Author Topic: Pure aluminum CNC case ALL SHIPPED, NO LEFTOVER.  (Read 80517 times)
Offline Sai
Re: Pure aluminum CNC case(fulled)(collecting payment/shipping)
« Reply #100 on: Tue, 05 March 2013, 18:56:40 »
when are we getting our tracking no.?
Offline tinlong117
« Reply #101 on: Tue, 05 March 2013, 21:06:20 »
i havent sent it as registered letter, but it will come.
Offline Sai
« Reply #102 on: Tue, 05 March 2013, 21:38:02 »
hmm ok. then i just hope it will fit into my po box.  :-X
Offline Michael
  • Formerly Bro Caps
« Reply #103 on: Tue, 05 March 2013, 23:54:04 »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #104 on: Wed, 06 March 2013, 00:12:04 »
He's the only guy who doesn't use tracking but the items I have bought from him in the past, always turns up on your doorstep.
He's a lot like Qtan.
Offline Sai
« Reply #105 on: Wed, 06 March 2013, 01:03:40 »
i just hope this arrives while i am working from home.
Offline cgbuen
    • cgbuen.io
« Reply #106 on: Wed, 06 March 2013, 01:44:50 »
Hey tinlong, hope you can check your PM soon - I had another quick question, will send a payment as soon as you respond! Thanks!
Offline heedpantsnow
  • Old enough to know better
« Reply #107 on: Wed, 06 March 2013, 18:42:08 »
Are these lower profile than the stock Poker base?
I'm back.
Offline tinlong117
« Reply #108 on: Wed, 06 March 2013, 18:44:49 »
what you mean?
« Reply #109 on: Wed, 06 March 2013, 20:50:41 »
what you mean?
Sorry, I mean are they the same height as the original plastic Poker casing or are they shorter/lower?
I'm back.
Offline Jocelyn
  • 조셀린
« Reply #110 on: Wed, 06 March 2013, 20:53:22 »
I don't have my Poker here (own both), but I would think it's shorter. Externally, the Pure CNC case is ~1cm high up front and ~2cm high in the back with a 45 degree upward bend in the middle of that measurement.
Offline tinlong117
Re: Pure aluminum CNC case ALL SHIPPED, NO LEFTOVER.
« Reply #111 on: Thu, 07 March 2013, 03:06:51 »
all had been shipped.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #112 on: Fri, 08 March 2013, 09:02:25 »
The Pure aluminum case has a much lower profile than the stock KBC Poker case, but the keyboard appears to be at the same height and angle. Below are a couple of photos comparing the two.
Offline codyeatworld
« Reply #113 on: Fri, 08 March 2013, 11:05:38 »
Thanks for the picture!
I like how the plastic case covers the guts a bit more. But no biggie. Still looks great!
Hopefully my poker and case come in the mail today...
« Reply #114 on: Sat, 09 March 2013, 00:24:28 »
Thank you, that's exactly what I was wanting to know.
I'm back.
Offline plastboks
« Reply #115 on: Sat, 09 March 2013, 05:59:55 »
Just received mine. Thanks  ;D
Offline tinlong117
« Reply #116 on: Sat, 09 March 2013, 06:10:13 »
what?! you received your case already  ;D  :rolleyes: :rolleyes:
Offline GeorgeK
« Reply #117 on: Sat, 09 March 2013, 11:18:39 »
That makes me excited :D
Offline plastboks
« Reply #118 on: Sat, 09 March 2013, 11:47:21 »
Yup :D
Offline tinlong117
« Reply #119 on: Sat, 09 March 2013, 11:50:44 »
Yup :D
super! :D
I just posted it as a letter and it usually arrive like 10 days o_O
Offline Sai
« Reply #120 on: Sat, 09 March 2013, 12:10:06 »
i guess it should arrive to me next week. =.= wonder why it arrives to norway first when SG is nearer to HK  :))
Offline pshay
« Reply #121 on: Sun, 10 March 2013, 10:35:47 »
most of the case shipped today.
so... where are my “phantom awesome face” keycaps
Offline Hzza
« Reply #122 on: Mon, 11 March 2013, 13:20:39 »
Mine came today, thanks dude.
edit - Protip, the foam stuff the case came wrapped in makes a great insulating sheet. Also, this totally changes the feel of my daughters Poker, almost makes me want to use it again!
« Last Edit: Mon, 11 March 2013, 14:55:27 by Hzza »
« Reply #123 on: Mon, 11 March 2013, 16:22:44 »
Got mine!
Here are some shotty pics if your still waiting! I dont have my poker yet :(
http://imgur.com/a/kydLY
I was also thinking of using that foam for the bottom sheet.
Offline Jocelyn
  • 조셀린
« Reply #124 on: Mon, 11 March 2013, 16:41:14 »
Got mine!
Nice. I wish I was on the coast :)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #125 on: Mon, 11 March 2013, 18:35:53 »
mine came in,ill post a pic or two soon
its a TIGHT fit, at least for me but i got it in there and it works fine. looks great
Offline Jocelyn
  • 조셀린
« Reply #126 on: Mon, 11 March 2013, 18:51:19 »
Hurry with the photos lol :)
Offline Michael
  • Formerly Bro Caps
« Reply #127 on: Mon, 11 March 2013, 19:25:22 »
twss
Offline Glod
    • YouTube Channel
« Reply #128 on: Mon, 11 March 2013, 19:26:59 »
ok well, i snapped these quick of the poker in the pure case
few things
1. i had to take off my wasd mod because the wires were too thick and the poker wouldnt fit in the case. it really wasnt too successful though, the LED seem to go dimmer and didnt serve any use
2. it was a very tight fit
3. youll notice on the picture where the usb plug is that the board is just slightly (looks like half a mm) bumped up compared to the other picture of the backspace
overall i like it
« Last Edit: Mon, 11 March 2013, 19:28:34 by Glod »
Offline Jocelyn
  • 조셀린
« Reply #129 on: Mon, 11 March 2013, 19:29:12 »
few things
3. youll notice on the picture where the usb plug is that the board is just slightly (in mm) bumped up compared to the other picture of the backspace
overall i like it
1. Yep, you'll need to dremel the case ridges like I mentioned before
2. Not a bad thing
3. Again, probably need to dremel the case :)
Thanks for the photos! I think it looks wonderful!!!
Edit: Does anyone know if Vortex or Beast's plate is thicker?
« Last Edit: Mon, 11 March 2013, 19:30:57 by Jocelyn »
Offline Michael
  • Formerly Bro Caps
« Reply #130 on: Mon, 11 March 2013, 19:49:23 »
You would be better off using small trace wires and cover them with silicone (or even tape) directly to the pcb. They wouldn't take hardly any extra space.
Seeing if I can find a photo to share of that....
Offline Glod
    • YouTube Channel
« Reply #131 on: Mon, 11 March 2013, 19:57:46 »
that actually sounds like a good plan, need the right kind of LED this time though too, i grabbed some leds off the quickfires i harvested and they are very dim.
again, i love this case, so worth it
Offline Michael
  • Formerly Bro Caps
« Reply #132 on: Mon, 11 March 2013, 20:00:50 »
What I use, really bright:
http://www.ebay.com/sch/i.html?_trksid=p3984.m570.l1313&_nkw=2x3x4mm+LED&_sacat=0&_from=R40
Make sure they say 'water clear'
« Last Edit: Mon, 11 March 2013, 20:02:33 by Bro Caps »
Offline Glod
    • YouTube Channel
« Reply #133 on: Mon, 11 March 2013, 20:02:23 »
rectangle? hmmm
Offline Michael
  • Formerly Bro Caps
« Reply #134 on: Mon, 11 March 2013, 20:03:27 »
rectangle? hmmm
Aye, fits the tightest clearance keycaps without worry. Some round LED's require trimming due to lack of clearance from the key cap hitting them.
Offline Glod
    • YouTube Channel
« Reply #135 on: Mon, 11 March 2013, 20:06:41 »
ill give it a try, thanks.
Offline Glod
    • YouTube Channel
« Reply #136 on: Mon, 11 March 2013, 21:09:34 »
extra pic of the poker with plate in this case
crappy camera phone pic i know but i think it better illustrates how it looks with the plate. not all may like not having that "lip" there but i think it looks bad ass
Offline WhiteFireDragon
    • youtube
« Reply #137 on: Mon, 11 March 2013, 21:13:55 »
Got mine, looks nice at initial glance.... BUT... closer inspection is no bueno. Given Vortex's track records, I already expected this so I'm not too flustered. Machining marks are not even. Some inner edges are chipped. Outer surface is not totally flat. There are localized bumps and dents. Some local edges are not straight. Fillet corners are terrible.
Do note that I'm generally more nitpicky than most people. But regardless, thanks tinlong for a super speedy GB and shipping!
Pros:
- price
- metal, CNC
Cons:
- Vortex
- mediocre quality
Flaws:
Offline Michael
  • Formerly Bro Caps
« Reply #138 on: Mon, 11 March 2013, 21:17:45 »
WFD - That looks really rough on the rounded corners. Looks really bad in those close-up photos. Sigh. Ah well, I guess 100 bucks wasn't too bad
Offline Jocelyn
  • 조셀린
« Reply #139 on: Mon, 11 March 2013, 21:18:59 »
Haha WFD strikes again!
I think most people, including myself, appreciate your nitpickyness. Anyway, nice mini review & photos.
Offline Michael
  • Formerly Bro Caps
« Reply #140 on: Mon, 11 March 2013, 21:20:04 »
I think this falls under the category:
GOOD FROM FAR.... BUT FAR FROM GOOD....
Offline Jocelyn
  • 조셀린
« Reply #141 on: Mon, 11 March 2013, 21:23:48 »
Indeed.
Btw, I think Glod is using a Vortex plate. So, which plate is thicker, Vortex or Beast's?
Offline mashby
    • Mashby
« Reply #142 on: Mon, 11 March 2013, 21:25:15 »
Indeed.
The Beast's plate is thicker.
Offline jcrouse
Re: Re: Pure aluminum CNC case ALL SHIPPED, NO LEFTOVER.
« Reply #143 on: Mon, 11 March 2013, 21:25:36 »
I think I know her.
Offline Jocelyn
  • 조셀린
« Reply #144 on: Mon, 11 March 2013, 21:26:07 »
Oh no!
Vortex plate is 0.060", Beast's plate is standard 16 gauge, so 0.0625". The difference is negligible when looking at it, but this actually matters for Costar stabilizers. For switch mounting or anything else, this difference doesn't matter.
Thanks for this.
« Last Edit: Mon, 11 March 2013, 21:30:45 by Jocelyn »
    • youtube
« Reply #145 on: Mon, 11 March 2013, 21:27:27 »
I forgot to add that chamfers on there are a joke. However, the whole case was sand/bead blasted, then clear anodized. There's no conductivity except for the inner screw holes.
« Last Edit: Mon, 11 March 2013, 21:29:41 by WhiteFireDragon »
Offline Glod
    • YouTube Channel
« Reply #146 on: Mon, 11 March 2013, 21:44:59 »
odd mine looks different around the usb port, what i mean is on the outside mine looks more symetrical than WFDs
mine was a little ugly on the inside i didn't take any close ups on the inside of the case but it looked very rough.
i have a different kind of imperfection though, these little dots, as if its been poked with something sharp or bubbles maybe and then some scratches like it was dropped
again, i really need to invest in a better camera for low light......
here are the dots, they should be clearly visible in this picture if you view it larger, they are all over the case, and there was an odd droplet stain also pictured
here is where it looks like it was dropped at some point
i mean i'm happy with it, but this is my first customized board with a aluminum case and all. if i had the experience with KMACs and other stuff like WFD i bet you money i would be more unhappy with this case.
also forgot to say
THANK YOU Tinlong! none of these problems are your fault and you charged what i think is a fair price for these.
Offline Sai
« Reply #147 on: Mon, 11 March 2013, 21:51:32 »
can you post a picture of the package as well? i need to see it to know whether the package will fit in the box >.>
Offline Jocelyn
  • 조셀린
« Reply #148 on: Mon, 11 March 2013, 21:52:38 »
I want to say no way lol, but I'm sure someone will post a photo soon :)
Offline Glod
    • YouTube Channel
« Reply #149 on: Mon, 11 March 2013, 21:55:55 »
i threw it away, it wasn't a box, just a padded postpack mailer. could be shoved into a mail box but not sure if someone would actually do that.
