Author Topic: Vinyl Plate Wrap  (Read 3321 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
Vinyl Plate Wrap
« on: Thu, 28 March 2013, 13:52:51 »
Anyone know of a vendor in stock? Also, is it possible to apply the wrap without taking apart the keyboard and attaching it just by removing the keys?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
Re: Vinyl Plate Wrap
« Reply #1 on: Thu, 28 March 2013, 13:56:30 »
I don't think you will be able to cover your whole case with the vinyl wrap without taking apart the case. You can probably cover most of it, but it'll look sloppy and increase your chance of getting bubbles.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2 on: Thu, 28 March 2013, 14:03:39 »
Mimic-Cables showed an image of one that they might be selling at this link, but you're going to have to uninstall the plate in order to apply it.
Hope that helps!
Offline OnTheBrink
    • Wired In Store
« Reply #3 on: Thu, 28 March 2013, 14:55:43 »
Hope that helps!
Mimic is out of stock.
Offline SmallFry
« Reply #4 on: Thu, 28 March 2013, 14:57:23 »
IIRC, he just laid out the vinyl and used an XActo knife to get it to how he wanted.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Thu, 28 March 2013, 15:16:36 »
Nope, it was "printed" on a vinyl cutter
source: I helped him
Offline mashby
    • Mashby
« Reply #6 on: Thu, 28 March 2013, 17:06:21 »
Well, he hasn't released it yet, so technically it's never been in stock. LOL!  :))
Offline OnTheBrink
    • Wired In Store
« Reply #7 on: Thu, 28 March 2013, 18:27:01 »
If it is anything like their cables... I will wait for them to release it.
Offline SmallFry
« Reply #8 on: Thu, 28 March 2013, 18:28:26 »
Ah, interesting, not sure how one would line one of those bad boys up though.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Thu, 28 March 2013, 18:58:43 »
What I assume he was asking is will you have to desolder all the switches or does this go around them?
Offline mistakemistake
  • Global Loveinator
« Reply #10 on: Thu, 28 March 2013, 21:57:02 »
you would need to desolder first for sure. I actually just need to get my hands on a few plates first and get some more test fitting going. I'll probably get with beast again here soon and see if I can put something out for you guys.  as for applying the vinyl, it was pretty easy the first time. I used transfer tape and a tiny mist of distilled water.
Offline esoomenona
  • Gnillort?
« Reply #11 on: Thu, 28 March 2013, 22:03:54 »
Hmmmmm... I would think it would be better from a buyer's standpoint to NOT have to desolder. Can't it be engineered to go around the switches? This would be even better because if I wanted to switch colors, I could just pull it off, buy a new one and go.
Offline Skull_Angel
« Reply #12 on: Thu, 28 March 2013, 22:32:00 »
I'm not sure that's possible w/o it ending up looking tacky by not fully covering visible parts of the plate around the switches; trying to apply it with the switches still installed could also lead to other problems if water (liquid) is needed to help apply it.
Offline OnTheBrink
    • Wired In Store
« Reply #13 on: Fri, 29 March 2013, 00:11:23 »
The vinyl plate sticker had the switch cut outs so you do not need to desoder.
Offline elton5354
« Reply #14 on: Fri, 29 March 2013, 00:19:40 »
Yeah, but the switches are on top of the plate. The holes aren't big enough. You need to desolder to install the sticker then you put the switch on top of the sticker.
