Author Topic: Poker (from iMAV's GB) and Backlighting  (Read 4743 times)
Offline jcrouse
« on: Thu, 07 March 2013, 16:44:03 »
Can anyone tell me whether the LED's on the Poker that came from iMAV's group buy can be turned on and off if I add them. I notice that every switch has the holes in the PCB to install LEDs. I am not an LED guy but would like caps lock and also some way to tell if the function layer is on or off.
Thanks,
John
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Poker (from iMAV's GB) and Backlighting
« Reply #1 on: Thu, 07 March 2013, 16:49:55 »
Thanks for asking this question. I too would like to know.
Not quite ready to build up my board yet, but getting close.
Offline Michael
  • Formerly Bro Caps
« Reply #2 on: Thu, 07 March 2013, 16:55:58 »
You would need to do some modification. WFD has done it, so might start there.
Offline jcrouse
« Reply #3 on: Thu, 07 March 2013, 17:00:31 »
Link?
Offline fydo
  • Meow!
« Reply #4 on: Thu, 07 March 2013, 17:09:56 »
IIRC, there's only support (traces) for 7 LEDs on the PCB. I don't have mine (yet) so I can't tell you exactly which ones.
However, there are holes for LEDs on each and every switch on the PCB, so you can run wires to each of them if you want a fully backlit keyboard. You'll have to find a way to get power to them though... :)
« Last Edit: Thu, 07 March 2013, 17:11:52 by fydo »
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline Jocelyn
  • 조셀린
« Reply #5 on: Thu, 07 March 2013, 17:15:47 »
This^ I can post some photos of the back of my PCB when my CNC Aluminum case gets here.
Offline jcrouse
« Reply #6 on: Thu, 07 March 2013, 17:16:01 »
Also, what are the options with the DIP switch?
Thanks,
John
Offline jcrouse
« Reply #7 on: Thu, 07 March 2013, 17:17:38 »
OK, yeah, I can see the traces, duh (me). Cap lock works as expected and the spacebar led lights up after pressing FN and spacebar, esentially toggling on the function layer.
Offline Jocelyn
  • 조셀린
« Reply #8 on: Thu, 07 March 2013, 17:18:54 »
Thanks,
John
POKER V01.pdf
« Last Edit: Thu, 07 March 2013, 17:21:31 by Jocelyn »
Offline Gupgup
« Reply #9 on: Thu, 07 March 2013, 17:27:21 »
Would like to see this, cause I want LEDs on my WASD keys! Are the wires running from the right lead of the  LEDs to the USB? Or do they get there power from another source?
Offline jcrouse
« Reply #10 on: Thu, 07 March 2013, 17:48:49 »
The LEDs seem to work like so ...
Caps Lock, just as you would suspect.
The LED under the Spacebar, Right Shift and three bottom row keys on the right all light up when you press the FN key and then the spacebar, esentially toggling those four keys to act as arrow keys.
As stated, I am not an LED guy and just wanted to know what modes were active. I put an LED on the Cpas Lock and Spacebar switch.
John
Offline Jocelyn
  • 조셀린
« Reply #11 on: Thu, 07 March 2013, 18:04:22 »
Mine are wired to Esc Lock, but you could go directly to the USB or use a different led (Spacebar, rewire shift, alt, win, ctrl, etc.)
John
Haha Yeah I know you were only asking about the regular set up. This is why I didn't post initially, but I figured seeing the underside of my board might help with the regular keys too.
Offline fydo
  • Meow!
« Reply #12 on: Thu, 07 March 2013, 22:49:10 »
I'd be interested in seeing those photos as well! :)
Offline Jocelyn
  • 조셀린
« Reply #13 on: Fri, 08 March 2013, 01:57:26 »
Used my SGNote2. I hope this is good enough :)
Edit - You can also see how to do the normal seven by looking at the Caps Lock in the photo.
« Last Edit: Fri, 08 March 2013, 02:32:11 by Jocelyn »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Fri, 08 March 2013, 10:13:33 »
The easiest way to turn off any additional hand wired would probably be to stick a small 2way switch inline on the positive. Should be easy enough to place under the pcb along the back somewhere would just need to cut a small hole for it.
For default, the Poker has LED on ~/esc, caps lock, Space, Rwin, menu, Rctrl, Rshift.
Offline WhiteFireDragon
    • youtube
« Reply #15 on: Fri, 08 March 2013, 12:46:14 »
[img]
I think I've seen something like that before.
Offline fydo
  • Meow!
« Reply #16 on: Sat, 09 March 2013, 16:31:08 »
Thank you for the great photo!
With "piggybacking" off of other keys like this, is there any concern about having enough power? eg. Can I power an entire keyboard worth of LEDs off of the ESC key like that?
« Last Edit: Sat, 09 March 2013, 16:33:36 by fydo »
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #17 on: Sun, 10 March 2013, 00:27:09 »
So i was a copy cat...
Not as good/clean of a job as Jocelyn but it works!
(sorry my old school D80 doesnt capture low light very well :P)
« Last Edit: Sun, 10 March 2013, 00:34:02 by Glod »
Offline Jocelyn
  • 조셀린
« Reply #18 on: Sun, 10 March 2013, 00:30:17 »
Not as good/clean of a job as WhiteFireDragon but it works!
FTFY  ;)
I only took the photo and have never soldered lol. Nice job btw :)
« Last Edit: Sun, 10 March 2013, 00:32:51 by Jocelyn »
Offline Glod
    • YouTube Channel
« Reply #19 on: Sun, 10 March 2013, 00:37:07 »
thanks, i figured id add that in there when i installed my new plate :)
Offline Jocelyn
  • 조셀린
Re: Re: Poker (from iMAV's GB) and Backlighting
« Reply #20 on: Sun, 10 March 2013, 00:41:47 »
Oh btw, did you dremel out the two case ridges to allow room for the wires? I probably should have also mentioned that before.
Offline Glod
    • YouTube Channel
« Reply #21 on: Sun, 10 March 2013, 00:55:10 »
no, but i didn't notice any problems, all the screws went in fine and everything is level. i used really thin wires i found around from kits.
not sure though how the wires will do in the cnc pure case i got coming in.... we shall see
Offline Jocelyn
  • 조셀린
« Reply #22 on: Sun, 10 March 2013, 00:58:11 »
Haha I'm waiting on the same case. Worse case scenario you can dremel it down a bit.
I'll post a photo of what WFD did to my plastic case ridges whenever the CNC arrives.
« Last Edit: Sun, 10 March 2013, 01:26:55 by Jocelyn »
