Author Topic: How do I clean my keyboard o.o  (Read 1603 times)
Offline Moleboy
« on: Wed, 24 April 2013, 16:12:22 »
I have a Ducky Shine (v1), and I'm good with taking the keycaps off--but it's absurdly hard to clean in between the switches...any special way/guide to doing this? =D
Offline Emmiya
Re: How do I clean my keyboard o.o
« Reply #1 on: Wed, 24 April 2013, 16:15:13 »
Compressed air always worked for me, unless it's baked on(shouldn't be). In which case, just take an old toothbrush/ any sort of fine brush and gently rub then turn upside down and shake.
Offline Grim Fandango
« Reply #2 on: Wed, 24 April 2013, 17:17:34 »
Why not just get a keycap puller and take the keycaps off? Does not take too long. It is not like you need to do it every day and you can leave any key with a stabilizer on.
Though I can not blame you. I am lazy. Cleaning often means keeping it upside down for a bit, and wiping it down with microfiber cloth.
« Reply #3 on: Wed, 24 April 2013, 17:29:47 »
Vacuum is better than pressure, in general.
Q-tips and alcohol are good.
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline birthdaymonkey
« Reply #4 on: Wed, 24 April 2013, 19:27:07 »
I've always used a vacuum with the narrowest attachment I have. Although sometimes I wish I had an even narrower one.
Realforce 87u 55g | WASD v1 with Blues | Quickfire Rapid with Blues | Filco 87 with Reds
