Author Topic: Mechanical Numpad as Gamepad  (Read 6209 times)
Offline hashish
« on: Mon, 08 April 2013, 16:38:41 »
So I have a spare mechanical numpad that I don't use very much. I would like to re-purpose it as a game pad ala the g13 or the orbweaver. I have a g13 and I like it but I don't love it. I would like to see how a mechanical keypad would fare compared to my g13. Does anybody have any advice on how to remap keys on a second HID?
(I wish logitech would update the g13 with mechanical switches)
Offline quake4mhg
Re: Mechanical Numpad as Gamepad
« Reply #1 on: Tue, 09 April 2013, 01:26:32 »
Can autohotkey do it?
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Tue, 09 April 2013, 22:25:49 »
HID Macros
Offline hashish
« Reply #3 on: Tue, 16 April 2013, 12:54:24 »
Thanks for the suggestions, I think that is exactly what I am looking for.
Offline hashish
« Reply #4 on: Wed, 17 April 2013, 16:22:25 »
argh, no matter what i press on my usb keypad directly connected to my computer it triggers my KVM switch. How weird is that. If it work, I was going to mod a usb thumb joystick (from a gamepad) for a mechanical logitech g13 ish thing
Offline ImperfectLink
« Reply #5 on: Fri, 28 June 2013, 12:30:15 »
Maybe look into USB Overdrive or SharpKeys?
That said, you sould just sell me the spare numpad ;-)
Offline Thimplum
  • Master of all Ponies
« Reply #6 on: Tue, 09 July 2013, 11:38:41 »
Get a Teensy and direct wire the switches? My trolling does need work.
TP4 FOR ADMIN 2013
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #7 on: Fri, 12 July 2013, 15:55:45 »
If it was a Cherry 3700 old school model, you could put it into Mode 4 and the entire thing becomes hard programmable. If it's not, AHK should do the trick, or just change bindings in game to the numpad keys?
TOO BAD FOR YOU
              Phantom 62g MX Whites
