Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2263522 times)
Offline orlando
Re: GH60 Group Buy
« Reply #1200 on: Sun, 21 April 2013, 15:49:05 »
Finally placed my order!
Offline gnubag
Re: GH60 Group Buy
« Reply #1201 on: Sun, 21 April 2013, 16:10:09 »
Offline Jocelyn
  • 조셀린
Re: GH60 Group Buy
« Reply #1202 on: Sun, 21 April 2013, 16:12:54 »
Offline guilleguillaume
Re: GH60 Group Buy
« Reply #1203 on: Sun, 21 April 2013, 17:57:28 »
Order sent! I decided to get 4 PCB :D
Offline elton5354
Re: GH60 Group Buy
« Reply #1204 on: Sun, 21 April 2013, 18:02:29 »
Misc
Some orders requested for costar 7x wires. I'm not sure this will be available, as WASDkeyboards is not able to provide them. Costar stabilizers are $7 per set.
If costar 7x wires aren't available, then can you change mine to PCB-mounted stabilizers with 7x wires?
Is it simple to make your own?
Offline gnubag
Re: GH60 Group Buy
« Reply #1205 on: Sun, 21 April 2013, 18:30:22 »
Misc
you would need the right wire and a wire bender.
also you would need measurements on where to bend it.
Offline mauri
Re: GH60 Group Buy
« Reply #1206 on: Sun, 21 April 2013, 18:36:09 »
So I'm sorta confused, does one order the switches via the order form, or separately via deskthority?
I AM BABAR KING OF THE ELEPHANTS
Offline mkaito
Re: GH60 Group Buy
« Reply #1207 on: Sun, 21 April 2013, 18:38:14 »
Please use the order form for this group buy.
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #1208 on: Sun, 21 April 2013, 18:46:12 »
still have to place my order....deciding on a second one....thanks JD, Komar and WFD for this! great job organizing it
Offline chel-
Re: GH60 Group Buy
« Reply #1209 on: Sun, 21 April 2013, 18:50:06 »
Does anyone have any more details on assembly services? I have no interest in actually doing any work if I were to join this XD
Offline stoic-lemon
Re: GH60 Group Buy
« Reply #1210 on: Sun, 21 April 2013, 18:54:07 »
A month and a half of procrastinating and my order is in. I guess I'm one of the few going for the Samwisekoi plate. Would've ordered more, but the new strong Yen is killing me.
Offline TheQsanity
  • SmallFry Lovin'
Re: GH60 Group Buy
« Reply #1211 on: Sun, 21 April 2013, 19:33:29 »
What spacebar stabilizer is for the HHKB, standard and Pure?1
SmallFry! <3
Offline gnubag
Re: GH60 Group Buy
« Reply #1212 on: Sun, 21 April 2013, 19:50:12 »
HHKB spacebars are 7u (not quite sure)
standard (i assume you mean ansi 1.25) and pure are 6.25u
Offline TheQsanity
  • SmallFry Lovin'
Re: GH60 Group Buy
« Reply #1213 on: Sun, 21 April 2013, 19:53:49 »
Would you still need a 7 stabilizer if you are going to do the split spacebar? or would you need two 3.5 or something?
SmallFry! <3
Offline elton5354
Re: GH60 Group Buy
« Reply #1214 on: Sun, 21 April 2013, 19:54:54 »
Seeing even backspace needs stabilizer..So anything bigger than 2x needs one..
Would lister make 7x wires for us? :D
Offline gnubag
Re: GH60 Group Buy
« Reply #1215 on: Sun, 21 April 2013, 20:10:43 »
there is no split spacebar? or did i miss something?
Offline heedpantsnow
  • Old enough to know better
Re: GH60 Group Buy
« Reply #1216 on: Sun, 21 April 2013, 20:51:28 »
Hi, I'm sorry to be dense.  One question I had was clarification on where to order switches.  Thank you Mauri and Mkaito for clarifying to order here, not 7-bit.
Do I need to get 12 of the switches PCB-mount and the others plate-mount if I'm using the universal plate?
Did we ever decide about WASD LED's?  What is the LED color?  Is there a choice?
Could someone please check my order?  I want 2x Poker clones with the option to switch to HHKB layout later.  Just switches for 1 now.  I can solder myself.  (maybe this will also help others who are a little unsure of their order)
GH60 PBC quantity *$40 per PCB, SMD presoldered: 2
GH60 DIY kit quantity*$25, requries SMD soldering: 0
Universal ANSI plate: 2
Universal ISO plate: 0
Poker plate quantity ANSI 1.25x: 0
Switches and stabilizers (stabilizers are in sets, each set is enough for 1 whole keyboard. Switches are per switch)
Costar stabs, Plate-mounted, PCB-mounted cherry stabs (specify spacebar wire size). The switch color you want. FORMAT: quantity x item
2 sets PCB-mounted cherry stabs (6.25 spacebar)
14x PCB-mount brown switches (a few extras)
53x plate-mount brown switches (a few extras)
Assembly service *
 No
Thanks for the help!
I'm back.
Offline fydo
  • Meow!
Re: GH60 Group Buy
« Reply #1217 on: Mon, 22 April 2013, 01:36:29 »
For clears, you can get mx greys, they have the exact same stem. I don't imagine very many will use the stock clear springs.
I didn't realise that you could use MX Greys for an ergo clear mod. Excellent! I've updated my order.
Thanks again for this excellent group buy. Really looking forward to putting my GH60 together. :D
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline korne
    • comscan
Re: GH60 Group Buy
« Reply #1218 on: Mon, 22 April 2013, 01:54:09 »
Placed my order
Offline electrogeek007
Re: GH60 Group Buy
« Reply #1219 on: Mon, 22 April 2013, 02:28:14 »
Placed my order, now the wait begins...  ;D
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: GH60 Group Buy
« Reply #1220 on: Mon, 22 April 2013, 02:31:10 »
just made a last minute order change
if organizers could PM me to confirm my order makes sense that would be great or i guess i can just wait till the final order confirmation thingy comes up.
Offline Batmann
Re: GH60 Group Buy
« Reply #1221 on: Mon, 22 April 2013, 03:14:29 »
ordered,
and awesome OP btw, being able to see all the layouts with the renders is really helpfull, great job  :)
Offline GeorgeK
Re: GH60 Group Buy
« Reply #1222 on: Mon, 22 April 2013, 04:14:22 »
Once orders are closed and payments taken, what's the rough estimate as to production time for the PCBs and plates?
Offline mauri
Re: GH60 Group Buy
« Reply #1223 on: Mon, 22 April 2013, 04:47:21 »
Lastly, which switches are available for this gb?
Offline Sai
Re: GH60 Group Buy
« Reply #1224 on: Mon, 22 April 2013, 04:50:57 »
blue, green, tactile grey(corret me if i am wrong), red, black, brown except for clear and white mx.
Offline mauri
Re: GH60 Group Buy
« Reply #1225 on: Mon, 22 April 2013, 04:55:03 »
Aight, thanks I think I'll order aswell :)
Offline vardhana
Re: GH60 Group Buy
« Reply #1226 on: Mon, 22 April 2013, 05:02:24 »
Misc
According to "Phantom Group Buy" in DT wiki, there was STAB700(Costar 7 units stabiliser). http://deskthority.net/wiki/Phantom_Group_Buy
Does anyone know how did the Phantom organizers provide Costar 7 units stabilizer?
Offline Wraul
Re: GH60 Group Buy
« Reply #1227 on: Mon, 22 April 2013, 05:39:49 »
Someone made each of those by hand.
It might have been litster, but I'm not sure.
Offline TheProfosist
  • Custom Layouts Only!
Re: GH60 Group Buy
« Reply #1228 on: Mon, 22 April 2013, 05:47:03 »
So umm yea gb for the pre soldered pcbs went through already?
Offline MKULTRA
  • telling it how it is
Re: GH60 Group Buy
« Reply #1229 on: Mon, 22 April 2013, 06:04:18 »
No?
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #1230 on: Mon, 22 April 2013, 06:11:14 »
still deciding on switches for my second GH60...
what i decide on won't be able to be changed until september... so much pressure
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
Re: GH60 Group Buy
« Reply #1231 on: Mon, 22 April 2013, 06:25:34 »
Can someone remove my first order from the spreadsheet? I have 2 orders :p
Offline camelCase
  • Don't look at my toes.
Re: GH60 Group Buy
« Reply #1232 on: Mon, 22 April 2013, 06:36:06 »
How did you order your switches? The OP says to go over to deskthority and order there, but I see people ordering them through this thread's gh60 official order form. I'm wondering which way will get you your switches faster?
Offline korne
    • comscan
Re: GH60 Group Buy
« Reply #1233 on: Mon, 22 April 2013, 06:37:36 »
Updated my order with
-2x PCB (SMD presoldered) - $30
-2x bare PCB
- 1 universal ISO
- 1 universal ANSI
- 1x Cherry (PCB-mounted) stabilizers
- 1x Cherry (Plate-mounted) stabilizers
Offline tadbitnerdy
Re: GH60 Group Buy
« Reply #1234 on: Mon, 22 April 2013, 06:40:58 »
I submitted a brand-new order because I freaked out and I wasn't sure if I had my order correct for a poker layout board.  Please delete all previous orders and order changes and go with the latest one (submitted Sunday April 21st).  I added a note in the comments section on the order form to delete all previous orders and order changes.
Thanks again!
-Tad
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #1235 on: Mon, 22 April 2013, 07:09:59 »
well you can order on the GH60 order form in the OP, or you can go to Deskthority and get the switches via that GB. I am getting half of my switches from somewhere else separate from this GB, and the second half on my GH order form. Not sure at the moment which one goes faster, but i will come back and update you.
Also, today is the final day to submit an order, so figure out what you want!
Offline mauri
Re: GH60 Group Buy
« Reply #1236 on: Mon, 22 April 2013, 07:16:40 »
Edited my order, had bit of a mishap
Offline salmo
    • messmore.org
Re: GH60 Group Buy
« Reply #1237 on: Mon, 22 April 2013, 08:08:09 »
I put in a new order to replace my existing one (noted it in the comments).  The new one landed, but it appears the original hasn't been removed.
Not trying to be impatient, I know there is a lot of churn going on right now as the deadline nears.  Just wanted to make sure I noted it.  As much as I would love more GH60's, I'm pretty sure that would not be "good for my marriage." :)
Offline snoozeymon
Re: GH60 Group Buy
« Reply #1238 on: Mon, 22 April 2013, 08:08:58 »
Order placed!
Unfortunately i do not know if my order-information was transferred correctly, since i did not get any confirmation via email or pm??? (except emails from deskthority)
e: nvm just found my order in the spreadsheet
« Last Edit: Mon, 22 April 2013, 08:21:47 by snoozeymon »
Re: GH60 Group Buy
« Reply #1239 on: Mon, 22 April 2013, 08:15:51 »
Assembly service *
 No
Is there anyone who could please help with my questions and review my order?  Do I need to order a mix of plate- and pcb-mount switches??
I'm back.
Re: GH60 Group Buy
« Reply #1240 on: Mon, 22 April 2013, 08:28:22 »
Done.
You can order switches from this GB. We can supply MX Red, Blue, Brown, Black, Green, or Grey (tactile). Ordering them from this GB should be as fast as any method.
Thanks again!
-Tad
Done.
Done.
Assembly service *
 No
Order looks correct to me. The mix of PCB mount and plate mount switches will work great for your assembly. There will be holes with solder pads for LEDs on every switch, but no traces to them. I'm still not 100% sure if the WASD-Esc will have traces for LEDs, but I believe that is the plan.
Offline thoere
Re: GH60 Group Buy
« Reply #1241 on: Mon, 22 April 2013, 08:30:52 »
I ordered my switches from the GB on Deskthority and had them shipped to the gh60 distributor. How do you associate my order with those switches?
Offline raphdu57
Re: GH60 Group Buy
« Reply #1242 on: Mon, 22 April 2013, 08:33:56 »
First of all I really wanted to thank anyone involved in the realization of this project, you've done an amazing work so far !
Would it also be possible to remove my old order ? I submitted a new one a few days ago !
Also @heedpantsnow You may need 2x 7x spacebar  wires if you want a true HHKB layout.
QFR with MX brown
Offline mkaito
Re: GH60 Group Buy
« Reply #1243 on: Mon, 22 April 2013, 08:47:45 »
Can you actually make your own traces, in case you want LEDs at some point?
Offline mauri
Re: GH60 Group Buy
« Reply #1244 on: Mon, 22 April 2013, 08:58:11 »
I'd assume by your email or note in invoice or sth, but I'd want a confirmation on that aswell.
« Last Edit: Mon, 22 April 2013, 09:00:41 by mauri »
Offline chel-
Re: GH60 Group Buy
« Reply #1245 on: Mon, 22 April 2013, 09:21:15 »
Can someone please clarify - If I'm going for ANSI 1.5x - full 1.5x mod, WKL, or HHKB do I a need 7x or 6.25x spacebar wire?
Re: GH60 Group Buy
« Reply #1246 on: Mon, 22 April 2013, 09:38:18 »
You need a 7x wire, which is why I ignored your last order change request. :)
UPDATE:
THE SWITCH SUPPLIER JUST INFORMED ME THAT THE ONLY GREY SWITCHES HE HAS ARE ACTUALLY LINEAR (DARK GREY).
THESE WILL NOT WORK FOR "ERGO-CLEAR" MOD.
SORRY FOR ANY CONFUSION, AS I WAS JUST INFORMED OF THIS JUST NOW. IF YOU NEED TO CANCEL SWITCHES, PLEASE SUBMIT AN ORDER CHANGE REQUEST.
You can still order MX Clear or MX Grey (tactile) from 7bit on Deskthority, or we will place the order with 7bit if you order them through this GB.
« Last Edit: Mon, 22 April 2013, 10:20:55 by jdcarpe »
Offline chel-
Re: GH60 Group Buy
« Reply #1247 on: Mon, 22 April 2013, 09:49:09 »
thanks XD
Offline r3dx
Re: GH60 Group Buy
« Reply #1248 on: Mon, 22 April 2013, 10:18:06 »
Finally submitted my order!  :D
Thanks to everyone who put this together!  :)
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: GH60 Group Buy
« Reply #1249 on: Mon, 22 April 2013, 10:22:20 »
I was trying to read through everything to see what I need to change in my order, but is the Universal 10x the only one that will support a 10x spacebar or do all ansi 150 layouts support it also?
