Author Topic: How is this thing called?  (Read 1226 times)
Offline aycko
« on: Thu, 28 February 2013, 14:26:32 »
Hi,
I recently bought an used Filco Majestictouch 2 and the first thing I did was clean it. But during this process I broke one of those white thingies that hold down the enter key. On the one end they end like a cross, similar to the switches and on the other end they have a lash where you can insert a wire. Most of the bigger keys, like Enter, Space, right Shift, Backspace etc. have two of them.
I do not know how they are called, but can I somehow order them?
Offline Tym
Re: WHAT* is this thing called?
« Reply #1 on: Thu, 28 February 2013, 14:29:15 »
I believe you are talking about the stabilizer? I'm not sure where you can order them; but if you put your location (country) in your profile people may be able to help you better.
Offline The_Beast
  • I like wood ಠ_๏
Re: How is this thing called?
« Reply #2 on: Thu, 28 February 2013, 14:29:32 »
Offline aycko
« Reply #3 on: Thu, 28 February 2013, 14:38:54 »
Yeah that is the thing I am looking for. Thank you very much. Is there an European shop that sells those?
Offline calavera
« Reply #4 on: Thu, 28 February 2013, 14:58:12 »
Head over to deskthority, there might be people generous enough to just mail you some for free. It's worth a try at least.
