Author Topic: WYSE Moogle Key GB [SHIPPING]  (Read 67618 times)
Re: WYSE Moogle Key GB [Ordering until Wednesday]
« Reply #100 on: Sun, 05 May 2013, 23:28:08 »
Please ignore my ignorance but would a Moogle still be useful for a G80 or not?  Yes I am that slow when it comes to Moogles, because I do know they are for every other keyboard out there but generally not for the Original Cherry (depends which model)  :-\ .
But for WYSE, a moogle is almost always a necessity with any keyboard, since they were mostly terminal boards, and the mods have strange sizes, or simply don't exist.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #101 on: Mon, 06 May 2013, 00:15:13 »
Thank you JD.  Much appreciated, always helping the ignorant and lazy in figuring out the basics with Keyboard Design  ;D .
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #102 on: Mon, 06 May 2013, 00:58:51 »
Would increase cost by few bucks...anyone opposed to doing both?
Not I. Bring on both!
Offline whiskytango
  • Don't touch the trim
« Reply #103 on: Mon, 06 May 2013, 11:19:46 »
When you say "both", do you mean:
1. Full touch and center stemmed stepped caps locks, or
2. Full touch and off-center stemmed stepped caps locks?
If off-center stepped, why would this need to be in the moogle if it's already in the tsangan? I don't know a lot about Cherry boards, are there some that use the off-center stemmed caps lock and standard keys everywhere else? I thought they also needed the 1.75 R Shift that is also included with tsangan kit and maybe some odd sized bottom row mods?
If it's not much more, I would be all about adding an extra center-stemmed stepped caps lock. Wouldn't mind adding the ~` key either while we're at it :p
I don't really need more off-center stemmed caps locks, but I doubt they would add much to the cost of the kit, so I would be fine with that too if it helps people with compatibility.
« Reply #104 on: Mon, 06 May 2013, 11:24:08 »
We have to hit the better prices guys, I can't afford three kits at >$50 !
« Reply #105 on: Mon, 06 May 2013, 11:24:53 »
50 sets $38.33 per set :D
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #106 on: Mon, 06 May 2013, 11:26:11 »
Talked to Boost....whiskytango makes a good point that this is a MOOGLE which is designed to retro-fit a standard ANSI board.  Aint nobody got time for an off-center stepped and if you need it get a tsangan.
We agreed that we should do a Center Stemmed Stepped Caps AND a Center Stemmed Flat Caps.
This will increase the cost by a few bucks, but will give everyone the option.
If anyone strongly objects to this decision, please PM me.
Offline placebo guy
« Reply #107 on: Mon, 06 May 2013, 21:03:12 »
Thank God I checked GeekHack after 6 months.  I would've missed this for my mint WYSE set.
Submitted my order.  Thanks Boiler!
PS - BHawks are going down, down, down!!!  Go Wild.
Leopold TKL MXRed; RF 103U 55G; WASD MXBlack; Unicomp Spacesaver; AT101W; RK-9000 Blue; various Filco
Offline cgbuen
    • cgbuen.io
« Reply #108 on: Mon, 06 May 2013, 21:20:54 »
Will wait for more info on the center-stemmed stepped. I'd consider jumping in if I knew the updated price breaks!
  • techkeys.us
    • TechKeys
« Reply #109 on: Mon, 06 May 2013, 21:42:44 »
The price breaks will look the same but will be a few dollars more.  I will try to get exact pricing tomorrow.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #110 on: Mon, 06 May 2013, 23:46:42 »
Hooray center stem stepped caps lock!
Offline evolyn
« Reply #111 on: Tue, 07 May 2013, 03:56:02 »
so in the moogle kit are all keys expect for 9cluster to fit on the kmac1 ? i try to figure that out.
plz help thx.
Offline strafe
    • Strafe's Blog
« Reply #112 on: Tue, 07 May 2013, 09:33:10 »
Put an order in for one set.
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
Offline whiskytango
« Reply #113 on: Tue, 07 May 2013, 10:03:05 »
plz help thx.
The moogle only includes keys to fit an standard ANSI layout that are not included with an old WYSE set. Look at the list of keys included in this moogle which are listed in the first post. Then look at your keyboard and note which keys on your keyboard are not listed as being part of the moogle. Those are the keys you need besides the moogle. If your bottom row uses the 1.5 mods and 7x spacebar, you will also need a tsangan kit in addition to the moogle. See this link. The leftovers from that group buy are available at techkeys.us
You will also need to source an old set of WYSE keys as well for the alphas and other modifiers not included in the moogle or tsangan (Such as the 9 keys above the arrows which are included with some but not all types of old wyse boards)
Offline Dubsgalore
« Reply #114 on: Tue, 07 May 2013, 10:03:37 »
I am out..thought i was going to need to order a moogle, but i'm good!
Offline cgbuen
    • cgbuen.io
« Reply #115 on: Tue, 07 May 2013, 15:11:39 »
Or, if any one person objects to the center-stemmed caps, I'd be willing to buy it off that person.
Offline remedyhalopc
« Reply #116 on: Wed, 08 May 2013, 02:38:39 »
Forgot to post here that I'm out. I won mimics auction for his full wyse set. Thanks anyway guys!
  • techkeys.us
    • TechKeys
« Reply #117 on: Wed, 08 May 2013, 07:51:36 »
Removed
  • techkeys.us
    • TechKeys
« Reply #118 on: Wed, 08 May 2013, 07:52:24 »
LAST day for orders!
Offline whiskytango
Re: WYSE Moogle Key GB [LAST DAY TO ORDER]
« Reply #119 on: Wed, 08 May 2013, 10:16:10 »
Is there an update on the cost to add the extra caps lock?
« Reply #120 on: Wed, 08 May 2013, 10:21:34 »
I have to reduce my order to 2, need money to fund a PCB fab
  • techkeys.us
    • TechKeys
« Reply #121 on: Wed, 08 May 2013, 10:40:12 »
Done
Had a few drop their order or qty...we are just floating over 50 right now!
  • techkeys.us
    • TechKeys
« Reply #122 on: Wed, 08 May 2013, 10:45:13 »
Final pricing is up.  As I suspected, it was a few bucks more.
Offline whiskytango
« Reply #123 on: Wed, 08 May 2013, 11:39:32 »
that's not terrible.... and I am sure you can sell off the extra stepped key if you don't want it
And bump to the top. Come on, lets get some orders in! Last minute rally to 75!
« Reply #124 on: Thu, 09 May 2013, 20:07:40 »
I actually need back in....mimc's auction didn't come with all the keys I thought it was going too.
  • techkeys.us
    • TechKeys
« Reply #125 on: Thu, 09 May 2013, 20:08:52 »
Please complete the form again.
I will invoice tomorrow
« Reply #126 on: Fri, 10 May 2013, 11:00:02 »
Paid! Thanks, guys. :D
Offline Kayliss
« Reply #127 on: Fri, 10 May 2013, 13:34:52 »
That was fast updating the paid list!  :))
« Reply #128 on: Fri, 10 May 2013, 15:24:54 »
real quick before I get an invoice...
does anybody NOT need the bottom row keys and spacebar? I have 1.5 bottom row keys and a 7x spacebar. Perfect fit for korean boards!
I'll either buy them off of you or trade you my 1.5x/7x stuff.
« Reply #129 on: Fri, 10 May 2013, 15:25:51 »
Kinda the whole point of this exercise, though... :)
« Reply #130 on: Fri, 10 May 2013, 15:28:00 »
Wow $100 for two moogle kits.... damn  :(
Offline whiskytango
« Reply #131 on: Fri, 10 May 2013, 15:40:49 »
I know... I was certain this would at least hit 75. Oh well, still excited about getting more WYSE moogles.
Also, which windows logo will we get, old style or new? EDIT: Wait, no, make it a surprise  :eek:
« Reply #132 on: Fri, 10 May 2013, 15:41:45 »
Win95 style, yeah!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #133 on: Fri, 10 May 2013, 17:10:56 »
Blank!  Blank OS keycaps!  Or Tux!  Or mutant hamsters!  Please just not the stark Win8 or giant Win95 logos.
This message typed on a Model M keyboard without Windows keys on a Linux workstation that scoffs at them anyhow!
 - Ron | samwisekoi
Offline numerus
  • Happy go lucky
« Reply #134 on: Fri, 10 May 2013, 17:22:38 »
 - Ron | samwisekoi
Indeed!!! pls no big Posters on our Keys :D
KBC Poker II | HPE 87% | FILCO Majestouch 2 | Cherry G81-3000 | Marquardt MK | CM NovaTouch TKL | POK3R
Offline whiskytango
« Reply #135 on: Fri, 10 May 2013, 18:52:13 »
Win95 style, yeah!
Ok I 2nd this. Old school all the way
Offline SmallFry
« Reply #136 on: Fri, 10 May 2013, 19:22:10 »
Paid.  :) Thank you!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #137 on: Fri, 10 May 2013, 19:59:30 »
Old School!
« Reply #138 on: Fri, 10 May 2013, 20:13:19 »
Old school Win95 logo because it matches the first round if these, organized by Quarzac. (Where ya been, buddy?)
I'll always have a place in my heart for the first round WYSE Moogle buy. It was my first GB when I joined! :)
  • Kitteh Overlord
  • Say WHAAT...
Re: WYSE Moogle Key GB [Ordering]
« Reply #139 on: Fri, 10 May 2013, 21:38:21 »
I have to change my order to just 1...  :mad:
This didn't take off like I thought it would.  :))
Invoice doesn't show just one... Help?
  • techkeys.us
    • TechKeys
« Reply #140 on: Fri, 10 May 2013, 22:10:37 »
Updated -- any more cancellations and we will need to consider waiting for more orders or cancelling the group buy.
Offline whiskytango
« Reply #141 on: Fri, 10 May 2013, 22:18:18 »
out of curiosity, did anyone advertise this on any other boards? DT, reddit, KDB, etc?
Offline mushupork
  • I am not knowing
« Reply #142 on: Fri, 10 May 2013, 22:27:35 »
If the point is to make it look like a match for WYSE should the key not look like an original set would?  If there was no such key then blank makes sense to me.  A modern logo on a "period" keyset is wrong, like a raygun in a western movie.  On the other hand, rather than a blank, has anyone done "geekhack" in the WYSE font for that key?  OS/technology agnostic but not plain.
Wanted:  Windowed capslock for a QFR
  • Kitteh Overlord
  • Say WHAAT...
« Reply #143 on: Fri, 10 May 2013, 23:44:45 »
Paid.
Offline okooko
  • afk.
« Reply #144 on: Sat, 11 May 2013, 04:48:59 »
Boiler, paid just now.
Didnt realise this was during invocing. all good.
  • techkeys.us
    • TechKeys
Re: WYSE Moogle Key GB [NEED MOAR ORDERS]
« Reply #145 on: Sat, 11 May 2013, 22:23:42 »
Everyone is invoiced - Pay Up!!
Still accepting orders until everyone is payed.
Offline calavera
« Reply #146 on: Sat, 11 May 2013, 22:44:56 »
Holy crap I thought the price would be lower. :(
Was this posted in other forums at all?
Offline ebacho
« Reply #147 on: Sat, 11 May 2013, 23:19:45 »
Paid.
« Reply #148 on: Sat, 11 May 2013, 23:21:28 »
There are other forums?
Offline khaangaaroo
« Reply #149 on: Sat, 11 May 2013, 23:23:57 »
I thought we would hit higher tiers, but looking at the original GB by Quarzac, there seems to be about the same, maybe slightly fewer people that participated in the first one. So WYSE demand is about the same, but SP's pricing has gone up?
