Author Topic: Space invader switchs are similar to (Insert switch here)  (Read 3667 times)
Offline Neccros
« on: Thu, 11 April 2013, 16:27:18 »
I've searched and haven't found a clear answer... I love how white Space Invader switches feel, very clean and crisp w/o any mid stroke resistance.
So due to the lack of access to keyboards with the various options for switches, what would you say is close to feel and sound to a white Space Invader switch based NMB keyboard????
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
Re: Space invader switchs are similar to (Insert switch here)
« Reply #1 on: Fri, 12 April 2013, 02:44:52 »
space topres?
topres with alps click (or if you can feel it, like a older ballpoint pen click mechanism?). Seriously I have brown/black/blue/white/clear mx, white/black/blue/pink/salmon alps, & model m keyboard/switches. Invaders feel like none. Check the fujitsu.
My only explanation is since the casing is the slide, it feels much more stable, and there is not much of a hollow resonance effect and may be the materials are softer than cherry/alps, so no prominent click/clacks. Overall feels good.Only bad is the keycap-flying effect :)
I am also waiting to find the answer. I have only the black invaders.
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Offline blueSmoke
« Reply #2 on: Fri, 12 April 2013, 02:54:36 »
oops! sent before reading. I dont have any white invaders. so context changed.
Offline BucklingSpring
« Reply #3 on: Sat, 13 April 2013, 21:58:23 »
NBM Space Invaders are a better version of MX Green :-)
Boards I own, click ->
Offline tipo33
  • "Ski"
« Reply #4 on: Sat, 13 April 2013, 22:43:20 »
They are ...... wierd.  I really can't compare them to any other switches.  I personaly like them.
KM4COL    R.I.P.  SmallFry
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #5 on: Sat, 13 April 2013, 23:06:20 »
I think NMB Space Invaders actually might compare most accurately to low usage SMK's. Been a while since I've typed on NMB Spaceys though.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline SmallFry
« Reply #6 on: Sat, 13 April 2013, 23:09:31 »
Also related... how do you pull the caps off of one of these beasts?
Offline Hak Foo
  • Make America Clicky Again!
« Reply #7 on: Sun, 14 April 2013, 01:01:04 »
ML maybe?  My brief experience was all about the limited throw.
Overton130, Box Pale Blues.
« Reply #8 on: Sun, 14 April 2013, 03:03:45 »
Nothing really. They feel completely unique imo, if only I could find cap replacements without buying an entire new board  :(
« Reply #9 on: Sun, 14 April 2013, 11:26:39 »
I use a regular keycap extractor gripping both sides of the keycap. Pull gently and straight up. My two NMB space invaders boards are from the late production and never seen much light. So the plastic is still in good shape. I don't know if the older ones tends to break when you pull them out.
Offline SmallFry
Re: Re: Space invader switchs are similar to (Insert switch here)
« Reply #10 on: Sun, 14 April 2013, 11:31:59 »
Isn't there a spring that goes flying?
« Reply #11 on: Sun, 14 April 2013, 11:35:37 »
Hum, not that I recall. I could swear I posted a photo of one recently on this forum. I don't remind an exposed spring.
Maybe if you take the switch apart?
Offline SmallFry
« Reply #12 on: Sun, 14 April 2013, 11:38:02 »
Dunno, I've got a board that I got at the meet yesterday that needs a bath... perhaps in a hazardous material tank. :P I'll check here in a few if there's a spring. They do feel really nice though.
