Author Topic: Keycap Removal Tip  (Read 4128 times)
Offline Chase5delta
  • Keyboardoholic
Keycap Removal Tip
« on: Sat, 23 March 2013, 00:56:37 »
Just incase any of you didn't know this, an average guitar pick makes for a pretty great keycap remover, I prefer it over a wire puller easily. :D
Filco MJ2 TKL (Mx Blues) Keycool 84 (Mx Reds)
Offline Grim Fandango
Re: Keycap Removal Tip
« Reply #1 on: Tue, 26 March 2013, 05:28:10 »
Hmmm, I have various guitar picks... but I do not really see how they make a good keycap removal tool . Some instructions maybe?
One thing that I am not able to do with a pick is put equal pressure on both sides of the keycap to gently remove them. Though I suppose you could just jam it in there and pop it off......  :))
Offline Chase5delta
  • Keyboardoholic
« Reply #2 on: Tue, 26 March 2013, 22:02:07 »
Yeah I kinda just put slide it in the bottom and slowly pop it up. Idk if this is bad or not, I havent had a problem yet.
Offline tricheboars
  • Keyboards are Important!
« Reply #3 on: Tue, 26 March 2013, 22:11:47 »
hmm i could see that this is good in a bind but it does not give uniform force pulling up. this could result in a broken stem if not done carefully as this method would require one side of a keycap to take all the stress. i am not sure how great the guitar pick method maybe removing larger keys that require stabs.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Sat, 30 March 2013, 20:21:01 »
If you're only lifting it up from one side, it's not putting even pressure on the stems. Wire puller is still probably fastest and safest.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #5 on: Sat, 30 March 2013, 20:24:38 »
Offline drdoooom
« Reply #6 on: Sun, 31 March 2013, 12:44:16 »
i think i'll stick to the wire puller..
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #7 on: Sun, 31 March 2013, 13:05:21 »
Paperclip pullers for life!
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Neal
  • Skype: iNewbcake
« Reply #8 on: Sun, 31 March 2013, 14:53:11 »
Wirepuller <3
