Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2263523 times)
Offline Dsan
Re: GH60 Group Buy
« Reply #1100 on: Thu, 18 April 2013, 07:31:16 »
Will ordering switches delay the shipment,or will they be ready when the shipment of the keyboards will start?Also,are the switches pcb or plate mounted? :)
if using plate, both pcb and plate mounted switches can be used.
if not using a plate, only use pcb mounted switches
Yeah I know this,maybe I didn't ask it properly.I want to know if the switches offered in the group buy are plate or pcb mounted :D
Offline mkaito
Re: GH60 Group Buy
« Reply #1101 on: Thu, 18 April 2013, 07:35:14 »
Both are offered, I believe. Just specify in the order which kind you want.
Offline llovro
Re: GH60 Group Buy
« Reply #1102 on: Thu, 18 April 2013, 07:52:10 »
does gh60 have reattachable usb cable or how does it work?
Offline mkaito
Re: GH60 Group Buy
« Reply #1103 on: Thu, 18 April 2013, 07:57:00 »
PCB has a mini USB plug. You need to find a cable on your own. Mimic's cables seem to be quite popular, but I guess any A-MiniB cable will work, if you happen to have one lying around.
Offline llovro
Re: GH60 Group Buy
« Reply #1104 on: Thu, 18 April 2013, 08:01:23 »
oh okay, thanks
Offline pix3l_fodder
Re: GH60 Group Buy
« Reply #1105 on: Thu, 18 April 2013, 16:53:00 »
Those space bar wires, can anyone explain if they're required for cherry stabs on an ISO 1.25x?
You would need a 6.25 spacebar wire
How would one change my order, especially as its not listed on the front page as an order-able item?
Re: GH60 Group Buy
« Reply #1106 on: Thu, 18 April 2013, 16:54:11 »
If you need to change an order, just submit a new order, and in the comments write "cancel my old order."
Offline mkaito
Re: GH60 Group Buy
« Reply #1107 on: Thu, 18 April 2013, 16:57:27 »
Just specify the wire size along with the stab set order.
Re: GH60 Group Buy
« Reply #1108 on: Thu, 18 April 2013, 17:05:19 »
yep done that with the updated order, followed instructions from last page.
Offline Winther
Re: GH60 Group Buy
« Reply #1109 on: Thu, 18 April 2013, 17:10:30 »
What would be the spacebar wire size for the ISO 1.25 plate? 6.25 right?
Do you guys have a standard wire size if its not specified in the order?
Offline jspark
Re: GH60 Group Buy
« Reply #1110 on: Thu, 18 April 2013, 18:42:46 »
I don't know how much and where to pay. Please send me the invoice or can you provide any functionality to see what I really ordered?
Thanks
KBC Poker X Cherry MX Black switch
Filco Majestouch2 Ninja Cherry MX Blue switch
IBM Model M 1391401 in 1988
Offline MKULTRA
  • telling it how it is
Re: GH60 Group Buy
« Reply #1111 on: Thu, 18 April 2013, 20:34:41 »
Thanks
Read the thread.  All that info was posted
Offline miscsubbin
Re: GH60 Group Buy
« Reply #1112 on: Thu, 18 April 2013, 20:52:48 »
Can we get MX Green switches?
GH60 Group Buy
« Reply #1113 on: Thu, 18 April 2013, 20:55:25 »
You can get Red, Blue, Brown, Black, Green, or (Light) Grey.
Plate mount or PCB mount.
:D
Re: GH60 Group Buy
« Reply #1114 on: Thu, 18 April 2013, 21:03:13 »
:D
Adding grease to the stem of a Green would basically be a ghetto white, correct?
Offline cusx
Re: GH60 Group Buy
« Reply #1115 on: Thu, 18 April 2013, 21:03:35 »
:D
There isn't any clear switches ? Because I ordered some.
Offline duq
  • Connoisseur
GH60 Group Buy
« Reply #1116 on: Thu, 18 April 2013, 21:29:47 »
:D
Check the group buys section. There is a clear group buy.
Re: GH60 Group Buy
« Reply #1117 on: Thu, 18 April 2013, 21:31:09 »
If you order MX Whites or Clears from this GB, we will most likely have to submit the order for those to 7bit, after his preorder sale is over. Expect higher prices and delayed shipping.
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
Re: GH60 Group Buy
« Reply #1118 on: Fri, 19 April 2013, 06:06:49 »
Ordered ANSI 1.5x plate with blue switches, really love the HHKB layout with the normal RSHIFT :D
Offline miscsubbin
Re: GH60 Group Buy
« Reply #1119 on: Fri, 19 April 2013, 07:19:56 »
Can I get a PM confirming my order update?
Offline Dsan
Re: GH60 Group Buy
« Reply #1120 on: Fri, 19 April 2013, 07:30:31 »
Ordered :D Can someone please tell me if what I wrote on the comment section is possible?Thank you
Offline 4814
Re: GH60 Group Buy
« Reply #1121 on: Fri, 19 April 2013, 07:59:33 »
Quick question:
Am I able to use six 1.25x instead of the four 1.5x and the two 1x(?) keys on the bottom row with the Ansi 1.5x-Plate? If yes, does it affect the spacebar/stabilizer?
And if I buy the switches from 7bit (sorry... but I want white ones :D) and don't want the assembly service, it is recommend to let him sent the switches directly to me. Am I right?
BTW ty for this great group buy! Really looking forward to my GH60 :)
Edit: Think I got it... I could use six 1.25x but I would need a 7.5x Spacebar which seems to be pretty rare...
« Last Edit: Fri, 19 April 2013, 08:22:40 by 4814 »
Re: GH60 Group Buy
« Reply #1122 on: Fri, 19 April 2013, 08:24:51 »
You can check it yourself here:
Here are your orders. I think from now on, if you need to change an order, just submit a new order, fill now the order change sheet to delete old order. That's faster than us manually changing stuff. But in the new order, put in the comments section "new updated order". Use Ctrl + F and search for yourself since there are a lot of entries.
red  = GH PCB
green = plates
Order confirmation
Yes, we can do that. Don't you want your name on the package if it gets delivered to your office, so they know who the package is for?
Quick question:
No, not the way you are thinking. The spacing is off and won't work with the switch mounts on the PCB. You can use 7x 1.25u mods with a 6.25u spacebar, just like a Poker.
Offline mkaito
Re: GH60 Group Buy
« Reply #1123 on: Fri, 19 April 2013, 08:37:45 »
Someone just pointed me at massdrop when I asked about group buy platforms. I assume you've seen it, and decided it's no good for this. Would you mind sharing your reasoning?
Offline Dsan
Re: GH60 Group Buy
« Reply #1124 on: Fri, 19 April 2013, 08:44:57 »
The secretary knows it's for me so it's not needed in my end,but I don't know if it's required to ship the package.I received an USPS package from EliteKeyboards without name on it,not sure how it works with other postage services.Sorry to bother you,you replied a question I made on the poker acrylic case,but since I can't speak English very well I wonder if I understood the answer correctly.Universal ANSI plate + Acrylic GH60 Poker(from acrylic case) will be ok together,right? :p Sorry again,just want to be sure :D
Re: GH60 Group Buy
« Reply #1125 on: Fri, 19 April 2013, 08:50:00 »
I was actually approached by someone from Massdrop, and I'll tell you what I told them: I think our GB is just too complex in logistics for them to package it in any way that makes sense.
Yes, just fine, as long as you remembered to order the Cherry PCB mount stabilizers. :)
Also, being international, I'm pretty sure we will have to put some name on the customs form.
Offline Dsan
Re: GH60 Group Buy
« Reply #1126 on: Fri, 19 April 2013, 08:55:25 »
Thank you so much :D
Do I need to update the order by myself?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: GH60 Group Buy
« Reply #1127 on: Fri, 19 April 2013, 08:59:01 »
HOLY ****...430+ PCB's ordered.
-Enzo Ferrari
Re: GH60 Group Buy
« Reply #1128 on: Fri, 19 April 2013, 09:04:41 »
No, you did it right already.
Yes, so far. 50 of those are for imsto, but still!
Offline GeorgeK
Re: GH60 Group Buy
« Reply #1129 on: Fri, 19 April 2013, 09:05:17 »
I'm having it either way but is the part assembled PCB $30 (as in the first post) or $40 (as on the order form)?  Also, seriously, b****r the DIY kit - that looks impossible!  Especially for the sake of $5 but even for $15!
Re: GH60 Group Buy
« Reply #1130 on: Fri, 19 April 2013, 09:06:43 »
It's $30.
And it's not impossible, just improbable!
Offline aggiejy
GH60 Group Buy
« Reply #1131 on: Fri, 19 April 2013, 09:19:44 »
Question... I placed a switch order with 7bit for some Whites and put "GH60" on it. However, I don't want to hold up my Gh60 order if it's ready before the switches. (They aren't my only switches, so most impt to get my Gh60s first!)
So the question is: should I ask to add direct shipping to my 7bit order, or would I have the option of paying you guys additional shipping to proxy the switches later?
Offline eon
Re: GH60 Group Buy
« Reply #1132 on: Fri, 19 April 2013, 09:42:24 »
Does the HHKB plate still has a bottom row for 1.5 1 1.5 7 1.5 1 .15 ? I'm quite confused with this plate, it's tagged as "true" HHKB in the order confirmation page. Wondering if things have changed.
Thanks.
Poker MX Red - Photos
Offline GeorgeK
Re: GH60 Group Buy
« Reply #1133 on: Fri, 19 April 2013, 09:49:53 »
It's $30.
That makes the pre-assembled option all the more appealing in my eyes - $5 to avoid all that hassle!  Even the Ergo Dox is all through hole (at least it looks that way) and that looks complicated to build...
Thanks for getting back to me
GK
Offline ItsBc
  • BARACOOT
    • Portfolio
Re: GH60 Group Buy
« Reply #1134 on: Fri, 19 April 2013, 09:52:28 »
Finally signed up for the GB. Can't wait ^_^
Re: GH60 Group Buy
« Reply #1135 on: Fri, 19 April 2013, 09:53:53 »
If it were me, I would just have 7bit direct ship those switches to you. The GH60 shipping tag is more for people who need assembly.
Thanks.
Yes, that is still the layout. The other HHKB layout with the 6u spacebar is just for a few of us fools who may want that option with a case, and has nothing to do with any plates offered in this GB.
Offline SmallFry
Re: GH60 Group Buy
« Reply #1136 on: Fri, 19 April 2013, 10:36:11 »
Couple of questions pertaining to the spreadsheet...
One, the row 2 is hidden in the spreadsheet, is that my order? One, who's order is row 2? Is that JCrouse, Halverson etc that don't have any orders submitted?
Two, a couple of users have had nothing in their order, ones that popped out at me were Jcrouse, Halverson, and Longweight to name a few... That seems to be a slight problem?
Three, is the form auto updating? If so, I don't see my order. (Placed by Prdlm2009, but shipping to me) EDIT: I'm a dummy. I see it now.
« Last Edit: Fri, 19 April 2013, 10:43:28 by SmallFry »
Offline GeorgeK
Re: GH60 Group Buy
« Reply #1137 on: Fri, 19 April 2013, 10:42:07 »
Longweight has definitely cancelled his order if it helps...
Re: GH60 Group Buy
« Reply #1138 on: Fri, 19 April 2013, 10:42:57 »
Three, is the form auto updating? If so, I don't see my order. (Placed by Prldm2009, but shipping to me)
Row 2 is private. It's just order totals.
The users with nothing in their order have placed new updated orders. So I had to delete those old orders. But I don't delete rows from the spreadsheet, just in case something goes wrong. It's nothing for you to worry about. :)
I see the order. In the public spreadsheet. Maybe you are typing his username wrong? The "comments" field is also private.
Offline eon
Re: GH60 Group Buy
« Reply #1139 on: Fri, 19 April 2013, 10:43:07 »
Thanks.
Great. Thanks a lot jdcarpe.
Offline SmallFry
Re: GH60 Group Buy
« Reply #1140 on: Fri, 19 April 2013, 10:44:49 »
Gotcha, I edited my post after I realized my mistakes etc. Thank ya. BTW look at IMSTO go. 50 DIY kits. :eek:
Re: GH60 Group Buy
« Reply #1141 on: Fri, 19 April 2013, 15:49:38 »
Sorry about this but I resubmitted my order again, bought another due to the price reducing to $30 :) I was unable to find the spacebar wire length for HHKB so added a comment. Hope i've not complicated matters.
Offline WhiteFireDragon
    • youtube
Re: GH60 Group Buy
« Reply #1142 on: Fri, 19 April 2013, 17:15:36 »
I just updated the remaining order changes that were submitted up to this point. Jdcarpe did most of them though :)
And please no more PMs for order changes. It will get buried to the next page within 2 days and I won't remember. Just fill the form. I also hid a lot of the rows in the public confirmation form. Don't worry about those, they're just duplicate orders from changes, so your name doesn't show up twice.
Elton, please just submit a new order. You changed your order 8 times, sometimes adding stuff and sometimes changing stuff. Too confusing so just submit a new order.
I have a semi-important update soon...
Offline Jocelyn
  • 조셀린
Re: Re: GH60 Group Buy
« Reply #1143 on: Fri, 19 April 2013, 17:18:44 »
Hmmmm I was about to submit my order, but I guess I'll wait a little longer :)
Offline fydo
  • Meow!
Re: GH60 Group Buy
« Reply #1144 on: Fri, 19 April 2013, 17:21:17 »
Phew, finally got around to filling out my order. This is an exciting project!
The suspense! :o
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline cobraj
Re: GH60 Group Buy
« Reply #1145 on: Fri, 19 April 2013, 23:39:43 »
Haha.
How intriguing :P
Offline Jocelyn
  • 조셀린
Re: GH60 Group Buy
« Reply #1146 on: Fri, 19 April 2013, 23:54:09 »
Haha.
How intriguing :P
I originally had some very irrational ideas going through my head like a free Aluminum Case for anyone who bought a full kit!! ROFL
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #1147 on: Sat, 20 April 2013, 00:19:27 »
semi-important updates
let's hear em  :p
    • youtube
Re: GH60 Group Buy
« Reply #1148 on: Sat, 20 April 2013, 00:23:32 »
I'm currently rendering all the additional layouts and I'm posting them one by one as they finish. Look at the OP for now. Takes a bit of setup time for each one :/
Basically just some price updates, PCB, plates, layouts, etc.
Offline Jmneuv
Re: GH60 Group Buy
« Reply #1149 on: Sat, 20 April 2013, 02:43:00 »
Thank you.
Looks like most of the plates don't support off center spacebar (cherry); Would a wider slot weaken the support too much to allow for plate mount?
