Author Topic: Question about springs  (Read 1356 times)
Offline Chase5delta
  • Keyboardoholic
« on: Sat, 23 March 2013, 23:57:16 »
If I buy 35g springs or something light like that will I be able to replace the springs with MX Blacks to basically make reds?
Filco MJ2 TKL (Mx Blues) Keycool 84 (Mx Reds)
Offline Turbo Slaab
Re: Question about springs
« Reply #1 on: Sat, 23 March 2013, 23:58:40 »
If you put MX black springs in, if it's a linear switch, it will be a MX black. Or ghetto black.
Looking for CC's!
Offline khaangaaroo
« Reply #2 on: Sun, 24 March 2013, 02:12:06 »
I think OP meant putting lighter springs into mx blacks switches. Yes, that will basically make (ghetto) reds.
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
« Reply #3 on: Sun, 24 March 2013, 03:02:55 »
yes , you can !! I think you can use brown switch spring change to black switch ,
feel that , and you will feel just like red switch !
make different
