Author Topic: Insert Hyperlink button suggestion  (Read 6665 times)
Offline TheSoulhunter
  • ~ BOOO ~
« on: Fri, 01 March 2013, 10:38:52 »
Insert Hyperlink button inserts:
Code: [Select]
[url][/url]
Now, something I know from other forums...
Insert Hyperlink button throws a prompt to type a URL resulting in:
Code: [Select]
[URL="URL"]URL[/URL]
Example: http://www.youtube.com
Insert Hyperlink button used on selected TEXT throws a prompt to type a URL resulting in:
Code: [Select]
[URL="URL"]TEXT[/URL]
Example: Check this out!
Insert Hyperlink button used on selected IMAGE throws a prompt to type a URL resulting in:
Code: [Select]
[URL="URL"][IMG]IMAGE[/IMG][/URL]
Example:
etc.
Makes life much easier! :)
« Last Edit: Fri, 01 March 2013, 10:44:10 by TheSoulhunter »
A Ghost From The Past
Offline alaricljs
  • I be WOT'ing all day...
Re: Insert Hyperlink button suggestion
« Reply #1 on: Fri, 01 March 2013, 10:41:08 »
What browser?  I have Firefox and it does exactly what you're asking for.
Filco w/ Imsto thick PBT
  • ~ BOOO ~
« Reply #2 on: Fri, 01 March 2013, 10:48:16 »
I use Firefox as well...
But selecting the "well" in the sentence above and hitting the button simply results in:
Code: [Select]
I use Firefox as [url]well...[/url]
On other forums it works!
Offline alaricljs
« Reply #3 on: Fri, 01 March 2013, 11:53:40 »
Java ?
  • ~ BOOO ~
« Reply #4 on: Fri, 01 March 2013, 13:05:06 »
Java ?
Enabled!
Btw, most of the mentioned forums where it works are vBulletin based...
« Last Edit: Fri, 01 March 2013, 13:14:28 by TheSoulhunter »
Offline alaricljs
« Reply #5 on: Fri, 01 March 2013, 13:37:01 »
Do you have WYSIWYG editor checked on this page:  http://geekhack.org/index.php?action=profile;area=theme  ?
  • ~ BOOO ~
« Reply #6 on: Fri, 01 March 2013, 13:54:55 »
Well, WYSIWYG editor is somewhere in between...
While it throws the prompts and using the button on text or images works, you don't have editable tag code anymore, so meh :/
Offline alaricljs
« Reply #7 on: Fri, 01 March 2013, 14:00:24 »
That silly arrow in red [] toggles to editable code.
  • ~ BOOO ~
« Reply #8 on: Fri, 01 March 2013, 14:42:29 »
I guess toggling it on/use/off/edit/on/use/off/edit... will do it as a work around, thanks for pointing that out :)
Anyway, I prefer the simple instant non WYSIWYG method vB uses, would be cool if it could be integrated here!
