Author Topic: wood grain pattern case  (Read 18050 times)
Offline tauburn
Re: wood grain pattern case
« Reply #50 on: Mon, 22 April 2013, 12:47:29 »
Thanks guys.  Painting it was a pain in the ass.  Even thin coats had a tendency to fill the "grain" and sit on the surface, so after each thin coat I had to blot with a paper towel to push the paint into the grain and remove excess paint.  Ended up applying more thinner coats than I would normally do, but it was a nice day and I had the time, for once, so it was worth it.
i was going to do exactly what you did (with klaxon and all) with mine but was worried this would happen.
Offline cytoSiN
  • ATCG
« Reply #51 on: Mon, 22 April 2013, 13:13:53 »
I didn't even think of it until I started to paint.  Necessity is the mother of invention, I guess.  I think it worked out fine in the end.
Model M 1391401 1989 || Ducky DK9008G2 Pro LE || XArmor U9BL-S LED || CM Storm QuickFire Rapid
Offline jdeblese
« Reply #52 on: Fri, 21 June 2013, 07:31:02 »
Interesting idea! Gotta try it when I can get ahold of a brush.
For people looking for a wood texture, have you considered drybrushing it? Give it a dark base coat (or use a black case) and then paint lightly using a lighter color with a brush that's almost dry. The paint will only stick to the raised areas, highlighting the texture. Do it with multiple colors of varying dryness to increase the effect.
Notice how the wood is darker in the cracks?
I'll do some experiments if I can find the materials.
Offline balanar
« Reply #53 on: Fri, 21 June 2013, 08:08:29 »
Gotta wait till someone does it with a nice brown colour...
Offline cytoSiN
  • ATCG
« Reply #54 on: Fri, 21 June 2013, 08:31:44 »
I'll probably do my next one brown to go with the Sindarin GB.
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #55 on: Mon, 24 June 2013, 15:36:06 »
This is quite a cool mod, might have to give this a try.
