Author Topic: Post your Topre Keyboard  (Read 4453170 times)
Offline Remenition
  • Cooler than your average kid ;)
Re: Post your Topre Keyboard
« Reply #6650 on: Thu, 03 December 2015, 04:44:09 »
Ill do some scouting aswell
Appreciate it brother :)
This pretty cheap for having silent sliders: The one I bought was still cheaper but this isn't bad. Can easily harvest it and sell for $150 if you wanted to.
http://www.amazon.co.jp/%E6%9D%B1%E3%83%97%E3%83%AC-REALFORCE108US-%E9%9D%99%E9%9B%BB%E5%AE%B9%E9%87%8F%E7%84%A1%E6%8E%A5%E7%82%B9%E6%96%B9%E5%BC%8F-ALL30g-SJ38D0/dp/B003Y2ZBUU/ref=sr_1_24?ie=UTF8&qid=1448205002&sr=8-24&keywords=topre
What are silent sliders?
Are they the same as what's in the Type-s?
AFAIK they're longer sliders that compensate for the travel distance lost after putting on silencing rings.
On a separate note, can someone confirm that Type-S sliders are actually not longer than regular ones?
The base is thinner on the purple sliders, as opposed to the normal black sliders. Type S uses regular black sliders.
awesome, guess i need to pick up a board with some purple slider's to salvage
I.e. an HHKB Type S.  Heck of a board to sacrifice just for the sliders :eek:
well an hhkb type s just has regular slider's no? i would have to get a silenced realforce proxied over for some purple sliders.
Offline nmur
  • ಠ_ಠ
« Reply #6651 on: Thu, 03 December 2015, 04:53:26 »
man, if JT Keycaps can make mx sliders, I wonder if they can make longer topre sliders too. perhaps with correctly sized rubber silencers too.
they would make a buttload of money, considering some people are prepared to buy entire RF boards just for the sliders.
Offline raymogi
« Reply #6652 on: Thu, 03 December 2015, 05:00:51 »
I will be waiting for this day to happen. Proxying a board just for sliders is so damn tiring.
Please feed my addiction.
Offline whmeltonjr
« Reply #6653 on: Thu, 03 December 2015, 20:51:14 »
Lubed storm trooper HHKB.  ;D
Offline Remenition
« Reply #6654 on: Thu, 03 December 2015, 20:52:03 »
awwwwww yeeeee, do you have a guide for lubing?
Offline whmeltonjr
« Reply #6655 on: Thu, 03 December 2015, 21:00:51 »
Buy one already lubed  :)) Sorry I can't be of more help, but I traded my non-lubed one for a lubed one.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #6656 on: Thu, 03 December 2015, 21:49:53 »
Simple and beautiful! Gotta love a good ol' Storm Trooper theme.
I recently went back to Storm Trooper myself!
Short version:
Unscrew the bottom case from the top.
Open slowly and detach the controller from the bottom case.
Unscrew the PCB from the top case, and lift slowly.
Gather your domes and springs in a bowl.
Once you have just the top case with the plungers, flip it upside down so the plungers are fully extended out.
Lube the 2 contact rail corners of each plunger with a brush or whatever you have on hand.
Once all of them are lubed, just kind of flip your top case upside down a few time to evenly distribute the lube.
Screw everything back together.
Enjoy the true oneness with cup rubber!!!
Let me know if you need more specifics :3
« Reply #6657 on: Fri, 04 December 2015, 04:55:52 »
Broken space bar :(
Offline atlas3686
  • HHKB Elite
« Reply #6658 on: Fri, 04 December 2015, 06:22:55 »
Broken space bar :(
Seems to be a common issue... :)
Offline linuxhermit
« Reply #6659 on: Fri, 04 December 2015, 06:29:46 »
My new FC660C and a new to me Realforce 45g. I keep debating a 55g but worry it'll be to heavy.
87UW45FC660C EW
« Reply #6660 on: Fri, 04 December 2015, 07:40:23 »
Broken space bar :(
They should really start looking into that. What terrible quality control.
Offline jerue
  • (Whenever that happens :P)
« Reply #6661 on: Fri, 04 December 2015, 07:53:41 »
It won't be. It's bliss on a Realforce  ^-^
Offline raymogi
« Reply #6662 on: Fri, 04 December 2015, 08:13:15 »
Might be a tad heavy for the first hour or two but after that there's no turning back.
Offline Dongulator
« Reply #6663 on: Fri, 04 December 2015, 08:57:00 »
Anyone suggesting that 55g isn't too heavy must been hit with a heavy dose of Gamma Rays...
All joking aside those are very good looking boards. I'm looking forward to my fc660c EW which should be coming today or tomorrow.
Offline Solo
  • Unreal
« Reply #6664 on: Fri, 04 December 2015, 09:27:26 »
I received my EW yesterday and it's wonderful. Prepare to be enamored by its beauty.  ^-^
« Last Edit: Fri, 04 December 2015, 09:29:42 by Soloist »
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #6665 on: Fri, 04 December 2015, 14:06:15 »
119098-0
Offline Remenition
« Reply #6666 on: Fri, 04 December 2015, 14:43:33 »
Offline daerid
    • Rossipedia
« Reply #6667 on: Fri, 04 December 2015, 15:08:31 »
Hnnnnnnnngggggggggghhh my god that makes me want a white 660C sooooooo bad
Offline Bromono
  • Wanabe Cicerone
« Reply #6668 on: Fri, 04 December 2015, 15:25:01 »
Offline kct
« Reply #6669 on: Sat, 05 December 2015, 01:19:28 »
Less than a year old Realforce 87U variable I got from a local forumer. I kind of need to find a PC to use it with...
Offline bocahgundul
  • a seal
« Reply #6670 on: Sat, 05 December 2015, 04:31:35 »
Why don't just use your pc? the topre deserve better than that cherry  :p
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #6671 on: Sat, 05 December 2015, 05:00:49 »
Replaced the blank red row 3 cap with an up row 4. Still need a row 1 pipe slash, and row 4 shifts.
oh I want to touch it...
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #6672 on: Sat, 05 December 2015, 19:57:28 »
Broken space bar :(
YOU'RE BROKEN, BRO.
BRO. KEN.
Only way to know is to buy and touch that 55g for yourself, mane. You must try it :P
Beautiful boards tho ~
Really liking this photo, dood :3
« Reply #6673 on: Sat, 05 December 2015, 19:57:48 »
Broken space bar :(
YOU'RE BROKEN, BRO.
BRO. KEN.
NO YOU ARE BROKEN
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #6674 on: Sat, 05 December 2015, 20:00:20 »
NO YOU ARE BROKEN
OH YEE? WELL YOU ARE DAMAGED GOODS, SON.
Offline raymogi
« Reply #6675 on: Sat, 05 December 2015, 20:43:06 »
NO YOU ARE BROKEN
Permanent eye damage cause of that avatar.
« Reply #6676 on: Sat, 05 December 2015, 20:44:37 »
NO YOU ARE BROKEN
IM GOING TO GO CRY IN A CORNER NOW THANKS
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #6677 on: Sat, 05 December 2015, 20:45:23 »
NO YOU ARE BROKEN
/rekt 10/10
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #6678 on: Sat, 05 December 2015, 20:53:48 »
Offline digi
  • elite af tbh
« Reply #6679 on: Sat, 05 December 2015, 20:55:52 »
/rekt 10/10
ughh.....hnnnggggggggggg...uggGGGGGGGHHHHHHH - I CAN'T SEE THAT GIFFFF, WAIT I CAN, I JUST GOT REKTTED!!!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #6680 on: Sat, 05 December 2015, 20:57:33 »
hue hue hue ~
« Reply #6681 on: Sat, 05 December 2015, 21:23:07 »
Offline Gaspar
« Reply #6682 on: Sat, 05 December 2015, 21:52:33 »
I have the grey Leopold 660c and I just got a RF 55g. Honestly I don't feel that much of a difference between the 2. I do feel one and the 55g are heavier but it's not that much of a gap. I prefer the feel of the switch of the RF but i like the layout of the Leopold more, it's so elegant and simple, so effective.
How much of a difference do you feel between the Leo and the RF, both 45g?
Offline Latin00032
« Reply #6683 on: Sat, 05 December 2015, 22:10:35 »
I have the newer fc660c and the rf 55g.
There was discussion about this before in other threads about the newer fc660c feeling heavier than most other 45g topre boards. Many people have said the newer 45g fc660c feels almost as heavy as a 55g rf.
I believe this is true. When I used both boards side by side the difference was minimal. Granted the 55g rf was still heavier but by a smaller margin. Maybe a 4g to 5g of difference.
When I swaped the 55g domes into the fc660c the switches got even heavier. Possibly feeling like a 58g board.
I believe the plate design changed in newer fc660c boards.
Newer fc660c is the one with grey or white caps.
Older fc660c has a black case with black caps.
Maybe someone else on this thread will chime in on this.
Offline raymogi
« Reply #6684 on: Sat, 05 December 2015, 22:12:57 »
I have the old 660c with blank black caps and I do feel that the 45g there is much heavier than the 45g in HHKB.
I can only imagine how much heavier it is going to be with 55g domes.
Offline Latin00032
« Reply #6685 on: Sat, 05 December 2015, 22:30:46 »
My fingers started feeling like they were getting a bit of a work out after I put the 55g domes inside the newer fc660c.
I never tried the older fc660c so I don't know how it compares with the newer one.
I'm just going but what other forum members have said.
« Reply #6686 on: Sat, 05 December 2015, 23:12:13 »
It might be a trick of the light, or my bad eyes, but that FC660C looks huge compared to the RF.  If you move the FC660C 1x to the left, the backspace would still extend about 2x to the right of the RF keys.
Offline wupi
« Reply #6687 on: Sun, 06 December 2015, 09:20:08 »
Offline trenzafeeds
  • **** off
« Reply #6688 on: Sun, 06 December 2015, 09:53:08 »
Wow, that is quite nice. Good job pulling all those things together.
demik will never leave.
Unless he gets banned.
Offline Dongulator
« Reply #6689 on: Sun, 06 December 2015, 10:18:47 »
The fc660c is about  about 1 1/2 rows smaller than the RF
Offline linuxhermit
« Reply #6690 on: Sun, 06 December 2015, 10:40:10 »
The FC660C is on top of a wrist rest in that picture sorry
87UW45FC660C EW
Offline trenzafeeds
  • **** off
« Reply #6691 on: Sun, 06 December 2015, 17:54:22 »
Yeah lol... I was very confused as well. Nice boards though!
Offline nmur
  • ಠ_ಠ
« Reply #6692 on: Tue, 08 December 2015, 00:33:37 »
apologies for the quality but office lighting + phone camera = literal potato. but hopefully you guys get the idea...
red keys now in the same arrangement that the blue keys are on the 10th AE 87U
kinda considering looking for someone that will trade their pink set for my red set
Offline E3E
« Reply #6693 on: Tue, 08 December 2015, 01:26:05 »
That red and black contrast is sick.  :thumb: Pink and black wouldn't be so bad either. :P
Offline henz
  • What?
« Reply #6694 on: Tue, 08 December 2015, 03:36:38 »
My hometown's fotball team had those colors!
« Reply #6695 on: Tue, 08 December 2015, 03:50:45 »
AE has blue `~?
:eek:
Offline nmur
  • ಠ_ಠ
« Reply #6696 on: Tue, 08 December 2015, 03:52:41 »
AE has blue `~?
:eek:
 :confused: oh no I messed it up
brb driving back to work to fix it
« Reply #6697 on: Tue, 08 December 2015, 03:53:56 »
AE has blue `~?
:eek:
Thank you :)
Offline Bromono
  • Wanabe Cicerone
« Reply #6698 on: Tue, 08 December 2015, 14:10:31 »
I like this.
so no
no pink for you
Offline trenzafeeds
  • **** off
« Reply #6699 on: Tue, 08 December 2015, 16:25:02 »
I like this.
so no
no pink for you
nice BR avatar
