Author Topic: Cherry Stabilizer Stuck  (Read 3530 times)
« on: Fri, 29 March 2013, 06:58:19 »
One of my cherry stabilizers (the black thing) is popped up and won't go back down... I got it to fix itself once but then it felt crappy so I tried to fix it again, and now I can't seem to get it back down.
Re: Cherry Stabilizer Stuck
« Reply #1 on: Fri, 29 March 2013, 07:01:23 »
One of the ones on my Leopold jammed and honestly, I just smashed it until it reset. Not sure if that was the best thing to do but it worked.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 29 March 2013, 08:02:31 »
Most likely the wire has gotten unseated from it's clip. If so just take something like a small screwdriver or tweezer and push it back into the clip until it snap in place.
