Author Topic: Any tkl or smaller boards for mac?  (Read 3020 times)
Offline Harryboii
« on: Mon, 18 March 2013, 04:47:54 »
Does anyone know of any mac compatible boards that are tkl or smaller?
Offline davkol
  •  Post Editing Timeout
Re: Any tkl or smaller boards for mac?
« Reply #1 on: Mon, 18 March 2013, 05:02:59 »
Matias * Mini Pro
Offline bazemk1979
Offline whiskerBox
« Reply #3 on: Mon, 18 March 2013, 09:13:12 »
HHKB
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline daerid
    • Rossipedia
« Reply #4 on: Mon, 18 March 2013, 11:54:12 »
/thread
Offline Rule16
  • R.I.P. SmallFry
« Reply #5 on: Mon, 18 March 2013, 12:23:06 »
Matias * Mini Pro
Does that support PS/2? I'm looking for more alps after my find :)
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #6 on: Mon, 18 March 2013, 12:34:02 »
Matias * Mini Pro
If you're looking for Alsps switches, then I think the Matias is probably your best bet. You can buy them direct, or from MechanicalKeyboards.com.
However, as a fellow Mac user, I'm more of a fan of the KBT Pure and KBT Race (if you need something a little bigger). I'm currently using a KBC Poker, but those are currently hard to come by at the moment.
The Matias Tactile Pro Mini is $116 and the KBT Pure is approximately $90.
Hope that helps!
Offline Rule16
  • R.I.P. SmallFry
« Reply #7 on: Mon, 18 March 2013, 12:39:00 »
Matias * Mini Pro
Hope that helps!
I'm not an Mac user, just looking for some good alps switches with PS/2. You may hate me for saying this, but I'm actually a PC gamer :P
Dvorak Only Zone
Offline mashby
    • Mashby
« Reply #8 on: Mon, 18 March 2013, 12:44:44 »
Sorry, I got confused and thought you were the original poster.   :-[
Offline Rule16
  • R.I.P. SmallFry
« Reply #9 on: Mon, 18 March 2013, 12:54:32 »
Its ok, lol... Are the KBT Pure and Race alps? I thought they were a MX switch.
Dvorak Only Zone
Offline mashby
    • Mashby
« Reply #10 on: Mon, 18 March 2013, 13:23:41 »
They are Cherry MX.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #11 on: Mon, 18 March 2013, 14:21:18 »
For Mac users I will always say Matias makes the best keyboards.
i type, therefore i geekhack
Offline Harryboii
« Reply #12 on: Mon, 18 March 2013, 18:40:48 »
Matias keyboards just don't seem appealing to my eye for some odd reason. Perhaps it is the rounded edges. Would a filco keyboard or QFR be compatible?
« Reply #13 on: Mon, 18 March 2013, 18:47:01 »
If compatibility is your only concern, then you can pick any keyboard. I was under the impression that you needed the Mac OS symbols and stuff, in which case your options are far more limited.
Offline Harryboii
« Reply #14 on: Mon, 18 March 2013, 19:20:11 »
I should have been a bit more clear but nevertheless I got to learn about a new keyboard, and others were able to get something out of this post as well. =)
Offline Michael
  • Formerly Bro Caps
« Reply #15 on: Mon, 18 March 2013, 19:31:10 »
HHKB's were born to be used on a Mac :)
Offline laden3
« Reply #16 on: Mon, 18 March 2013, 19:35:54 »
If I am not mistaken, some duckies have DIP switches to switch the position of alt and super keys.
I rrrove brrracks.
Offline mashby
    • Mashby
« Reply #17 on: Mon, 18 March 2013, 20:45:29 »
Doing a search for Mac Compatible, in stock keyboards on mk.com will show you a few options, but if you uncheck the "in stock" box, you'll see a ton more.
As long as the keyboard is recognized by the OS, you can swap key caps for the Command and Alt key and either flip a dip switch on the board if it's supported to swap the switches, or change it in software.
