Author Topic: HPE 87 Keycap Replacements (37key and 87key)  (Read 3822 times)
Offline morpheus
« on: Fri, 08 March 2013, 02:37:36 »
Hi,
Can anybody tell me where I can find replacement key caps in either 37 key set, or 87 key set for my HPE 87 board?
I'm kinda worried that the keycap replacement set won't match the same height as the original keycap set.
How do I know which ones will match the same height as my originals?
I would like to replace it with lettered, colored key caps.
Thanks.
Here's a picture, which isn't mine.
« Last Edit: Fri, 08 March 2013, 02:55:06 by morpheus »
Offline morpheus
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: HPE 87 Keycap Replacements (37key and 87key)
« Reply #2 on: Fri, 08 March 2013, 10:22:53 »
Yes, it would have 'oem' profile keycap. Also set like this, this or this depending on what style you are after.
Offline gigibecali
« Reply #3 on: Fri, 08 March 2013, 11:15:51 »
I'd suggest you go for a complete set for your peace of mind.
The originals are "OEM" profile. AFAIK that means just that they're taller than Cherry profile.
That's not a lot of information :)
I bought a set of standard, white, cherry profile pbts from feng and they're just fine. HPE-87 is a Filco clone.
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline morpheus
« Reply #4 on: Fri, 08 March 2013, 11:31:57 »
You mean like an 87 key set?
Which sets out there will fit this HPE 87 (considering all the costar stabilizers etc.)???
Thanks.
« Reply #5 on: Fri, 08 March 2013, 11:34:44 »
As far as I am aware the HPE has nothing atypical about it. Any 87/104 MX set will work fine.
Offline gigibecali
« Reply #6 on: Fri, 08 March 2013, 12:14:36 »
that's correct.
Offline bazemk1979
« Reply #7 on: Fri, 08 March 2013, 14:19:18 »
so whats the difference between this board and Filco TKL? they look identical all the way.....
Offline noons
« Reply #8 on: Sat, 09 March 2013, 15:29:41 »
Yea this was most likely a copied filco design. They are probably very similar, but if your going for quality you cant really beat paying the extra money for the filco. Oh and personally I hate the logo above the arrow keys.
Tofu65 Turquoise Tealios | Drop ALT LP Alpacas | 2X Leopold FC750R MX Brown | KUL MX Brown w/Cherry Stab MOD | Leopold FC660C BLANK | REALFORCE 87U 45G | HHKB PRO2 | Leopold TKL MX RED | Filco Majestouch 2 TKL MX BLUE
