Author Topic: Post your Topre Keyboard  (Read 4801024 times)
Offline youmiring
Re: Post your Topre Keyboard
« Reply #10300 on: Fri, 15 May 2020, 00:08:22 »
so i just got a Realforce R2 TKL. I know keycaps are rare but is there any outlet that sell keycaps that will fit the Realforce R2? I'm also really looking to get the Realforce Hiragana keycaps. Any suggestions on where to look?
Offline phinix
« Reply #10301 on: Fri, 15 May 2020, 02:50:05 »
kbdfans sells some one set, but its not great quality some say.
Get Novatouch sliders, swap and use any MX set you want. :thumb:
Offline apexshikari
« Reply #10302 on: Fri, 15 May 2020, 14:22:23 »
Here’s one...
Offline phinix
« Reply #10303 on: Sun, 24 May 2020, 09:35:35 »
Realforce R2 with GMK VoC
Offline Auxo
  • Formerly CJD_Anthony
« Reply #10304 on: Tue, 26 May 2020, 02:16:17 »
oOo that looks very nais.
What MX adapters do you got under the hood?
Offline phinix
« Reply #10305 on: Tue, 26 May 2020, 02:38:11 »
Novatouch
Offline ddrfraser1
  • RIP Neil
« Reply #10306 on: Tue, 26 May 2020, 09:20:02 »
243528-0
Offline DrJackman
« Reply #10307 on: Tue, 26 May 2020, 20:46:21 »
^ REALLY really like that matching num pad.  very clean set up.
here's my FC660c silenced w/ white hhkb alphas
Offline ddrfraser1
  • RIP Neil
« Reply #10308 on: Tue, 26 May 2020, 21:03:04 »
HA! I did the same thing! With a numpad to match of course. It's a great combo  ;D
243613-0
Offline DrJackman
« Reply #10309 on: Tue, 26 May 2020, 23:32:46 »
Love it!  I plan to do something similar with my R2 pfu limited soon but am waiting to see if i can find some OEM caps for the swap.
Offline subcat
« Reply #10310 on: Mon, 01 June 2020, 20:12:21 »
I present a pile of Japanese e-waste from China, or the JUKI FD-01R.
A few of you might be familiar with the FD-0100, the OEM Topre product from the 90s that Topre would eventually turn into the Realforce.
The FD-0100 is relatively mysterious but another variant with air travel reservation-specific keycaps was discovered years ago by sandy55 in Japan.
These data-entry keycaps are so gorgeous in my opinion, I love the incredibly busy look with the blue front-printing, and grey integrated numpad.
Despite its dismal condition I knew I had to grab it the moment I saw it.
244067-0
244069-1
244071-2
244073-3
244075-4
It's had a hard end of its life :(
244077-5
It dates back to 1997, 4 years prior to the debut of the Realforce marque.
244079-6
After a gruelling 4 hour+ session mercilessly scrubbing every individual keycap by hand, they're clean!
I decided to throw them on an 86U with some supplementary 108UH-ANLG caps.
244089-7
244081-8
244083-9
244085-10
244087-11
You can see the staggering amount of use the integrated numpad has had.
The texture has significantly worn down, the legends are beginning to fade on 0, 2 and +, and they're mad shiny.
« Last Edit: Mon, 01 June 2020, 21:44:07 by subcat »
Offline Lastpilot
  • Power stance
« Reply #10311 on: Mon, 01 June 2020, 20:44:14 »
That is simply breathtaking. I am at a loss for words. Congratulations on finding such a great piece.
Offline nmur
  • ಠ_ಠ
« Reply #10312 on: Mon, 01 June 2020, 21:08:21 »
huge find, well done
any plans for the case? or just going to keep at as is?
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #10313 on: Mon, 01 June 2020, 21:14:55 »
This one incredible turnaround. Those caps are great! Really well done.
Offline subcat
« Reply #10314 on: Mon, 01 June 2020, 21:46:29 »
thanks  :-*
@nmur, for now i’ll be keeping it as is - it’s pretty seriously scratched up :(
Offline Wazazaby
« Reply #10315 on: Tue, 02 June 2020, 05:23:03 »
R1 Realforce cases are so cute compared to R2
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10316 on: Tue, 02 June 2020, 05:25:19 »
What an amazing find and restoration. This doesn't surprise me as much coming from you, as you ever do surprise us with more awesome Topre goodies than we've ever dreamed to see.
Love it.
Offline cmd
« Reply #10317 on: Tue, 02 June 2020, 08:19:48 »
Forehead >
Kind of sucks that they went away with it on the R2. I have zero desire to get a R2  :(
« Reply #10318 on: Tue, 02 June 2020, 19:08:55 »
Hell yeah. Only reason to buy a realforce is the forehead look. Love it. So nostalgic
Offline btctopre
« Reply #10319 on: Wed, 03 June 2020, 11:56:47 »
pics are from a mercari listing, but a yellowed case on a hhkb jp actually looks pretty cool-
Offline Keikenhate
« Reply #10320 on: Wed, 03 June 2020, 15:56:44 »
Just wow mate...
Best find i saw lately...
Im really thankfull that i just even saw this one man, really.... im on the deep hunt for a juki celavi myself......
Gz again!
Offline btctopre
« Reply #10321 on: Thu, 11 June 2020, 20:20:20 »
missed out on the HG buy, but went ahead and started getting ready for hAsHtAg evija season-
haven't popped the rev a sliders into hhkb yet, but aside from having less surface area on the bottom of the slider (you can see the ring overhang in the pic), they appear to be the same as a stock slider (so more like the hhkb type-s slider than a realforce). the rev a foam ring is roughly 1mm wider than the rev b ring though (left is a messed up rev b, right is rev a)-
Offline sth
  • 2 girls 1 cuprubber
« Reply #10322 on: Thu, 11 June 2020, 22:43:15 »
Type S sliders have the bit in the middle thinned out like realforce silent (though maybe there is a slight difference)- at least, the Hybrid BT Type S do. I thought that pro2 typeS also had the modified type-S slider as well but I've never seen the sliders in person.
Offline btctopre
« Reply #10323 on: Thu, 11 June 2020, 23:36:30 »
yeap you're right (i've never owned hhkb type-s sliders in any capacity). the hhkb type-s slider is closer to the normal purple slider, it's just its shortened legs aren't as short as the purple slider legs (and i'm assuming this is where the supposed loss of key travel comes in).
this rev a slider seems more akin to applying a hypersphere or deskey #4 (?) to a stock slider... and this was really perplexing me because a) comparing realforce against realforce, it seemed to be more effective at silencing than the rev b (standard) purple slider, and b) while simultaneously it didn't feel like key travel was being stunted (like it was coming up "short" of the resting position) at all.
welp, it turns out the OG 1u purple slider housings are actually taller than the stock housings (similar to the silenced realforce 2.25u housings) to compensate for the slider ring-
evija season just got a hell of a lot more interesting because i believe the implication here is that you can pop even thicker rings on the rev b purple sliders and not experience stunted key travel. so something like a rev a housing + rev b slider + rev b ring (or rev a if better) + keyclack v2 would be possible so that you have noise suppression on both the slider and the slider housing without really experiencing a loss in upstroke position (might be noticeable if you fully bottom out though?).
i don't have any excess rev b sliders sitting around, so i'll have to wait until this weekend to really be able to test stuff out (basically compare stock slider + housing against the above config in terms of key height, travel distance, and noise).
Offline btctopre
« Reply #10324 on: Sat, 13 June 2020, 18:18:12 »
will post more info later, but just following up to confirm that this is a thing. you can use this config (or a second foam ring instead of a keyclack v2), and it not affect key travel at all. i have some deskey 3/5 rings coming in that i'll mess around with and make some UlTiMAtE ToPRe SiLenCiNg thread later.
on another note, anyone know of any topre keyboards that contain "standard" ANSI legend keycaps that are in the carmine-ish color (found on the EDIUS keyboards, a couple keys on the axess, and on the mythical aa-0101)? the color is absolute heat and topre needs to bring it back.
edit - replaced attachment with flickr image (imgur and such were stripping a lot of the red color out and making it more brown), and added in the standard "power" red color for comparison-
« Last Edit: Sat, 13 June 2020, 18:40:45 by btctopre »
Offline subcat
« Reply #10325 on: Sat, 13 June 2020, 18:35:08 »
there aren't any :( agreed though, topre has so many cool old pastels that are so pretty, but almost never used on their modern stuff
Offline btctopre
« Reply #10326 on: Sat, 13 June 2020, 19:09:06 »
bah, i figured as much, but i definitely appreciate you confirming it. i bought an edius3 to get a look at the lighter wine color (needed to figure out how deep i really wanted to go to buy one of those wasd sets huehuehue), but this color really is something else. i'll have to get the ol' lightbox out to capture a pic of it for the archives.
and it's honestly amazing how creative they used to be with their overall keycap colors, sublegend colors, and even the front legend colors... given how uninspired it all seems now (aside from that monstrosity that is the hello kitty keyboard).
Offline subcat
« Reply #10327 on: Sat, 13 June 2020, 19:22:52 »
for sure, love that wine colour - what i like about topre is that there's always potential to discover new stuff, so i hope someone finds more of those caps on some wacky oem board at some point! would be cool to get a topre colour wheel going or something too, for documentation's sake - even the realforce logo keycaps come in like a dozen different shades
244915-0
Offline phinix
« Reply #10328 on: Sun, 14 June 2020, 12:16:48 »
Realforce r2 with MT3 Serika.
244979-0
Offline biothermal
  • Art
« Reply #10329 on: Sun, 14 June 2020, 16:43:00 »
Hey, that's pretty hot
Offline singlexyz
« Reply #10330 on: Sun, 21 June 2020, 05:41:34 »
Offline ddrfraser1
  • RIP Neil
« Reply #10331 on: Sun, 21 June 2020, 08:19:41 »
245439-0
Offline subcat
« Reply #10332 on: Sun, 21 June 2020, 08:21:22 »
someone bought a justsystems r2
good stuff  :thumb:
Offline btctopre
« Reply #10333 on: Sat, 27 June 2020, 18:15:27 »
Think this is about as far as I can take this one (would replace WASD with a "Dusty Carmine" set in the same color as the BS and restore BS to the Anni' blue, but I'm going to be too picky on that one so eh)-
Happy Hacking Keyboard Professional (PD-KB300BN)
Alphas from 104UB-DK (2013)
Modifiers from 104UB-DK45S (Win/Win/App), 87USD-10th(Esc/Tab/Ctrl/LShift/Altx2/Enter), 89S-10th(RShift), FC660C/EGB(\), EDIUSV6KB (BS)
Bird HHKB KMG-Pro Anti-Vibration Mat (noise/vibration reduction w/ flap cut-out to preserve bottom label)
Stepped-Sorbothane Lining (5 steps; noise/vibration reduction + case-flex stability)
Poron Urethane Top Layer (noise reduction + keycap stabilization)
Rev B Purple Realforce Sliders + Stock OEM Silencing Rings (noise reduction)
Sanded-Down 2.25u Sliders + 1u OEM Silencing Rings (noise reduction)
PFTE-Taped Slider Legs (noise reduction + friction reduction + slider stability)
PFTE-Taped Stabilizer Wires (noise reduction)
See you boys next time after the Heavy Grail/Evija ships.
edit- there's also an old hasu in there ofc.
« Last Edit: Sat, 27 June 2020, 18:17:43 by btctopre »
Offline subcat
« Reply #10334 on: Sat, 27 June 2020, 18:47:10 »
NICE
Offline dgneo
  • Supervillain
« Reply #10335 on: Mon, 29 June 2020, 07:58:36 »
bootiful
Offline nglx
« Reply #10336 on: Tue, 30 June 2020, 16:24:45 »
HHKB PRO 3 with custom keycaps
246120-0
Offline dgneo
  • Supervillain
« Reply #10337 on: Thu, 09 July 2020, 07:31:05 »
feels good to be back on topre
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10338 on: Thu, 09 July 2020, 10:52:49 »
inevitable return to topre
we always come back to it
welcome back :)
Offline Auxo
« Reply #10339 on: Thu, 09 July 2020, 20:53:56 »
My little slice of happiness 😊
246884-0
Offline strongly-typed
  • lux et veritas
    • Github
« Reply #10340 on: Wed, 22 July 2020, 23:01:14 »
My baby... 45g domes with purple sliders and lubed with 3204.  The spacebar has absolutely no rattle whatsoever. </thock-intensifies>
Realforce 87U 45g Silent :: Realforce 87U 30g Silent :: Realforce R2 55g :: Niz Plum 87 with 45g topre domes
English | Spanish | Italian | Latin | Portuguese | Mandarin | Cantonese | Japanese | Welsh | OCaml
Offline hdo
« Reply #10341 on: Sun, 26 July 2020, 12:36:14 »
 here is my realforce 104uk-hipro
247979-0
« Last Edit: Sun, 26 July 2020, 12:40:31 by hdo »
Realforce 104UK HiPro | Realforce 87UB SE170S | Leopold FC660C | Canoe | Kyria | Minila Air Kobo
Offline PadawanGeek
« Reply #10342 on: Sat, 08 August 2020, 09:52:50 »
Gosh, seeing this thread reminds me that I have a number of Topre keyboards that I should start rotating. I'm using a Topre RealForce 103UB 55G on my main rig, love that heavier 55G! Also have two CM Novatouch TKL's, two HHKB's, a Leopold FC66C and a Topre Type Heaven. Some with 3rd party keycaps, while remaining keyboards are with stock keycaps. There was a time I'd go nuts and buy 2-3 keyboards a month....
« Last Edit: Sat, 08 August 2020, 09:55:15 by PadawanGeek »
Offline frostize
« Reply #10343 on: Wed, 12 August 2020, 07:26:28 »
My topre collection :D
249290-0" alt="" class="bbc_img" />
Offline suntorytime
« Reply #10344 on: Thu, 03 September 2020, 06:47:48 »
Recently got another Topre (86U in white at the forefront, 10th anniversary edition in the back). I didn't notice when purchasing but it has a swapped tilde and escape key.
Confess I didn't know any Topre models had this 'layout'.. Played with the dip switches but they're just the standard 4 dips. It doesn't bother me, but is there some way to swap the two keys that I don't know about?
Offline dgneo
  • Supervillain
« Reply #10345 on: Thu, 03 September 2020, 06:59:56 »
They don't - when using it are the keys actually swapped, or is it just the keycaps? I'd be very surprised if the actual keys are swapped.
FWIW the 86u I had was standard Esc top left, Tilde below it.
Offline suntorytime
« Reply #10346 on: Thu, 03 September 2020, 07:06:01 »
No, keys are swapped it's not just the caps. It led me to a bit of a search down this mystery and there's a copy on ebay with exactly the same configuration (it also has the same S/N: 90101028A). This is despite the box on both the ebay copy and mine showing the esc and tilde in the common places.
https://www.ebay.com/itm/REALFORCE-SE0500-86U-English-keyboard-/392896370600?nma=true&si=u5p3IAdmnveaqZqS6yfW3y%252Fgk6k%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
Edit: My 86U's PCB sticker for good measure, date of manufacture 13 Jan 2009 - sub model? SE 0501
« Last Edit: Thu, 03 September 2020, 07:34:54 by suntorytime »
Offline dgneo
  • Supervillain
« Reply #10347 on: Thu, 03 September 2020, 07:17:12 »
Well **** that's pretty interesting, I've been digging through google images and can't find any in the same layout.
Perhaps one of the topre experts can shed some light (btctopre, subcat)?
Offline btctopre
« Reply #10348 on: Thu, 03 September 2020, 10:22:43 »
hmm... i had a white/beige 86u once, and it definitely did not come in that layout.
it looks like the one on ebay is the same one that sold on mercari (listing just didn't get removed from ebay yet). seller mentions no remapping of the keys in that listing, i don't see any sort of usb-to-usb remapping device on the cable, and there's no dip switch on that model to swap esc/tilde (nor have i ever seen such a thing on a topre keyboard), so not sure what is going on.
when you disassembled the board, were there any wires running in between the keys on the pcb (to create a sort of hard-wired remap)? i've only seen that once ever before on topre, but it makes me believe that it's possible.
Offline suntorytime
« Reply #10349 on: Thu, 03 September 2020, 11:24:02 »
Mystery solved - when I took the PCB out I couldn't even see the wire it was so thin, then rushed to make some dinner for the little one. What a strange mod... but I don't hate it. I don't program so I never use tilde.
