Author Topic: keyboard does not set flat, it wobbles ever so slightly...  (Read 4360 times)
Offline jksteger
« on: Mon, 01 April 2013, 15:36:04 »
I purchased a Ducky TKL with Black Alps to complement my Green Alps one.  I love the Black Alps, these are my favorite by far!  The problem, and this is driving me crazy, is that the top right and bottom left wobbles.  I have to slide a business card under either to top right or bottom left to make it quit wobbling!
Is this something worth trying to send it back from where I purchased it from or ask them to send some replacement "pads" for the corners?  I've got a little tape on the top right pad to make it set correctly but now it doesn't 'grip' the desktop as much as before.  I though maybe my desk was not level so checked my other keyboards and TKL's and no wobble, it's def. either the case or the pads!
What would you do?
Thanks,
J:
Offline Grim Fandango
Re: keyboard does not set flat, it wobbles ever so slightly...
« Reply #1 on: Mon, 01 April 2013, 15:56:38 »
Man, that seems to be an annoying issue. To me, having to always use a card or something to offset the height difference is just not something I am willing to do on a brandnew keyboard. I would first see if I can locate and address the problem itself. Maybe the little piece of rubber on one of the feet is oddly shaped and can be adjusted with a file or something. If there was no easy way to take care of it, I would just RMA.
Offline jksteger
« Reply #2 on: Mon, 01 April 2013, 16:02:09 »
thanks for the insight.  that gave me a thought, maybe i should pry the rubber feet/pad, whatever the technical term is for it, LOL, and place the piece of tape under it.
I will give that a go!  If that doesn't work then I will RMA.
Thanks,
J:
Offline zoolzoo
« Reply #3 on: Mon, 01 April 2013, 19:53:04 »
Try putting it on a different surface and see if it wobbles. It could be your desk too yah know...just double check it.
Both of my QFR's will wobble if I push them further to the right on my desk. When I move them back to the center where I type they do not wobble.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Mon, 01 April 2013, 21:07:30 »
Or you can always place a face towel under the keyboard.  It fix the wobble issue and make your keyboard sound nicer too  :D
If you think towel look ugly try mouse pad or desk mat.
Offline aggiejy
« Reply #5 on: Mon, 01 April 2013, 21:26:02 »
Arg, this drives me crazy too.  I have had 4 different filcos and 3 of them wobble on my desk.  In my case though, I think it's partly my desk.  Problem is that you can't really do a whole lot (easily) with rubber pads.  On keyboards with plastic feet, you can at least shave them down a little bit.  But I use a plastic membership-type card under one corner.  Can't see it, but I know it's there.  Grrrrr.....
