Author Topic: Mechanical keyboard retailer in New York?  (Read 8973 times)
Offline linziyi
  • The one with many questions
« on: Sun, 28 April 2013, 09:43:38 »
Hi! Newbie here! I just ordered a used keyboard with blue MX in this very forum, but very interested in other types of switches. Just wondering if there exist any store in New York (preferably in Queens because I live there :P ) that I can try out different types of switches? Thanks for information!
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline histevenhere
  • Student
Re: Mechanical keyboard retailer in New York?
« Reply #1 on: Wed, 01 May 2013, 18:59:02 »
Brooklyn here ! I believe you can only try the ones at Best Buy if you're lucky ... from experience, I purchased separate switches from WASDkeyboards and put keycaps on them to try out. Good luck !
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
Offline aggiejy
« Reply #2 on: Wed, 01 May 2013, 22:08:40 »
Welcome to Geekhack!  Unfortunately in the US, there doesn't seem to be many places where you can try out a lot of mechanical keyboards.  (Unlike Japan for instance)  But such a thing SHOULD exist. :)
Offline vipjun
« Reply #3 on: Thu, 02 May 2013, 08:58:25 »
there are a few at J&R in the city. I've not come across keyboards from bestbuy that are mechanical is there a specific one that carries them?
WTT Realforce 87ub variable for 55G / MX PCB mount
http://geekhack.org/index.php?topic=42360.msg861771#msg861771
