Author Topic: Shoddy assembly on a Realforce  (Read 3121 times)
Offline khaangaaroo
« on: Fri, 22 March 2013, 01:14:49 »
Get ready folks, this is a big one. Today I opened up a recently acquired 86u to move some domes around, and one of the domes had TWO capacitive springs underneath it!  :eek:
I actually couldn't feel the difference between the key with two springs and another with just one. It registered key presses like normal. I'm not surprised that I found two springs under one dome though. When you have a bunch of those springs around, they stick together and sit within one another pretty easily.
« Last Edit: Fri, 22 March 2013, 01:24:13 by khaangaaroo »
Offline deazncy
Re: Shoddy assembly on a Realforce
« Reply #1 on: Fri, 22 March 2013, 01:19:34 »
Strange.. Have you fixed it? Or is it not as big of a problem that it has to be fixed?
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Offline khaangaaroo
« Reply #2 on: Fri, 22 March 2013, 01:22:13 »
I just left the extra spring out as I was putting the board back together. It's really not a big deal. I'm just creating conversation :)
Offline calavera
« Reply #3 on: Fri, 22 March 2013, 01:22:50 »
LOL are you serious? I never noticed.
Offline khaangaaroo
« Reply #4 on: Fri, 22 March 2013, 01:29:36 »
Haha yeah, pretty funny. I never would have either if I didn't take it apart.
Offline iri
« Reply #5 on: Fri, 22 March 2013, 02:30:37 »
have you compared it to your 30g?
-Ray Bradbury
Offline khaangaaroo
« Reply #6 on: Fri, 22 March 2013, 02:50:10 »
Yeah, I tried it out for a full day at work, and it was a lot more fatiguing than I expected. That might be because I'm more used to 30g and mx reds (my two switches of choice.) But I wouldn't call 45g too heavy, they just feel a bit stiff. Not being able to type without bottoming out is tiring. I have a feeling my fingers will probably adapt after a few days though. We'll see.
Offline iri
« Reply #7 on: Fri, 22 March 2013, 03:17:55 »
realforce 45g is fatiguing... people are really, really different. did your fingers ache? just curious. mine do when typing on a 45g.
-Ray Bradbury
Offline Macsmasher
« Reply #8 on: Fri, 22 March 2013, 06:31:35 »
I know most guys like the 45g and 55g Topre boards. I've had an 87U variable for about four months, and just got a HHKB Pro 2, which is 45g uniform. I do like the 45g HHKB. But in terms of typing comfort, I'll take the 30g - 45g Realforce any day over the HHKB.
Offline longweight
  • philanthropist
« Reply #9 on: Fri, 22 March 2013, 06:35:38 »
The spring shouldn't make any noticeable difference to the feel of the key press....
Offline daerid
    • Rossipedia
« Reply #10 on: Fri, 22 March 2013, 10:41:52 »
Cray cray. I ended up trading out the 45g for the 55g because it felt like all the keys were too loose, that there was something wrong with them. But then, I'm 6'2" with 4" fingers.
Offline vipjun
« Reply #11 on: Fri, 22 March 2013, 11:03:12 »
WOW this is real crazy how does 2 springs even fit inside LoL!
WTT Realforce 87ub variable for 55G / MX PCB mount
http://geekhack.org/index.php?topic=42360.msg861771#msg861771
Offline iri
« Reply #12 on: Fri, 22 March 2013, 11:37:20 »
mine is all good with the keys, but the case is loose. and i'm 185cm with 22.5cm hands if this is relevant.
-Ray Bradbury
Offline khaangaaroo
« Reply #13 on: Fri, 22 March 2013, 11:44:10 »
You guys have big hands...haha
iri, you could try putting some tape or something around the inner edges of the case before clamping the two halves together. Maybe that will close any gaps and tighten it down.
Offline daerid
    • Rossipedia
« Reply #14 on: Fri, 22 March 2013, 11:46:07 »
The top part of my AE is slightly loose, but that doesn't really make a difference in use.
Offline khaangaaroo
« Reply #15 on: Fri, 22 March 2013, 12:02:26 »
The lonely spring
Offline iri
« Reply #16 on: Fri, 22 March 2013, 12:34:49 »
thanks. it's only a bit loose though. doesn't affect the overall typing experience. and there was a geekhack member (you?) who comfortably used their realforce board without the case.
also lolz @ the lonely spring )
« Last Edit: Fri, 22 March 2013, 12:38:08 by iri »
-Ray Bradbury
Offline khaangaaroo
« Reply #17 on: Fri, 22 March 2013, 12:40:09 »
haha yeah that was me without the case. I just thought I'd throw it out there in case the case of the loose case was really bothering you.
Offline iri
« Reply #18 on: Fri, 22 March 2013, 13:02:35 »
Hahaha
-Ray Bradbury
Offline morpheus
« Reply #19 on: Sat, 23 March 2013, 04:52:35 »
I don't know why, but the phrase "typing on a cloud of boobs" came up when I saw that picture of a lonely spring.
Offline vun
  • Just one more thing
« Reply #20 on: Sat, 23 March 2013, 06:12:30 »
More like "cloud of torpedo tits", going by the shape of the spring.
