DELAY!!!!!
« Reply #101 on: Fri, 09 August 2013, 18:50:10 »
Nope - I'm from the small country North of the US.
And was delivered by UPS.
Boards I own, click ->
Offline Matias
  • * Moderator
    • http://matias.ca
Re: A DELAY!!!!!
« Reply #102 on: Fri, 09 August 2013, 19:02:04 »
We use UPS and ship from Cheektowaga, NY, so customers on the east coast will get theirs first.
Fit and finish is perfect. Keys are lining up nicely with very little height variation.
I should point out that (unlike the Quiet Pro) the Mini Quiet Pro case is NOT painted.  It is injected black polycarbonate, so it's much less prone to fingerprints.
Re: A DELAY!!!!!
« Reply #103 on: Fri, 09 August 2013, 21:48:17 »
Interesting - Polycarbonate, hmmm - means more scratch resistant as well, isn't it?
As for the spacebar top surface porosity, is it an hallucination or it is rougher than the fullsize QP?
Offline Matias
  • * Moderator
    • http://matias.ca
Re: A DELAY!!!!!
« Reply #104 on: Sat, 10 August 2013, 05:07:14 »
Compared to ABS, it's much more scratch resistant, and about 50% more expensive.  I believe we are the only company making mechanical keyboards using Polycarbonate.  Everybody else uses cheaper ABS and paints it.
I never noticed before, but it looks like the grain of the texture is a little bigger.
Offline therecorder
Re: A DELAY!!!!!
« Reply #105 on: Sat, 10 August 2013, 05:40:36 »
BucklingSpring...  How about a closeup photo of your Mini so we can all see what you are talking about.
Re: A DELAY!!!!!
« Reply #106 on: Sat, 10 August 2013, 09:22:28 »
Bigger grain - maybe it will be glossy resistant for little longer.
Awsome ALPS switch, injected polycarbonate case, kickass USB cable... When are we going to be able to have decent PBT keycaps?
Re: A DELAY!!!!!
« Reply #107 on: Sat, 10 August 2013, 09:24:08 »
There  :p
31092-0
Offline therecorder
Re: A DELAY!!!!!
« Reply #108 on: Sat, 10 August 2013, 09:46:40 »
There  :p
I agree.  Definitely a difference between  this spacebar finish and that of my full-size QuietPro.  Thanks.
Re: A DELAY!!!!!
« Reply #109 on: Sat, 10 August 2013, 09:55:42 »
And I see that as a good thing as long as it takes longer to turn Darth Vader glossy black.
