Author Topic: Found in my garage... any good?  (Read 5048 times)
Offline natgab
« on: Thu, 14 March 2013, 14:56:59 »
My brother had this with his junk in the garage.  So I grabbed it. :cool:
It is a Keytronic model # E03601QLPS2, assembled in Mexico with a PS/2 connector.  The keys are kind of soft, is this a mechanical or dome?  Looked in eBay, but only finding storefront listings.  Nothing from an individual that might go to the trouble of adding specifications.  It does have a little opening in back with markings XT/enhanced AT along where the power cable is tucked in but not a DIP switch thing.
It is heavier than my cheap black MS keyboard.  My black Apple keyboard is heavier though.  Closest I found on eBay was this, but it has a C at end of the model number and has Windows keys:
http://www.ebay.com/itm/KeyTronic-E03601QLPS2-C-Keyboard-/170998576733?pt=PCA_Mice_Trackballs&hash=item27d04f365d
P.S. I used mild soap and water on a paper towel.  KB noob, any suggestions?
Keyboard snob in training
Hackintosh / Linux / reluctant Windows users
Offline ishumprod
Re: Found in my garage... any good?
« Reply #1 on: Thu, 14 March 2013, 15:00:09 »
carefully pull a key off ( a little on, like the Q ) and show us a picture of what's under the keycap ( the switch )
home-made TKL rubber dome keyboard !
Offline lazerpointer
  • ya gotta stay phresh
« Reply #2 on: Thu, 14 March 2013, 15:10:30 »
Yeah, the switches could be of some value. Other than that, it looks like the epitome of "old ass keyboard"
i type, therefore i geekhack
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 14 March 2013, 15:13:01 »
Its just an old Keytronic, which are nice rubberdomes but nothing special.
Offline DavinDidIt
« Reply #4 on: Thu, 14 March 2013, 15:33:05 »
I sometimes use one of these at my work.  Keytronic keyboards are amongst the highest quality rubber dome keyboards there are, not including topre of course. :)
If you don't have anything else, this is actually not too bad of a keyboard to type on!
KMAC 2, HHKB
Offline natgab
« Reply #5 on: Thu, 14 March 2013, 15:33:45 »
--Opened up the keys.  Not a cherry switch, I'll post a picture in a bit.  My phone is stupid and won't cooperate.
EDIT: Here is the key w/o keycap:
« Last Edit: Thu, 14 March 2013, 20:44:58 by natgab »
Offline natgab
« Reply #6 on: Thu, 14 March 2013, 15:35:58 »
--Since it was outside in the garage.  Would the dampness affect it?  I'm in Southern California, so I'm not talking freezing weather or snowstorms.  Just cold and moisture, I'm near the beach.
Offline DavinDidIt
« Reply #7 on: Thu, 14 March 2013, 15:51:31 »
Just like any other electronic device, it probably wouldn't respond too well to moisture and exposure.   Depending on how close you are to the beach, I would think that this effect would be magnified by the amount of salt/sand particles in the air there.  Rubber and metal don't like salt and sand either :P
Best way to find out is to try it :)
KMAC 2, HHKB
Offline nsrexler
« Reply #8 on: Thu, 14 March 2013, 16:01:48 »
Only one way to find out! Worst case scenario, it doesn't work and you have a broken keyboard to throw out.
(Well actually the WORST case scenario is that it shorts out your motherboard, but I'd say that's pretty unlikely.)
Offline natgab
« Reply #9 on: Thu, 14 March 2013, 20:12:41 »
---I live about 1.5 miles (3 km?) from beach.  So we do still a bit of dew in the mornings.  I tried out the keyboard in Windows, both with the PS/2 and with my PS/2 - USB sex changer thing.  No response, since I just brought it from outside I'm hoping it still just needs an overnight drying out / climate adjustment to come back to life.
I feels pretty good for a dome switch.  If I revive it, I think I will use it to try and learn Colemak.
Offline sicaine
« Reply #10 on: Fri, 15 March 2013, 08:36:54 »
It does look horrible and doesn't have any real switches. I would throw it away
Online Findecanor
« Reply #11 on: Fri, 15 March 2013, 12:15:33 »
I would keep it as a backup keyboard, if I did not already have any and if I don't mind the "big-ass" Enter and small Backspace.
Key Tronic rubber domes are widely considered to be among the better rubber domes. They do not become mushier with time and use as much as other rubber domes.
Offline natgab
« Reply #12 on: Fri, 15 March 2013, 13:09:40 »
--Seems to be dead.  I tried again on my PC under Windows, I have used other PS/2 devices before, so its not the connector.  Also tried my laptop with a USB - PS/2 adapter.  Does not show up.
Offline davkol
  •  Post Editing Timeout
« Reply #13 on: Fri, 15 March 2013, 15:36:28 »
I have quite few KeyTronic 'boards in the closet, and most of them actually don't work only because the membrane sheet is out of position. It doesn't mean yours suffers from the same issue, though.
Offline natgab
« Reply #14 on: Fri, 15 March 2013, 20:51:14 »
---Is there a particular trick to opening them up?  Or just try and pry the part where the keyboard comes together.  I think I will try to see if something is loose on my keyboard.
Offline laffindude
« Reply #15 on: Sat, 16 March 2013, 00:05:14 »
PS2 is not hotplug. Make sure you reboot.
Dumb adapter won't work. You need an active converter.
Offline davkol
« Reply #16 on: Sat, 16 March 2013, 10:19:46 »
Either that, or there are screws under the black pads on the bottom side. IIRC mine have some screws.
Offline DavinDidIt
« Reply #17 on: Sat, 16 March 2013, 18:40:28 »
Either way, the case and keys on that keyboard are in dire need of a bath!
KMAC 2, HHKB
Offline natgab
« Reply #18 on: Sat, 16 March 2013, 21:59:05 »
---LOL, yeah took the picture before I did any cleaning.  Looks a little better.  Didn't have time to fiddle with it, maybe tomorrow I will take it apart.  Trying to find some how to videos, but didn't find any.  I guess I will try and check the black pads for screws like davkol suggested.
